Poor Backup Lighting
Discussion in '3rd Gen Tundras (2022+)' started by RVer, Mar 30, 2023.
  1. Mar 30, 2023 at 10:40 AM
    RVer
    RVer [OP] New Member
    2023 Platinum CrewMax
  2. Mar 30, 2023 at 10:42 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    RVer[QUOTED][OP] and Taco-Spike like this.
  3. Mar 30, 2023 at 11:07 AM
    ucf3
    ucf3 New Member
    Nabil
    2022 Tundra 1794
    nothing yet
  4. Mar 30, 2023 at 11:10 AM
    Taco-Spike
    Two Trucks
    RickyBobbysTundra and RVer[OP] like this.
  5. Mar 30, 2023 at 11:44 AM
    RVer
    Thanks guys, looks like some good options there.
  6. Mar 30, 2023 at 11:48 AM
    RVer
    Thanks. Looks like a pretty easy install. I have a tight space to negotiate, with obstacles, which can be a challenge on rainy nights; the more light back there the better.
    RickyBobbysTundra likes this.
  7. Apr 16, 2023 at 5:59 AM
    RVer
    Just an update: I went with Diode Dynamics reverse lighting and am pretty happy with the lighting, much improved over stock. The install could not be any easier and is truly “plug and play”. IMG_8288.jpgIMG_8287.jpg
  8. Apr 16, 2023 at 6:21 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Which ones are those? What did they plug into. Can you take a pic of them during the day
  9. Apr 16, 2023 at 7:16 AM
    chance12
    chance12 New Member
    GA
    23 Tundra CM Limited
    Ive got the Diode Dynamics SSC2 Pro reverse lights. I believe same as @RVer . Here are a couple of pics including one in the day time. There is a wiring harness that plugs into the 7 pin trailer plug.
    NewImprovedRon and RVer[OP] like this.
  10. Apr 16, 2023 at 7:26 AM
    RVer
    Kit Configuration
    SSC2
    Power Level
    Pro
  11. Apr 16, 2023 at 7:40 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    Thank you. Those look good!!! I don’t see the wire plugged in, does it plug in behind the bumper?
  12. Apr 16, 2023 at 7:44 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    I’ve got the old version of this still kicking and it’s awesome
    Taco-Spike[QUOTED] and RVer[OP] like this.
  13. Apr 16, 2023 at 8:01 AM
    chance12
    chance12 New Member
    GA
    yes
  14. Apr 16, 2023 at 5:40 PM
    RVer
    Yes, as described in chance12's post above. It'll take less than a half hour and that's if you take your time and dress the cables up nicely. Super simple install.
    chance12 likes this.
