17" Method wheels...what tire size, no lift?
Discussion in '3rd Gen Tundras (2022+)' started by SD.Tundra.858, Jan 10, 2023.
  1. Jan 10, 2023 at 4:48 PM
    SD.Tundra.858
    SD.Tundra.858 [OP] Family man...Toyota fan! Best spices in town!
    Travis
    San Diego, CA
    2023 Black Limited 4x4 w/ Platinum package
    I am hemming and hawing on whether or not to lift this truck right now. I enjoy the ride as is and I don't do much off-roading but I definitely want a better looking stance and set up. The wheels I got from method have zero offset and are basically the factory setup...from what I was told. What is the largest tire I could probably run on them without changing anything else on the truck? Has anybody got any pictures of a 17-inch wheel with the larger tire but not lifted? I'd love to see what the Tundras might look like without a lift, but larger off-road tires!
  2. Jan 10, 2023 at 9:00 PM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    Platinum714 and ChuckL like this.
  3. Jan 10, 2023 at 9:44 PM
    SD.Tundra.858
    Travis
    San Diego, CA
  4. Jan 10, 2023 at 9:58 PM
    SD.Tundra.858
    Travis
    San Diego, CA
    Found your post...looks great!
    Question... I'm slightly confused on offset. I didn't want much poke on mine, so when talking with Method, the suggestion a the 706 with the factory setup. So I believe it's 35m? I was told I most likely can't fit larger than 295/75/17. Any thoughts on that? Can I fit 34s?
  5. Jan 11, 2023 at 3:57 AM
    TexasTacoma713
    2023 SR5
    Don’t always believe what you’ve been told until you do your homework my guy. https://youtu.be/9jcunpA0cC8
    You can fit 34s no problem. 315/70 is a smidge bigger than 34”. You can even fit 35” with no lift but you’ll need to do a little trimming
    SD.Tundra.858[OP] likes this.
  6. Jan 11, 2023 at 8:11 AM
    SD.Tundra.858
    Travis
    San Diego, CA
    Thanks for sharing. I like his channel...
  7. Jan 11, 2023 at 9:43 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Wheel offset is the offset from the center of the wheel to the mounting points. It’s not the difference from factory specs. So 0 offset doesn’t mean it’s the same as factory setup. I believe stock wheels are still +60 on the 3rd gen. That’s almost a 2.5 inch difference. You need to figure out exactly what offset you have before buying tires.
    Tom likes this.
  8. Jan 11, 2023 at 10:35 AM
    TexasTacoma713
    2023 SR5
    From my observations not a lot of 17” wheels have positive offsets. 18” have more of a selection of + offsets
  9. Feb 2, 2023 at 9:20 PM
    TUNDRA-TY
    TUNDRA-TY Winter SUCKS!
    Tyler
    Tricities, WA
    23 SR5 4WD CMSB CSM
    Method 316s
    17x8 +25 offset
    285-70R17
    Just a little poke. No rubbing
  10. Feb 3, 2023 at 12:21 AM
    Fooyotatundra
    Fooyotatundra New Member
    2022 sr5 trd 4x4
    Blackhorn bh01
    17x9 +12 offset
    35x12.5x17 Toyo open country RT
    No lift, just removed the metal piece behind the liner and no rubbing.
  11. Mar 6, 2023 at 5:00 PM
    Navigator82
    Navigator82 New Member
    Carlos
    How is the clearance of the caliper on the wheels. I have been told that it will rub the inner wheels
  12. Mar 6, 2023 at 5:13 PM
    Tom
    Tom New Member
    705 +35 off set Method
    17x8.5
    285/70/17 yoko
    Yaboy and joonbug like this.
  13. Mar 6, 2023 at 5:17 PM
    Navigator82
    Carlos
    I have the Sema TRD 17 with 285/70/17 duratracs I just wan to know if the wheel will spin freely without the calipers tubing on the wheels
  14. Mar 6, 2023 at 5:21 PM
    Tom
    Tom New Member
    You have the truck. You have the wheel. Only you know for sure.
    Yaboy and TexasTacoma713 like this.
  15. Mar 6, 2023 at 5:23 PM
    Navigator82
    Carlos
    I’m just asking to see if is safe to drive it
  16. Mar 6, 2023 at 5:24 PM
    Tom
    Tom New Member
    Jack the truck up and spin the wheel. If it doesn’t make contact with anything you should be ok. I have 17” on my truck for over a month now.
  17. Mar 6, 2023 at 5:26 PM
    Navigator82
    Carlos
    How hood is the clearance? Between the caliper and the wheel?
  18. Mar 6, 2023 at 5:31 PM
    Tom
    Tom New Member
    About 3/8”
  19. Mar 6, 2023 at 5:32 PM
    Navigator82
    Carlos
    WoW actually u have more clearance. I may have 1/8 or less
  20. Mar 6, 2023 at 5:39 PM
    Navigator82
    Carlos
  21. Mar 6, 2023 at 8:47 PM
    mambajack
    mambajack New Member
    I am running method 703s +35 offset on 315/70/17. Before a level I had to remove the mudflaps in the front and pin back the liner so it wouldn't rub. Never tried to see if stretching it out touched anywhere
  22. Mar 16, 2023 at 4:22 AM
    UCKYUK
    UCKYUK New Member
    This is the same size setup I am looking at as well - Method 705's +35, with 315's. Do you have any pics you can please share? And no issues hitting any components - just the flap and liner, before you lifted it??
  23. Mar 29, 2023 at 7:02 PM
    mambajack
    Correct. I was a little paranoid, so actually tried the rim on the wheel just to see what clearance was like on the components behind it. Here is a video I took of that if it is helpful at all.
    https://youtu.be/zaHX9uBZISk
    jayhawknavy02 likes this.
  24. Apr 6, 2023 at 6:24 PM
    TRDnoob
    TRDnoob New Member
    2013 Platinum 4x4
    @mambajack do you have any pictures of yours with tires on now?
  25. Apr 6, 2023 at 6:35 PM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    2nd that
