Parking sensors
Discussion in '2nd Gen Tundras (2007-2013)' started by Shelton1007, Mar 28, 2023.
  1. Mar 28, 2023 at 2:05 PM
    Shelton1007
    Shelton1007 [OP] New Member
    2010 tundra
    Just noticed something on my truck.
    The front parking sensors activate when I release my brake pedal from a full stop. They go off after I travel a few feet.
    The sensors on the bumper.
    Electrical?
  2. Mar 28, 2023 at 3:45 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Mine did some weird stuff after a big rain once, then returned to normal after everything dried out.
    Have you had rain there?
  3. Mar 28, 2023 at 5:57 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Maybe they're coming loose inside the brackets? The plastics become brittle and with movement, they may shift in the brackets and cause them to go off.. this is an assumption as we only know what you've given us. One of my sensors was loose and in my inclined parking spot it would be set off with slight movement. replaced both brackets and they've been quiet ever since.
  4. Mar 29, 2023 at 2:01 PM
    Shelton1007
    2010 tundra
    No rain to speak of.
    When I come to a complete stop then accelerate it comes on. Nothing loose or broken that I can see.
    Seems like a connection.
    Let me check wire diagram.
    In case it is just bad sensors anybody have info on where to purchase them?
