  1. Mar 28, 2023 at 10:30 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Both my spare wheels are 16.
  2. Mar 28, 2023 at 11:20 AM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    So. You're already looking for take offs on CL... 17
    Your welcome.
    Now you will see all the Tacoma and 4runner take offs
  3. Mar 28, 2023 at 11:30 AM
    DJenerated
    Dija
    The Lone Star State
  4. Mar 28, 2023 at 11:47 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Brake pad has left the chat. Replacing it with EBC Orange stuff and slotted rotors to match the front. Luckily I have a spare caliper lying around.
  5. Mar 28, 2023 at 12:00 PM
    Oh, stop it! :rofl:
  6. Mar 28, 2023 at 12:02 PM
    DJenerated
    Dija
    The Lone Star State
    I need to do something about my front brakes. But I don't know if upgrading the rotors is enough in my case or should I do the gx460 brake mod or powerstop big brake upgrade. I need to do my research.
    Wait... do you have a rear disc conversion?
    des2mtn[QUOTED] likes this.
  7. Mar 28, 2023 at 12:05 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Make brackets to mount the 6 piston '22 caliper.
  8. Mar 28, 2023 at 12:11 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'm trying to decide if my 2.5 hour layover is enough time to do the Atlanta Skyclub crawl.
  9. Mar 28, 2023 at 12:11 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    bmf4069 likes this.
  10. Mar 28, 2023 at 12:14 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i cant bring myself to pay the prices, but a hallucinogen would be more fun than 9 shots on a flight.
  11. Mar 28, 2023 at 12:22 PM
    DJenerated
    Dija
    The Lone Star State
    But did you even see the spares?
  12. Mar 28, 2023 at 12:25 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I did. Gotta get in town before i schedule anything.
  13. Mar 28, 2023 at 12:33 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    My Sky Club entry is free and so is the alcohol in there. Worst case I'll be out $20 in tips.
  14. Mar 28, 2023 at 2:31 PM
    I've been to many of them, there's not enough difference between them all for me to make that effort.
    Mescaline, please.
  15. Mar 28, 2023 at 2:48 PM
    des2mtn
    Shady Grove
    Tonto cover
    If you have 17" wheels, do the 14WA conversion or get the pricey Powerbrake kit (NOT Powerstop). Powerstop stuff isn't really an upgrade. If you have 16" wheels, there is a pricey Stoptech big brake kit that may fit otherwise you're limited to 13WL calipers.
    And yes I do.
    DJenerated[QUOTED] likes this.
  16. Mar 28, 2023 at 2:54 PM
    DJenerated
    Dija
    The Lone Star State
    Yeah 17's are still in the plans for when my current tires need to be replaced and I can finally shed these lowly 16's and 33's for some 35's. Then bigger brakes for sure.
  17. Mar 28, 2023 at 2:58 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    my powerstop z23 were a definate upgrade over what i'd assume to be dealership brakepads.
    DJenerated likes this.
  18. Mar 28, 2023 at 2:58 PM
    Curious but lazy (rough day): How'd you handle prop valve to balance out front/rear ratio after the upgrade? Was it possible to tweak the LSPV, or did you just borrow the prop valve off the donor Sequoia?
  19. Mar 28, 2023 at 2:59 PM
    DJenerated
    Dija
    The Lone Star State
    Maybe I should try different pads. I'm rocking toyota pads
  20. Mar 28, 2023 at 3:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Had a chance to look at the virus in the light today. The hood latch still works! Crazy!
    20230328_154256.jpg 20230328_154304.jpg 20230328_154356.jpg 20230328_154401.jpg 20230328_154405.jpg 20230328_154412.jpg 20230328_154537.jpg 20230328_154545.jpg 20230328_154552.jpg 20230328_154738.jpg
    The rad fan is broken. Touching the intake. The radiator is bent. The AC condenser is bent. Neither appear to be leaking...
    The high beam bulb needs to be replaced. The radiator support is bent.
    It all looks like an easy fix with a come-a-long some webbing, some zip ties, some zip-screws, some time, some tinkering, and some body panels.
    https://youtu.be/lbd4YMBY4WM
  21. Mar 28, 2023 at 3:08 PM
    des2mtn
    Shady Grove
    Tonto cover
    I deleted the LSPV and put a manual prop valve at the master cylinder. I followed the instructions and adjusted to where the rear brakes would lock up and then backed off from there. I've tweaked it a few times, but overall the pedal feel is great.
    Maybe I should've gotten the Z23 brake pads :cookiemonster:
  22. Mar 28, 2023 at 3:11 PM
    des2mtn
    Shady Grove
    Tonto cover
  23. Mar 28, 2023 at 3:18 PM
    DJenerated and des2mtn[QUOTED] like this.
  24. Mar 28, 2023 at 3:23 PM
    des2mtn
    Shady Grove
    Tonto cover
    So far they've turned out to be my favorite pad I've tried especially with how I use the truck now. They offer less aggressive ones, assume they're cheaper
  25. Mar 28, 2023 at 3:28 PM
    If your layover is today I’ll help you out. Connecting through there in 3, 2, 1……..
  26. Mar 28, 2023 at 3:29 PM
    des2mtn
    Shady Grove
    Tonto cover
    Tundras2Atlanta?
    txagg, tacoguybill, shifty` and 2 others like this.
  27. Mar 28, 2023 at 3:43 PM
    Do they wear well under aggressive use? I would hope so for the price.
  28. Mar 28, 2023 at 3:44 PM
    With roll-aboards instead of actual Tundras. Boooooo. Hit the rental lot like days of thunder
    txagg and RUSTYNUTS like this.
  29. Mar 28, 2023 at 4:18 PM
    @RUSTYNUTS @Azblue @alb1k
    Tried out some flux core!!! Better than I expected, and it actually sounded way better than before(switched out an old stinger) but I think I’ll enjoy using it for the outside projects we do!FC554DDB-2791-4FC3-B335-4A14D2B1D1C5.jpg 978120E9-5BFC-4B22-A4D5-27E134492A84.jpg
    This was inside with a fan blowing on the work, for science!
    RUSTYNUTS, alb1k, bmf4069 and 2 others like this.
  30. Mar 28, 2023 at 5:01 PM
    Azblue
    The Dirty T ( ^_^)_且
    Nice. I personally hate flux core, but it is the perfect thing for use outdoors in the wind.
