Loose gear shift
Discussion in '1st Gen Tundras (2000-2006)' started by dwlacy, Mar 18, 2023.
  1. Mar 20, 2023 at 11:38 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Weird...we have the same year, but the gauges are clearly different. Either it's a mid-year change, or...2004 DCs are truly unicorns!
    (My mfg date is 03/04)
    Apologies to OP for hijacking the thread.
    BubbaW[QUOTED] likes this.
  2. Mar 20, 2023 at 11:48 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    What might be even weider is, that is your gauge that I simply added the 9 and white marks :eek::D
    w666[QUOTED] and shifty` like this.
  3. Mar 20, 2023 at 11:54 AM
    Time to replace that 'D' LED or bulb.
  4. Mar 20, 2023 at 12:00 PM
    w666
    Maryland
    You know, it's the damnedest thing...I DID replace the "D" light (and several others as well) The "D" light remained dim, even with the new bulb. I took it out and removed the green condom, yet still the same result. My theory is that since the "D" light is illuminated the preponderance of the time, and it is incandescent, that the heat has permanently yellowed the plastic. That's my story, and I'm sticking to it! (It still pisses me off every time a look at it)
  5. Mar 20, 2023 at 12:09 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Here's another example to further derail this thread. Bottom right corner you can see my volt gauge wired directly to the battery. The refresh rate of the display makes it impossible to photograph all the digits fully lit but it's reading 14.61 here at idle after a 20 minute drive. I, too, have an '04 DC but using a Ford diode and an AC Delco gold 94R AGM.
    w666 likes this.
  6. Mar 20, 2023 at 12:56 PM
    dwlacy
    dwlacy [OP] New Member
    don
    oklahoma
    06 v8 2wd maroon tundra dc
    no cats....
    @Shifty guy at the shop that does bg flushes gave me a $75 quote to flush the engine & change the oil.....but, doesn't recommend doing it unless their are serious issues with the engine....might cause more harm then good....so, I guess the next step is to pull off the valves covers & see what they look like.....the gaskets need replaced anyway.....if not too sludged up, I might consider doing it.....toyota recommends one at 90,000, if I remember correctly, and this truck has probably never had one....
    shifty` likes this.
  7. Mar 20, 2023 at 1:06 PM
    shifty` All my rowdy friends have settled down
    Sometimes the gaskets don't need replacing.
    A lot of times what guys on here have found is that, with time, the bolts lose their torque, or maybe the rubber washer on the fastener compresses, and they simply need a tightening.
    But if you do choose to go that route, here's everything you need, along with instructions, part numbers, process, etc.: https://www.tundras.com/threads/valve-covers-fix-or-leave.105385/#post-2712883
  8. Mar 23, 2023 at 1:08 PM
    dwlacy
    don
    oklahoma
    no cats....
    @Shifty update....finally got a nice day to work on the truck....but now it's trying to rain....pics of things as I take it apart.....no cracks in the timing belt, but it looks pretty worn, time for a new one....your thoughts?right side.jpg left side.jpg
  9. Mar 25, 2023 at 1:48 PM
    dwlacy
    don
    oklahoma
    no cats....
    @Shifty got the right side valve cover off.....not to bad, nothing that mmo at every oil change won't be able to take care of....gaskets are a little hard....I'll change them as soon as I can get some new ones....IMG_20230325_151632.jpg
  10. Mar 25, 2023 at 4:55 PM
    Yup. Definitely a little burnt. Driver's side will definitely look 2x as bad.
