Fog lights not fitting on my 2002 single cab tundra. Need some advice, have pictures.
Discussion in '1st Gen Tundras (2000-2006)' started by southerndude03, Mar 23, 2023.
  1. Mar 23, 2023 at 8:23 AM
    southerndude03
    southerndude03 [OP] New Member
    2002 single cab 2wd v6 tundra
    So I bought the tyc fog lamp assemblies since I have the wiring present for them, I also got the relay and sourced an original fog lamp switch from a parted out vehicle. All that works.
    The lamp assembly to bolt hole doesn’t line up on the top hole of the bumpe. Could this be because I need a new bumper support and bumper or is the part the wrong fit?
    I could get a small piece of 1/8” thick flat steel and make an adapter for the top support I guess.
  2. Mar 23, 2023 at 9:20 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  3. Mar 23, 2023 at 9:25 AM
    You’ve got the right part. I think the post you’re looking for is on the bracket that attaches to the bumper. I remember being puzzled during my assembly as well.
    F3AC347A-680E-41B7-9F3C-CC14AC9FD67F.jpg AB6C0A42-DCDD-47C1-96CF-DF4FEAD36BCD.jpg
  4. Mar 23, 2023 at 9:37 AM
    This is the post you seek
    w666 likes this.
  5. Mar 23, 2023 at 9:40 AM
    And that folks, is how you do double entendres
    shifty` and Mustanley like this.
  6. Mar 23, 2023 at 10:12 AM
    southerndude03
    I have that. It’s what the bumper is going to attach to. I believe it’s going to go through the hole on the bumper that the top hole of the fog lamp is near but not on. I had a hit a deer in it years ago and messed up the front bumper. Maybe this bumper isn’t to oem spec on that post. The bumper mount that the bumper mounts to looks newer than 2002
  7. Mar 23, 2023 at 10:14 AM
    Mount the brackets to the bumper first. Then mount the fog lights.
  8. Mar 23, 2023 at 10:46 AM
    southerndude03
    Well I guess I removed the bumper the hardest way possible with how I did it then.
    KNABORES[QUOTED] likes this.
  9. Mar 23, 2023 at 11:14 AM
    That's the awesome part about mistakes: After you make one, you probably won't do it again. Furthermore, if you post about it on a forum like this and someone else on here reads it, they learn about the mistake and might recall how to avoid it. You just made us collectively smarter by sharing your fuckup. THANKS! :rofl:
    Bad Jackson likes this.
  10. Mar 23, 2023 at 11:29 AM
    southerndude03
    So I feel really dumb now. I took that part off, and of course it all fits perfectly. The hole on the bumper was so close that I thought they fit together.
    shifty`[QUOTED] and KNABORES like this.
  11. Mar 23, 2023 at 11:35 AM
    Don’t feel dumb. You recognized the need to reach out and did so. Your bumper and new lights will be assembled correctly. That’s a win. I’ve been stumped numerous times and needed another set of eyes or someone wiser than myself to get me to the finish line on a project. Never stop learning.
    Mustanley and shifty` like this.
  12. Mar 23, 2023 at 12:03 PM
    Meh, if you're serious, consider changing your words: You feel enlightened with a sense of clarity. You can't gain knowledge you already have, so instead of feeling like you should've magically held this knowledge about a topic you've likely never dealt with before, recognize you were simply ignorant of something before, and now you're wiser.
    People have somehow managed to pervert the term 'ignorant' in the last few decades to mean "stupid" instead of "not knowing about". It's OK to be ignorant. Ignorant doesn't equal* "stupid", it equals* "ripe for learning". Knowledge on this topic is shared today to enlighten you. Now we're all smarter, less ignorant. Now is time for you to feel enlightened, learned, not "dumb"
    Win-win. Glad you got it together.
    Bad Jackson, Mustanley and KNABORES like this.
  13. Mar 23, 2023 at 2:06 PM
    southerndude03
    [​IMG]I’m very happy with the result. The grey bumper paint had flaked flakes off and also rusted in places. I sanded it, put phosphoric acid based rust remover on the rust, sanded, and finally used 1.5 large cans of rustoleum spray on Bedliner. I took a torch to the plastics to remove its fading. I put new grommets under the cowl and siliconed them in as well. I did have to cut the cowl a small amount to make the Ravi ditch light brackets fit (this is normal)
    I’ve had this truck a couple of months shy of 20 years now and I love it.
    shifty` and KNABORES like this.
  14. Mar 23, 2023 at 2:07 PM
    Great job sir
  15. Mar 23, 2023 at 3:19 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
  16. Mar 23, 2023 at 4:52 PM
    w666 likes this.
  17. Mar 23, 2023 at 4:58 PM
    NickB_01TRD
    KY
    Every time I start to do it there's a chance of rain next day. Would really like to give it a bit of time to soak in.
