  1. Mar 21, 2023 at 10:46 PM
    #2671
    TheCrazyludwig
    TheCrazyludwig New Member
    Added to my diamondback. I cannot speak fondly enough on how much I love this setup.
  2. Mar 22, 2023 at 2:38 PM
    #2672
    Tibetan Nomad
    Tibetan Nomad New Member
    What bolt is this? What kinda bit key do i need to loosen it if needed?
    installed with CAT shield.
  3. Mar 22, 2023 at 3:55 PM
    #2673
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Black AFE tow hooks. Got my baja designs behind the bumper light bar but waiting on the pro light bar replacement to rip off the front end. Not wanting to do it twice.
    Tibetan Nomad and Baja Designs like this.
  4. Mar 22, 2023 at 4:56 PM
    #2674
    Pepticgnome
    Pepticgnome New Member
    It’s a security torx bit you’ll need to remove that bolt.
    Tibetan Nomad[QUOTED] and Yaboy like this.
  5. Mar 23, 2023 at 3:53 AM
    #2675
    mlive
    mlive New Member
    South Central, PA
    2023 Tundra DC 6.5
    Mine does the same thing. I noticed it yesterday morning, almost fluctuated up and down with the RPMs until the truck warmed up. Super weird, not sure if that is normal but I can't say I have ever seen any other vehicle do that before.
  6. Mar 23, 2023 at 5:03 AM
    #2676
    scruyu
    scruyu New Member
    How you wired the light bar (3 - white, blue, & black wires) to CR switch(5 - yellow, red, white, green, & back wires)? any diagram? Thanks
  7. Mar 23, 2023 at 5:06 AM
    #2677
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    I have an 05 Sequoia that has the same fluctuation in oil pressure for 278,000 miles. I think it is just how Toyota designs it.
    nodak67 likes this.
  8. Mar 23, 2023 at 5:16 AM
    #2678
    nodak67
    nodak67 New Member
    JR
    i hope that afe tow point has more than 1 mounting screw holding it in place[\s] :)
    never mind i went to the afe website and looked at the design.
    edit : too bad the video they used shows an aftermarket bumper. probably didnt want to show how its touchy with the oem bumper.
    Tibetan Nomad likes this.
  9. Mar 23, 2023 at 6:06 AM
    #2679
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah and what's up with the ammeter that goes up to 19v lol
  10. Mar 23, 2023 at 7:07 AM
    #2680
    pawner
    pawner New Member
    Chattanooga, TN
    2022 Tundra Limited with Leer 100XR
    did you get those trim pieces wrapped?
  11. Mar 23, 2023 at 7:20 AM
    #2681
    nodak67
    nodak67 New Member
    JR
    i am guessing so the needle sits in the middle when at normal charge and doesnt fluctuate as much with a broader range from low to high.
    personally i would prefer a digital readout instead of a needle.
  12. Mar 23, 2023 at 8:15 AM
    #2682
    Tibetan Nomad
    Thank you. Turned out to be a T40 security Torx and thankfully a set I have in the garage had this...Finally paid off buying a damn set several years ago to use one or two bit. :yes:
    Henry1jg and gj953 like this.
  13. Mar 23, 2023 at 9:45 AM
    #2683
    Tundra9271
    Tundra9271 New Member
    2023 Tundra SR5 4x4 DC Lunar Rock TRD Sport
    Installed Talons Garage cat shield!
    running boards/sliders will be next, followed by Marathon seat covers.
    eddiefromcali likes this.
  14. Mar 23, 2023 at 10:40 AM
    #2684
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Not used go seeing a 12v system have a 19v max on the gauge
  15. Mar 23, 2023 at 10:43 AM
    #2685
    nodak67
    nodak67 New Member
    JR
    true but if you check a 12v battery its usually sitting above 12v on the charge. when i had the drone mobile on the 2018 tundra, it would show the charge on the battery in the 13.3-13.5 range while running and down to 11.7 sitting outside at times.
  16. Mar 23, 2023 at 10:52 AM
    #2686
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep I am aware. My 2016 does that. It does not have a 19v ammeter though :rofl:
  17. Mar 23, 2023 at 10:52 AM
    #2687
    urmomspad
    urmomspad New Member
    SoCali
    23 Tundra TRD OR
    Adventure ready!! I’m really digging the clean look of the sliders.
  18. Mar 23, 2023 at 10:53 AM
    #2688
    nodak67
    nodak67 New Member
    JR
    my 2018 platinum did
  19. Mar 23, 2023 at 10:55 AM
    #2689
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Interesting.
  20. Mar 23, 2023 at 10:57 AM
    #2690
    nodak67
    nodak67 New Member
    JR
    even the lower trims on 18+ had the 9-19v gauge. i think they change the dash on 18 and up to show the gauge.
    google 18+ tundra dash images and compare to the previous years. the gauge was just above the fuel gauge.
  21. Mar 23, 2023 at 11:04 AM
    #2691
    nodak67
    nodak67 New Member
    JR
    2017 was the last year they didnt have the gauge. 2018 and on they added it.
    1st pic is a 2017
    2nd pic is a lower trim 2018
    3rd pic is a higher trim 2018
  22. Mar 23, 2023 at 11:15 AM
    #2692
    Townwilder
    Townwilder New Member
    NY
    2021 Tundra Platinum MBM
    Just put deposit on my 2023 Plat! You have a link for the chrome badge delete? Want this for when I pick up mine!
  23. Mar 23, 2023 at 11:24 AM
    #2693
    Townwilder
    NY
    mbishop13[QUOTED] likes this.
  24. Mar 23, 2023 at 12:48 PM
    #2694
    Pepticgnome
    Just added the cbi full skid plate and heritage grill to my tundra. Next will be lights in the grille and bumper.
    ChiefG, eddiefromcali, Yaboy and 2 others like this.
  25. Mar 24, 2023 at 3:28 PM
    #2695
    eddiefromcali
    Eddie
    100% Stock
    Picked up some TRD Pro wheels n tires. I'm gonna need a custom plate soon. WANBPRO, FAUXPRO, NOTAPRO?
  26. Mar 24, 2023 at 3:46 PM
    #2696
    Simplyfresh83
    Simplyfresh83 New Member
    2022 TOYOTA TUNDRA SR5 TRD OFF ROAD
  27. Mar 24, 2023 at 3:54 PM
    #2697
    TheManderson
    TheManderson Former Tundra Owner
    Mark
    2022 Tundra Hybrid Limited 4x4 TRD Off Road (SOLD), 2024 Ford F350 Lariat Ultimate Tremor 6.7L HO Diesel
    What is that on you hood? I know you don't have a hybrid...
  28. Mar 24, 2023 at 3:59 PM
    #2698
    TRDWill_20
    TRDWill_20 New Member
    Will
    North Carolina
    2023 Tundra Pro
    Added some badges to the tailgate and put on the the Bak Revolver X4s. Both look great.
    Tibetan Nomad and 2020Platinum like this.
  29. Mar 24, 2023 at 4:05 PM
    #2699
    Simplyfresh83
    TRD OFF ROAD BADGE
    TheManderson[QUOTED] likes this.
  30. Mar 24, 2023 at 4:18 PM
    #2700
    TheManderson
    Mark
    Where did you find the badge? Link?
