Disabling brake lights and dash lights for night vision use
Discussion in '3rd Gen Tundras (2022+)' started by Eurodriver, Mar 23, 2023.
  1. Mar 23, 2023 at 4:24 AM
    Eurodriver
    Eurodriver [OP] New Member
    Hoping some of you with a better understanding of wiring can help me.
    I’d had a 2016 4Runner that I installed Rigid D2 IR lights on and was able to have a cut off switch for the dash lights and brake lights. The dash cluster lights need to go because they will create too much of a glare and the brake lights obviously eliminate the purpose of driving discreetly.
    I can live with the instrument cluster being on, because I’ve already cut out a piece of cardboard that fits the glass and keeps the light out of the nods but wondering if there’s a fuse or way to switch off the brake lights. If there’s a way to shut off the cluster that would be great too.
    pyrotechnic likes this.
  2. Mar 23, 2023 at 4:42 AM
    nodak67
    nodak67 New Member
    JR
    only thing i can think of is a circuit interrupt on the brake light. wire in a on/off switch in between the connector and brake light connection. lights you can just turn off on the stalk and use a 3rd party switch to turn on the IR lights.
    dash you can lower the brightness to lowest setting and install your card board shield :)
    Eurodriver[OP] likes this.
  3. Mar 23, 2023 at 4:44 AM
    nodak67
    nodak67 New Member
    JR
    other option is to install a circuit interrupt on the brake pedal actuation switch to signal brake lights to the bcm maybe?
    but that could cause issues with the brake assist module and a few other things i think.
  4. Mar 23, 2023 at 4:56 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    4 NC relays (one on the grounds at each fixture) and power them from a cab switch would be my vote.
  5. Mar 23, 2023 at 5:04 AM
    nodak67
    nodak67 New Member
    JR
    my best guess would be an interrupt at the connect on the brake light housing itself (inline adpater between the connector and the brake light housing connector). i dont think the brake lights have a canbus wire and should solve the issue with problems with the bcm and other brake pedal systems (crawl control, brake assist, abs, etc)
  6. Mar 23, 2023 at 8:27 AM
    Jriedy85
    Jriedy85 New Member
    Josh
    2022 SR5 Tundra
    I'm curious as to why you would ever need to drive with NV?
    bulldog93 and Dhust27 like this.
  7. Mar 23, 2023 at 8:29 AM
    Breathing Borla
    Northern Illinois
    hes looking for the yeti
    bulldog93 and Tripleconpanna like this.
  8. Mar 23, 2023 at 8:59 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    If you were trying to outrun the police at night it could come in handy :rofl:
    Tripleconpanna likes this.
  9. Mar 23, 2023 at 9:00 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Maybe pull a fuse or tape up the rear lights. For the dash use a cover. That’s what we do out in the field.
  10. Mar 23, 2023 at 9:21 AM
    ArticTundra
    ArticTundra New Member
    Cold
    Why WOUDLNT you want to drive with night vision?!
    BabyMoose, snivilous, Dhust27 and 6 others like this.
  11. Mar 23, 2023 at 9:16 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    My guess is he owns or frequents a large ranch, and probably hunts there as well. Very handy for predator control at night.
  12. Mar 24, 2023 at 1:10 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Cuz they would never think about using that kind of technology :spy:
    Especially in a helicopter...
    but wait, I flee on foot...
    and we'll still find you :D
  13. Mar 24, 2023 at 6:08 AM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    I run a couple of donkeys with my cattle herds. The donkeys will chase the coyotes down & kick the crap out of any coyote that enters the pastures. I have found the donkeys are the best form of predator control I can get.
    grizzy86, Tripleconpanna and jgoliath like this.
  14. Mar 24, 2023 at 6:12 AM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    My East coast brain can’t comprehend the idea of a donkey chasing down a coyote and putting its boot up the coyotes ass.
  15. Mar 24, 2023 at 6:33 AM
    RCwyoming
    RC
    The donkeys are not pets & they tend to be territorial. When the farrier shows up to take care of the grandkids’ horses, the donkeys get their hooves ‘adjusted’ too. Running donkeys with the livestock is something my great-great-grandfather swore by & we’ve continued the tradition. I know we share our summer pastures with bobcats & the occasional mountain lion but we’ve never lost a calf, heifer or steer to one of those predators & I have to assume it’s because of the donkeys. I have had a few stupid hunters take shots at a couple of my steers & that’s never pleasant to deal with. My biggest concern is modern-day rustlers.
  16. Mar 24, 2023 at 7:25 AM
    FloridaMan80
    FloridaMan80 New Member
    I got sucked into a donkey-knowledge rabbit hole a few years ago and it blew my mind. They seem to hate coyotes/wolves/hyenas by instinct and will aggressively go after them if they're around. They kick, bite, and thrash them to death.
    I wouldn't go near a donkey now unless it was confirmed to be domestic. They're legit badasses
  17. Mar 24, 2023 at 7:49 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You could try removing the STOP fuse and see what all that effects.
    Although it may also be needed for other system circuits..
  18. Mar 24, 2023 at 8:59 AM
    SwitchThrottle
    I just got sucked into a donkey-knowledge rabbit hole...
  19. Mar 24, 2023 at 10:00 AM
    Jriedy85
    Jriedy85 New Member
    Josh
    2022 SR5 Tundra
    Lol. Don't get me wrong. I would enjoy it. I was just curious. I've never had to drive with NV but I don't do any predator hunting.
  20. Apr 7, 2023 at 7:08 PM
    RadioNerd
    RadioNerd New Member
    West Central TN
    2023 Black Tundra Limited
    Driving under NV is just plain fun. It's a whole new world. (Inset Aladdin song here)
    Has anyone found a solution for this yet? I'm throwing around the idea of tapping NC relays into the light circuits at the fuse box.
    Just wondering if a simpler solution is out there.
    Dhust27 likes this.
  21. Apr 7, 2023 at 9:14 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Funny you say this, I wasn't raised on a farm but not a "city slicker" either, lol. When we moved to Tn a few years ago, a farm near us has 2 donkeys with the cows and we were dumbfounded until we Googled it. It's pretty amazing, they are never far from the cows, no matter what part of the pasture they are in.
  22. Apr 7, 2023 at 9:17 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I'm not into hunting, but understand your purpose. As I'm looking at the badass photos, jealous of your gear, I read the comment of not outweighing the costs, made me laugh. Not to side track the thread, but what NODS and rifle optics you running?
  23. Apr 7, 2023 at 10:48 PM
    Black widow TRD
    Manuel
    NVG action !
    RadioNerd and Tripleconpanna like this.
  24. Apr 10, 2023 at 8:35 AM
    nodak67
    nodak67 New Member
    JR
    dam drug runners :)
    /s
  25. Jul 14, 2024 at 8:17 PM
    BayAreaTruckin
    BayAreaTruckin New Member
    San Francisco, CA
    Following this - I also want to drive under NV, any solutions to this?
  26. Mar 7, 2025 at 1:53 PM
    radar x50
    radar x50 New Member
    2023 Tundra Platinum
    bump...any blackout options yet?
  27. Mar 7, 2025 at 4:19 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Retired...finally likes this.
  28. Mar 7, 2025 at 4:51 PM
    BayAreaTruckin
    San Francisco, CA
    I ran deep down this rabbit hole. Decided that I didn't want to hack up the wiring harness - easiest solution was duct tape over removable lense covers
  29. Mar 7, 2025 at 9:08 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Yeah right, every poacher's dream, don't ask how I know
  30. Mar 8, 2025 at 3:59 PM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    Looks like TEMU night vision
