  1. Mar 22, 2023 at 9:06 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I had a cb headset when we went to little sahara in OK. All my great aunts crew ran cb.
    67E678F2-C832-4BAC-852C-DAB8AC741D44.jpg 96542733-4380-4890-AC0E-A268DF2CF9AB.jpg
    My mom got me facebook blocked from that side of the family, so i dont have access to the better pics of me.
  2. Mar 22, 2023 at 9:09 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    That's why GMRS is becoming popular on the trails here
  3. Mar 22, 2023 at 9:19 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    That's annoying.
    Most people don't understand caster anyways.
  4. Mar 22, 2023 at 9:55 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    when i was in auto tech i had an alignment rack where you parked on ball bearing pads to make the adjustments easier, but with a fancy scale and a couple fast food trays you can do it at home.
  5. Mar 22, 2023 at 10:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Can ya give us a write up on this? :) Looks guuud!
    Shiiiit, say less.... "NoVeLtY" :duh:
    Yeah, I'll take a peek at it. You want anything for that stuff if you're willing to part with the receiver too?
    You tryna sell that Mr. C-Bee?
    Looks like the "UHF" radios on Scamazon are right about the same price point I was looking at for CBs... Needs more research.
    Now more research. GAH! LOL
    txagg and RUSTYNUTS like this.
  6. Mar 22, 2023 at 10:42 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    The programming is the problem. Usually costs a decent bit for someone to program. The name brand units anyway.
    This is the unit. LINK
    Will receive but not picking up voice when using the mic. Think the mic is just bad.
  7. Mar 22, 2023 at 10:49 PM
    DJenerated
    Dija
    The Lone Star State
    I had the same issue with my radiodacity gmrs
  8. Mar 22, 2023 at 11:36 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Ordered Bi-Led projectors from Ghina. Should be in in a week or so. I hardly drive ye olden Tundra but when I do and its late enough I need the headlights, the pathetic output of the LED bulbs in Chinesium chrome headlights just pisses me off. LOL. No sir, not good enough. I will bake them bitches open and throw the projectors in there soon enough. Love me some projector output width and cut off. Might even throw some switchback rings on there this time to act as DRL/turn signals. Meh.
    shifty`, bmf4069, txagg and 1 other person like this.
  9. Mar 23, 2023 at 2:16 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    When asked "how are you?" I typically respond "I'm doing fine...I don't have any problems that can't be solved with money". A broken bolt, however, seems to violate that paradigm. Your situation looks easy, just drill and tap. Coil packs can easily be solved with money. I bought 4 new ones last year (Denso @ $55/ea), and now that I've had eyes on the 4 I thought were good enough to keep I've decided to get 4 more. Good luck! When you look at it with fresh eyes in the morning you'll see that you complex problem is just a series of small, manageable steps.
    https://www.rockauto.com/en/moreinfo.php?pk=2140934&cc=1426935&pt=7060&jsn=470
  10. Mar 23, 2023 at 2:34 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    You may call it a rabbithole. I call it a neverending headache.
    On my last truck, I had mounted 3 (7"?) HID's on the bumper, and they were awesome. Made night into day. They were the red ring sealed offroad units, with the ballast inside. Anyways, liked em so much that I bought the kit for the headlights, and they were bright enough, but always having problems. First of all, you can't focus/aim them properly in OEM fixtures, there is no cutoff, and you're always blinding oncoming traffic. Besides that, they failed often. I bought several replacement bulbs, ballasts, and even a 2nd complete kit at one point. I'd just about guarantee it's one of those finicky ass ballasts. Also, alot of those ballasts won't even fire if it's not getting at least 12V. Put the entire kit in the trash can and you'll thank me later. Don't start tearing up your truck wiring/fusebox.
    Projector bulbs work nice without having to open the housings.. I do like the rings tho
    https://www.amazon.com/gp/product/B08DFRJ77T?ie=UTF8&th=1
    tacoguybill and txagg like this.
  11. Mar 23, 2023 at 3:08 AM
    artsr2002
    'Yonder
    Yeah I grabbed a set of those little projectors to install in some factory fogs. The cut off is decent, but the spread is not very wide. I just need to rotate them so they will be nice and horizontally level when installed and not all jacked at a crazy angle up due to how the stock 9006 bulbs sit in the housings.
  12. Mar 23, 2023 at 4:21 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Appreciate the mangler shout out shift! I had two on the VC job, same one on each side. If this happens to anyone else, go straight to drilling them out. I wasted a ton of time involving a map torch, welder, etc. None of it worked and had to drill them out. Those bolts are made of veal.
  13. Mar 23, 2023 at 5:39 AM
    I would at least keep a spare in the truck. If one fails your truck can also go into limp mode as another member experienced.
    txagg and tacoguybill[QUOTED] like this.
  14. Mar 23, 2023 at 6:07 AM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    I considered doing a write up but I don’t want to relive the experience.
    bmf4069, NUDRAT and Tundra2[QUOTED] like this.
  15. Mar 23, 2023 at 6:48 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well, there was a damn "deer" on tooley hill this AM going home. Like I said, we're real guuuud at cheatin death.
    Big drop off on the right hand side of the road where I was heading until I seen the "deer" on the left hand side and steered towards em trying to get em..... in my dreams.
    Anyways, I could have went off in the drop off and hit the big patch of oak tress about 50 feet down at 30° embankment...
    Here goes these pictures! Them brakes work REAL GUUD had the whole bitch locked up too! Standing on the rectangle!!!
    This tree I bumped helped me out of this predicament.
    I was in 2WD when all this happened. I put the truck in reverse and spun them tarrrs. Stopped, put light pressure on the skinny pedal and got them tarrs spinning again, popped it into 4WD and was on my way home in 2.5 seconds.
    Here's pictures of crackie at home.
    Apparently crackie said FUCK the government this year :rofl:
    oscardog86, txagg and tacoguybill like this.
  16. Mar 23, 2023 at 6:51 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Did you keep the sign?
    Bummer about the bumper, kudos for not dying.
    NUDRAT likes this.
  17. Mar 23, 2023 at 6:54 AM
    Dang man. Right when you get doors, now you gotta add a fender to the WTB list. :rofl:
    Glad you're alright, sucks you're buying a new bumper now. Structurally, everything look ok?
    txagg likes this.
  18. Mar 23, 2023 at 7:06 AM
    Damn dude. What up with all these deer jumping in front of trucks in KY? You need some serious battering ram to protect your truck from damage.
    Tundra2 and DJenerated like this.
  19. Mar 23, 2023 at 7:10 AM
    tacoguybill
    tacoguybill The Burrito Bandido
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    you guys should keep all the road trophy's you've been getting lately, just tell the county you paid for it
    glad you're good and hope its only the bumper, you guys sure do have some bad luck with hitting things lol, I just randomly looked and was surprised that there are 18 first gen tundras in the boneyard not 10 minutes from my house....as soon as I get the truck back together the game will be afoot to find some leather seats in decent shape.
    txagg likes this.
  20. Mar 23, 2023 at 7:20 AM
    I'm confused. There was no deer? Did you fall asleep?
    Jack McCarthy and DJenerated like this.
  21. Mar 23, 2023 at 8:13 AM
    DJenerated
    Dija
    The Lone Star State
    So you fell asleep? That sucks. I've had several close calls with that. Glad your OK. Nows a good excuse for a heavier duty bumper
  22. Mar 23, 2023 at 8:25 AM
  23. Mar 23, 2023 at 9:09 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Taco bumpers can be forced to fit, eh?
    Jack McCarthy likes this.
  24. Mar 23, 2023 at 9:17 AM
    danmurphymn
    danmurphymn New Member
    Minneapolis, MN
    Black 2004 DC TRD
    Grr,
    I just replaced my driver door with a used one. While I was in there, I upgraded my speakers. (cut & spliced the speaker wire).
    Now my power locks only lock, not unlock. Any idea what happened or what could be wrong?
  25. Mar 23, 2023 at 9:18 AM
    Damn man, glad you’re ok. If it weren’t for bad luck right? I have a brand new in the wrapper crash bar for the front bumper if you need it. Hit me up. I got it with my new front bumper and didn’t end up needing it.
    p.s. it’s free.99 and I’ll meet you halfway if you need it.
  26. Mar 23, 2023 at 9:40 AM
    Crackie needs the full brush guard option from BFF.
    mcharfauros, bmf4069, lsaami and 5 others like this.
  27. Mar 23, 2023 at 9:42 AM
    No sense in half assing it. Full cow catcher is needed for this application.
    bmf4069, tacoguybill, shifty` and 3 others like this.
  28. Mar 23, 2023 at 9:47 AM
    I was thinking sharp 1 foot spikes on an integrated brush guard steel bumper, but that works as well. Visibility isn’t great though.
  29. Mar 23, 2023 at 9:47 AM
    You don’t have to see what’s ahead of you with a bumper like that.
    bmf4069, NUDRAT, Mr.bee and 1 other person like this.
  30. Mar 23, 2023 at 9:48 AM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    They worked grear for about a year and a half before the Passenger one quit. Grabbed new bulbs/ballasts thinking i just killed one but that wasnt the issue and have been chasing it since. I do have Southpaw Retros so cutoff and everything was great. Also make it hard to just swap back to a standard bulb or i would have already tried that just to have lights again.
