  1. Mar 22, 2023 at 3:39 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    It already is 130, but I'm going to install yours
  2. Mar 22, 2023 at 4:11 PM
    daveeasa
    I mean, if you order the master tailgater thingy to me I can prep it for ya. No problem. I know exactly what needs to be done but didn't really figure it out till I got mine on the truck. I can use the same exact connector my 3rd gen Tacoma uses. Seriously no trouble at all.
    I prep'd mine a bit off the truck, extended power and ground with 18 gauge so I could do the vga and power / ground in the cab rather than ground it locally and source power elsewhere.
    Anyways, pretty straightforward as far as I see it, just slacker me didn't get it done.
    I didn't drill at all, used the spare tire slot for cables.
    shifty`[QUOTED] likes this.
  3. Mar 22, 2023 at 4:16 PM
    Oh snap, I totally forgot you got that!
  4. Mar 22, 2023 at 4:46 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Snorkel!
    Took me roughly 5 hours to do. Spent a ton of time just staring at it, and a good amount of time cutting. I botched the initial hole in the fender and put it too low :(. Luckily if I ever want to redo it, I have a brand new fender in storage that just needs paint.
    Big thanks to Shane Hoeckel for the custom snorkel adapter for the air box.
    oscardog86, NUDRAT, bmf4069 and 7 others like this.
  5. Mar 22, 2023 at 5:05 PM
    What snorkel did ya buy?
  6. Mar 22, 2023 at 5:08 PM
    I was gonna ask the same.
    My sequoia buddy said he heat gunned his to get it closer to the A pillar
    oscardog86 and DJenerated like this.
  7. Mar 22, 2023 at 5:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  8. Mar 22, 2023 at 5:29 PM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    I have a snorkel still in the box that I eventually plan on installing and doing just that as well
    The Black Mamba and NUDRAT like this.
  9. Mar 22, 2023 at 5:39 PM
    I can’t tell what that 12 year old boy was saying, but he definitely failed to utilize the ASSets around him during that video. Perhaps for legal reasons.
    NUDRAT, shifty` and Tundra2[QUOTED] like this.
  10. Mar 22, 2023 at 5:50 PM
    tacoguybill
    tacoguybill The Burrito Bandido
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    @w666 well hopefully I don’t have to go as far as you, I snapped one of the 6 camshaft cover bolts it’s the one that’s supposed to be torqued to 66in lb and I forgot to change my torque wrench from 12 Ft lb that the rest of the camshaft caps are torqued to….I do have a couple threads showing from the bottom though so I may try to get some pliers on it and keep turning it…it also has 4 other bolts that are torqued to 12ft lb and the other little one….we’ll see how it goes.
    I did get the drivers side cam cover on ok with no issues…. Until I went to reinstall my valve covers….apparently putting things back how you found them has led me astray. The last Jackwagon that installed my valve covers put the plug seals in upside down. And managed to get them over the spark plug tubes….how I don’t know but 31$ later and autozone next day delivery and I should have new plug seals tomorrow. Pics for reference. B63197E1-C312-450F-8FA2-814C4BF15ECC.jpg
    so naturally I installed them the same way…and couldn’t get the VCs back on…shit was bookoo dinky dau. Thinking I was being smart I decided to see if a coil pack would spread the seal out just wide enough to let it slide over the tube. I then noticed that the plastic housing on the coil pack was cracked. So I check the others. 6 total packs are cracked. 663B5EC7-379F-4673-A36B-1019E66CBE38.jpg
    Today was fun. I called it a night and came back in to hang out with the fam :rofl:
  11. Mar 22, 2023 at 5:51 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    So yall know I've been kicking the idea of a CB around for a minute mainly for the PA function of it, but I was talking to pops about it. I learned a lot from the old man. Lot of family history I didn't know.
    He said "Follow me, I think I've still got my CBs from the old Ford way back in the day."
    Naturally, I perked up and followed pops. He opens this filing cabinet and out come two midland transceivers from the early 90s. Basic units. Nothing fancy. 40 channels each. One unit is just the in cab box. The other one is legit, RTU. I set that dude up faster than you can choke a chicken and I know some of yall are PRO-FESH-E-NOWLS at that. Been laying in crackies passengers seat for the last couple days. I thumb through them channels once or twice a drive with the squelch turned all the way down to hear err-thang.
    I pick up a lot of overlap on the superbowl channels. Hard to make out individuals at times. Most of the time it's dead as a door nail on the other 38 channels, but I like the idea of this a lot.
    Anyways, here's pop's antenna fir your viewing pleasure.
    Yall got any funny antenna toppers saved in them nuggets, post up a link. I'll put whatever one YALL want on crackie. I think this is hilarious
  12. Mar 22, 2023 at 5:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I don't CARE what he was saying TBH wilin
  13. Mar 22, 2023 at 5:53 PM
    Man that's a bummer. How many miles on those? Mine are original at 182k and I'm wondering if I should replace mine soon.
  14. Mar 22, 2023 at 5:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  15. Mar 22, 2023 at 5:55 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    This one. https://www.ebay.com/itm/363611164374
    Surprisingly good for the price. My only real complaint is mine has a QC issue with a pinhole at the rear seam about halfway up the tube. I'll probably plastic weld a patch onto it. Oh, and I guess the studs are quite short, I ended up backing all the studs most of the way out just so I had enough threads to get the nuts started on, then I cranked it all down.
    I tried the heat gun trick with "meh" success. I may give it another shot some other time. It seems ok for now.
  16. Mar 22, 2023 at 5:58 PM
    RUSTYNUTS and Tundra2[QUOTED] like this.
  17. Mar 22, 2023 at 5:59 PM
    tacoguybill
    Saaaan Diaaago
    163,40X lol this is the worst one single crack but the rest have multiple smaller cracks. I’m assuming the higher temps from its early life in south Texas are a contributing factor. I had no issues with them thus far so I doubt they’re all the way bad yet but I also don’t want to risk them failing unexpectedly. Would you replace all 8 or only the 6 that are showing damage?
    w666 likes this.
  18. Mar 22, 2023 at 5:59 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    RUSTYNUTS and tacoguybill like this.
  19. Mar 22, 2023 at 6:03 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    I wish CB was still active in my area. Everyone is pretty much on HAM now.
    Tundra2[QUOTED] and FrenchToasty like this.
  20. Mar 22, 2023 at 6:07 PM
    I'd probably just do all 8. $54.79 a pop on Rock Auto for Denso. Someone posted a 5% off coupon earlier.
  21. Mar 22, 2023 at 6:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well, just means that this is easier to use for what I want for road tripping and such. I'll leave thus set up intact. Clean up some of the connectors and wiring, etc and this can be thrown in pops sequioa before a road trip. I'll hard mount a CB in my truck, my car and my girls car.
    She used to play CB tag with friends in high-school in the early 2010s. She knows her way around a knob for sure!!!
    Anyways, cb being dead here is PERFECT for us.
  22. Mar 22, 2023 at 6:35 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Went back at diagnosing why my Passenger Headlight wasnt working, got nowhere and now my driver is out too after f-ing with it all.
    Fuses are good, relay is clicking fine (even swapped with known good one from other rig), just replaced the headlight switch trying to solve few weeks ago. Old and new ballast/bulbs/igniters have all been swapped to the different configurations as possible. Yet still i got no lights. Even pulled the fuse box apart to check for bad wires (thats a bitch btw) and everything looks good.
    Power at the fuses, power at the relay, im at a loss. Whys this system gotta be so damn complicated. Anyone else been this far down rabbit hole with HID headlights?
    Tundra2 likes this.
  23. Mar 22, 2023 at 6:44 PM
    If they're not misfiring I wouldn't replace them, unless you've got the coin laying around.
    If they're misfiring, you should know.
  24. Mar 22, 2023 at 8:16 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Tennis ball or gtfo
    NUDRAT, shifty`, txagg and 2 others like this.
  25. Mar 22, 2023 at 8:18 PM
    I would think a ground issue if all the power sources check out.
  26. Mar 22, 2023 at 8:38 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I just put a CB in my side by side the other day. Never really felt like it would have much use in a vehicle. I guess to talk to truckers while you're on the highway or something. May have an antenna for you when you come to get your stuff if you're interested/planning to install in more vehicles. I've also got a CB that I believe just needs a new mic.
    Tundra2[QUOTED] likes this.
  27. Mar 22, 2023 at 8:44 PM
    Siebler
    CJ
    Eastern Oregon
    Thats kind of where ive lead myself to as well. The thing thats throwing me is that the Drivers light was working fine until today and then suddenly just went dead while chasing the passenger issue, right when i was about done for the day too.
    Rainy tomorrow and im supposed to go into town and would be driving home the 45 miles of winding canyon roads in the dark so hopefully i can trace it down and still make the trek.
  28. Mar 22, 2023 at 8:54 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i've got a cobra 25 i've wanted to mount, but flashing lights communicates with trucks so much better, most arent listening anyway, but apparently nobody uses cb channels on trails anymore.
    NUDRAT, Tundra2[QUOTED] and alb1k like this.
  29. Mar 22, 2023 at 8:54 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Working on this bed rack. My current setup is 45” and heading to 62”. Not quite done with these uprights, but the hardest part is over. Yew.
    oscardog86, shifty`, bmf4069 and 6 others like this.
  30. Mar 22, 2023 at 8:56 PM
    NickB_01TRD
    KY
    My buddies and I use CB when we go out in side by sides. Think a lot of people use UHF stuff now days. I don't blame them either. If we get too split up we can't contact each other.
    Tundra2 and DJenerated like this.
