Toyota Tundra Instrument Cluster Issue delay stuttering needles upon startup
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra Enthusiast 5.7L V8, Mar 21, 2023.
  1. Mar 21, 2023 at 7:07 PM
    Tundra Enthusiast 5.7L V8 [OP] New Member
    Jeffrey
    2019 Tundra Limited 4x4, 2016 Tundra 1794
    I have a Toyota Tundra Platinum, yesterday I’ve been having issues with my cluster delaying the needles and the RPM and Speedometer needles seem to freak out and stutter. I already disconnected the battery with no fix. Ever since this happened, the truck resets MPG and data, it acts like I disconnect the battery when I remove the key and the anti theft light does not blink when I remove the key. Also when I remove the key, the needle positions do not go down, they get stuck in the same position until you insert the key again. I posted a video on YouTube so you can see the needles delaying on startup. Also you can see in the video that the RPM and speedo needles freak out for a bit. I also started up the truck as well so you can see it also delays as well. Any help is appreciated
    https://youtu.be/DDdS7ZL-V5Q
    https://youtu.be/JlTaheAVQzc
  2. Mar 22, 2023 at 6:53 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Check the fuses, more specifically the 5A MET-B fuse in the fuse box under the driver side dash. This goes to Pin#1 on the J28 meter connection and should be 24/7 battery power.
    The cluster has two signals for power. One is a constant B+ from the battery to allow it to retain memory and keep the CPU alive, but in a sleep mode when the key is off. The second power source is an ignition power that comes into the cluster when the key is turned on. This is the signal to "wake up" the cluster for operation.
    Seems when you turn the key off your cluster is going completely dark meaning it is not getting constant B power from the battery. This will make it forget the memory data and also most likely make the needles look jumpy as they are resetting from a hard cold boot as you turn the key on.
    Its not properly booting and showing the Tundra logo at the beginning either
  3. Mar 22, 2023 at 7:21 AM
    Jeffrey
    Ok will check fuse. Thanks
  4. Mar 22, 2023 at 11:37 AM
    Jeffrey
    The 5A fuse was blown. Thanks for the solution. Everything works as expected now.D219E7C8-9BC2-4FBE-99C4-24796B5771B1.jpg
    https://youtu.be/urNFth1PXto
    Jeff_5_7[QUOTED] likes this.
