295/70/18
Discussion in 'Wheels & Tires' started by cpa357, Mar 22, 2023.
  1. Mar 22, 2023 at 6:19 AM
    cpa357
    cpa357 [OP] New Member
    Hi everyone. I know this question or one similar to it has been asked before. Wanted to start new specific thread for my build. I just bought a 2020 TRD Pro 2020 on Monday. How much modification is required to run 295/70/18s without rubbing? Can it be done with the current suspension. If not will 295/70/18s work without changes?
    Would consider changing UCAs to accommodate 295s?
    Thanks in advance.
  2. Mar 22, 2023 at 6:46 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    This might help: Search Results for Query: 295/70-18 | Toyota Tundra Forum (tundras.com)
    T-Rex266 likes this.
  3. Mar 22, 2023 at 6:58 AM
    CTundraForMe
    CTundraForMe New Member
  4. Mar 22, 2023 at 7:03 AM
    PermaFrostTRD
    Northern NY
  5. Mar 22, 2023 at 8:11 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    depending on the brand of tire, you might be able to run it without mods. The cheapest way to do it would probably be wheel spacers.
