Replaced Battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Base1216, Mar 19, 2023.
  1. Mar 19, 2023 at 9:11 PM
    Base1216
    Base1216 [OP] New Member
    2010 Toyota Tundra SR5
    Just installed a new battery on my tundra. It is running fine but the battery light is on when in idle. When I give it gas it goes away and then comes back on when idle, however the battery gage remains in place when I give it gas. Why is the light still on?
  2. Mar 19, 2023 at 10:07 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Your alternator maybe failing
  3. Mar 20, 2023 at 9:25 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Was the light on before you replaced the battery ?
  4. Mar 20, 2023 at 9:28 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    sounds like an alternator.
    Sierradevil likes this.
  5. Mar 20, 2023 at 10:07 AM
    Base1216
    Yes the light was on before I changed the battery.
  6. Mar 20, 2023 at 10:32 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Put a voltmeter on the battery as the truck is running. If it’s not reading 13+ Volts it’s not charging.
    This is the fastest way to test if it be alternator is working.
  7. Mar 21, 2023 at 9:29 AM
    CreekDweller
    CreekDweller Not so new ...
    2020 MGM 1794 TRD Off-Road
    To me, this is a sign that the battery is failing. The battery light comes on at idle because at low rpm the alternator is putting out very little current so the ammeter (the battery light) is telling you that the battery is discharging. When your rpm increases, the light goes out because the alternator is putting out more current than your truck requires to run itself (spark plugs, electronics, etc.). I'd start with a battery replacement, but you can also have the local auto supply store test the battery for you before making that decision.
  8. Mar 21, 2023 at 9:53 AM
    Rocko9999
    Rocko9999 New Member
    This.
    NewImprovedRon likes this.
  9. Mar 21, 2023 at 10:00 AM
    Base1216
    I put a brand new battery in it and it is still showing up in idle and disappears with acceleration. Took it to a shop and the voltage read 11.7.
  10. Mar 21, 2023 at 10:04 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Assuming that voltage reading was done with the truck running the alternator needs to be replaced.
  11. Mar 21, 2023 at 10:06 AM
    I've always been lucky when alternators fail...they have pretty much started on fire. No troubleshooting needed.
    The lucky part is the vehicles didn't burn to the ground.
    clarkritchie, Gravy, Jeff_5_7 and 3 others like this.
  12. Mar 21, 2023 at 10:12 AM
    Rocko9999
    So you put 2 new batteries in it? Again, go test the voltage with the truck running and report back.
  13. Mar 21, 2023 at 10:28 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    This forum is kind of crazy… the amount of new batteries bought here that are not needed is so high.
    If it’s only making 11.7v at idle, I would test it again but this time rev the engine up to 2-3k rpm. If it starts to show voltage then you alternator is starting to fail.
    It’s not charging at idle but when you rev it up, it’s spinning the alternator up enough to start kind of working. Reasons why the battery light goes off.
    Most likely will be replacing an alternator which is not exactly cheap. Buy a good quality one, not a chain auto parts store one. You don’t want to be doing this all over again in a few months to a year
  14. Mar 21, 2023 at 10:49 AM
    Rocko9999
    The trend to not diagnose and just fire up the old parts grenade is not waning. A little more diagnosis time will save you a lot of money in the future.
    I agree-do not put a cheap alternator in. Go to a reputable online dealer and get the new OEM, about $300. You don't want the headache of having to do it again, it's kind of a pain to access.
  15. Mar 21, 2023 at 12:44 PM
    eagleguy
    eagleguy New Member
    If you don't have a voltmeter your local auto store (most) can check the charging system for free. Just to double check.
    Rocko9999[QUOTED] likes this.
