2014 Tundra 5.8L - Whining/Grinding Noise on acceleration
Discussion in '2.5 Gen Tundras (2014-2021)' started by askochis, Jan 26, 2022.
  1. Jan 26, 2022 at 3:54 PM
    askochis
    askochis [OP] New Member
    Alan
    2014 TRD Limited Tundra
    Hi all!
    New member here (Hi Everyone!) with a 2014 Tundra 5.7L Limited TRD Pro - 86k miles - new to me since May last year. I've been searching around the forum and can't seem to find anyone with my issue so I thought I'd film it and see what everyone thinks!
    Long story short: every time I accelerate from a slow speed/stop there is a noticeable whine/grind coming from mid engine. You can hear it on this crappy video I made right at about 3-4 secs in (sorry for the blinker): https://youtu.be/LsW2G-e4hJU
    So for a few more things:
    - I already made an appt. with the dealer to have a looksee but they can't get me in until mid-Feb
    - Can't replicate the sound in park - Truck must be moving
    - It is consistent as of about a week ago - right between 2000-3500k RPM
    - It happens in 4Hi and 4Lo as well and if I am turning or not
    - Seems to be worse in cold weather but still happened on the warmest day here - happens with any accessory on, all accessories on, or no accessories on
    Random bits:
    - I replaced the MAF sensor and cleaned the throttle body about 6 months ago
    - Serpentine belt was replaced before I bought it and doesn't seem to be at play here
    - I rechecked all hoses, air filters, anywhere I could think for a vacuum leak but didn't find anything apparent
    Things I am thinking:
    - Clutch/radiator fan?
    - Water pump?
    - Transmission? (nightmare fuel but I honestly don't know what the folks did with it before I had it for the first 85k miles)
    Anyways, thanks for looking and for having me here in the forums! Looking forward (maybe) to everyones thoughts/ideas and will try to update when i hear back from the dealer.
  2. Jan 26, 2022 at 3:57 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Are you sure its coming from the engine bay? Do you have skid plates? Have you checked driveshafts?
  3. Jan 26, 2022 at 4:18 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Exterior weatherstripping/molding catching wind?
  4. Jan 26, 2022 at 8:36 PM
    askochis
    Alan
    No skid plates - pretty sure to almost positive its the engine bay- drive shaft and axle shafts LOOK fine but then again I don't really know - I don't have a lift or anything to really check them thoroughly. I'm not getting any shuddering/shaking/vibrations though. But come to think of it, it did start after a particularly icy day and that morning I heard a pretty loud clunk from the front passenger side wheel after going over railroad tracks. At the time I thought it was ice/snow getting caught up which maybe it did but messed with something up there? Not too sure but something to tell the dealer for sure... Thanks for the thoughts!
  5. Feb 13, 2023 at 11:21 AM
    Wduncan1983
    Wduncan1983 New Member
    2015 - Tundra 1794
    I have this same issue. Did you ever figure out what was causing yours to whine?
  6. Feb 13, 2023 at 7:06 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Does the sound oscillate with the RPMs?
  7. Feb 14, 2023 at 3:53 AM
    blanchard7684
    blanchard7684 New Member
    Air injection pump issue maybe?
    Also…check your exhaust to see if anything is loose or like an attempt was made on your cat converters.
  8. Feb 15, 2023 at 5:27 AM
    Wduncan1983
    2015 - Tundra 1794
    It's happening when I slowly accelerate from a stop. It goes away when I get on the gas and get up to speed quickly. Going to record it later today and upload so you can hear it for reference.
  9. Mar 2, 2023 at 4:07 PM
    askochis
    Alan
    I am SO SORRY - my alerts for this forum were going to JUNK - i had no idea. Hopefully you got your answer but mine was a failed clutch fan - got that fixed and my MPG went way up and no more whining sounds!
    HulkSmurf14 and texasrho83 like this.
  10. Mar 21, 2023 at 5:22 AM
    Wduncan1983
    2015 - Tundra 1794
    Sooo... I ended up having my check engine light come on and my traction control was disabled and threw the following codes. P0304, P0300, p0302, p0308. All related to cylinder misfire. This happened on a very cold morning the day after hauling my pop up camper home. In addition, I have the p1604 code that is related to an extended crank Service Bulletin https://static.nhtsa.gov/odi/tsbs/2019/MC-10170730-9999.pdf
    The dealer reprogrammed my ECM, Installed new spark plugs, and did an induction cleaning. They said that my fuel pump needed to replaced as well but the pump is on back order and they don't know when they'll get it in. After this was performed the whine that I had during acceleration was almost completely gone.
    Not sure if anyone else has this same issue but definitely nice to know the whine isn't my transmission or something worse.
  11. Mar 21, 2023 at 5:47 AM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    OP's video sounds like maybe an intake whistle to me, check to make sure all intake clamps are installed correctly and tight. Replace the screened throttle body gasket with non-screened part number. If you switch filters or intakes to something higher flowing the whistle gets even more pronounced. Switching to screenless gasket with an AFE prodry filter made my whistle quieter and across a smaller RPM band but still present under some operation conditions.
    https://www.tundras.com/threads/anyone-else-have-an-intake-whistle.6421/
    Wduncan1983 likes this.
