Fuel Tank Capacity
Discussion in '2.5 Gen Tundras (2014-2021)' started by travelertoo2, Mar 19, 2023.
  1. Mar 19, 2023 at 7:47 PM
    travelertoo2
    travelertoo2 [OP] New Member
    2020 SR Double Cab
    Everything I read says my 2020 Tundra is supposed to have a 26 gal tank. But doing the gas pump math tells me it's actually something like 20 gals. What am I not getting?
  2. Mar 19, 2023 at 7:52 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    the fact that Toyota is very conservative on the reserve capacity on these trucks. If I’m not mistaken, the reserve on my 38 gallon tank is around 8 gallons. So when I have 0 miles left means I still have 8 gallons to find a gas station, and with the mileage these trucks get it’s probably survival rather than overkill.
  3. Mar 19, 2023 at 7:54 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  4. Mar 19, 2023 at 8:28 PM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    I have the larger 38 gallon tank - however, if the 26 is the same as the 38, you'll get the yellow fuel light warning when you have 6-7 gallons remaining. If you're not towing that could mean another 80-100 miles potentially. Don't follow the miles to empty calc. It is not dynamic and just an estimate based on your past driving trends. The fuel light is to be trusted, not DTE calc.
  5. Mar 19, 2023 at 8:31 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    26 gallon tank here
    I fill up every time low fuel light comes on and it only takes 20-21 gallons. Never been able to put more than 21 in.
    It keeps a 6 gallon reserve one because people are idiots and will push it as long as possible so they added a big “buffer” and two to help keep the fuel pump submerged for cooling/ to fight overheating it
  6. Mar 20, 2023 at 5:00 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    You have a 26 gallon tank. I've never seen a vehicle that uses every gallon of fuel in the tank prior to the light coming on.
    You gave very basic information but assuming you're putting 20 gallons when your fuel light is on, then you would have a 6 gallon reserve on a 26 gallon tank. @1UP shared the link to where this topic has been abused for a long time.
  7. Mar 20, 2023 at 5:29 AM
    Garrett77
    Garrett77 New Member
    2020 Tundra 4x4 XP Predator
    I thought only Crewmax had the larger gas tank? I ran my DC down to single digits and it took 31 to fill it up. Old 2015 didn't take nearly as much.
  8. Mar 20, 2023 at 5:39 AM
    2mchfun
    Without some extra the truck would run out of gas on an incline folks, Best to fill up between 1/2 and 1/4 and stop at about 3/4 to avoid check valve and evap issues.
  9. Mar 20, 2023 at 5:51 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I feel like stopping at 3/4 is a little excessive? And how exactly are you going to measure when to stop to make sure you're only at 3/4?
    I stop when the pump stops. No extra clicks or top offs and never in my life have I had issues.
  10. Mar 20, 2023 at 5:53 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    you have to have the SR5 upgrade package to get the 38 gallon tank. An SR5 truck, like mine, does not have it unless that specific package is selected. Note that you cannot get the larger tank combined with the bench seat as the SR5 upgrade package adds the big tank and the center console.
  11. Mar 20, 2023 at 5:56 AM
    2mchfun
    You can watch the guage or go by memory if you simply apply a little effort.
  12. Mar 20, 2023 at 6:02 AM
    18" TRD Off Road Wheels
    It's not that it's hard. It's unnecessary.
  13. Mar 20, 2023 at 6:04 AM
    Garrett77
    Thanks, my old 2015 DC had the SR5 upgrade package and it didn't have the larger tank, but my 2020 DC does.
  14. Mar 20, 2023 at 6:04 AM
    The larger tank wasn't available until the 2016 model year.
  15. Mar 20, 2023 at 6:05 AM
    MadMaxCanon
    The caveat is that the larger tank only became an option starting in 2016 or 2017 i beleive, someone can correct me.
    Edit: ^ what he said
  16. Mar 20, 2023 at 6:06 AM
    Garrett77
    Ahhhhh...thanks.
    MadMaxCanon[QUOTED] likes this.
  17. Mar 20, 2023 at 6:24 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Which requires you to fillup once you get to an exact level every time. Then you also have to stand by the driver door reaching in to watch the gauge then shut the pump off. It's overkill. If thats what you like to do, that's great. But it's a pretty excessive process for something as simple as just filling a tank. Based on your suggestion, you're telling people to only use a quarter to a half of their tank.
    Elevatorguy likes this.
  18. Mar 20, 2023 at 6:27 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Run it down and fill it up. That process above is plain nonsense.
    Henry1jg, Mike59, Jaypown and 2 others like this.
  19. Mar 20, 2023 at 6:38 AM
    MadMaxCanon
    I think filling up at a 1/4 tank is a good idea to help extend fuel pump life. I have done that on most vehicles. You should be fine doing that.
  20. Mar 20, 2023 at 7:00 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    and if you have a S/C, do it sooner than 1/4 tank.
    because.
    Jaypown, GODZILLA and 2mchfun like this.
  21. Mar 20, 2023 at 7:11 AM
    MadMaxCanon
    because a 1/4 tank will only last you until the next stop light when your boosting? lol......
  22. Mar 20, 2023 at 7:28 AM
    2mchfun
    Tell that to the folks who have to fill up there truck with a dribble or spend a fortune on a repair because the check valve is somehow damaged or stuck and it can't be replaced without replacing the entire tank. Like it or not, these trucks have a few design flaws. I'm sticking with the "unnecessary" route and hopefully will be able to avoid that headache altogether. Might work, might not, but at least I am making others aware of the check valve issue so they will know what likely occured when fuel won't easily flow into their nearly empty tanks at the pump.
  23. Mar 20, 2023 at 7:43 AM
    That is caused by topping off, not filling to full.
  24. Mar 20, 2023 at 8:35 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    I usually try to fill up at 1/2 tank... mostly because I live in CA and it's $-$-$hocking if I go any lower. :eek2::eek:
  25. Mar 20, 2023 at 8:36 AM
    2mchfun
    Curious here, do you have any info or done any research on other brands or models that have had this problem caused by frequently filling up to the rim?
  26. Mar 20, 2023 at 8:46 AM
    MadMaxCanon
    I have seen somewhere on this forum that the tundra has an issue with the charcoal filter or evap cannister or something that when you top off or have an overspill it could cause an issue with one of those components. I always do the slow flow at the gas pump just in case it doesnt shut off or something it could mitigate any spills.
    2mchfun[QUOTED] likes this.
  27. Mar 20, 2023 at 8:47 AM
    MadMaxCanon
    Yeah you never really get used to the price lol. Though with only a 20 gallon usable range, a half tank comes really fast lol
  28. Mar 20, 2023 at 9:04 AM
    2mchfun
    I have seen the same. However, in all my life I have filled several other vehicles to the rim numerous times and I have also personally watched others fill a couple of different company fleets to the rim without any problems. None of the above were Toyota products though, mostly Ford and Mopar with a handful being GM. Somewhat of a design flaw IMO on the Tundra. :crapstorm:
  29. Mar 20, 2023 at 9:11 AM
    MadMaxCanon
    Agreed. never heard this concern for my other cars but it seems like good caution regardless, for no other reason than gas probably messes up your paint lol
  30. Mar 20, 2023 at 9:46 AM
    Type "why topping off gas is bad" into your preferred search engine. It's not vehicle or brand specific. It also isn't a "will cause damage" scenario, but rather a "may cause damage" scenario.
