2022 Tundra SR5 4WD
Discussion in 'Towing & Hauling' started by PasqueFlower, Aug 14, 2022.
  1. Aug 14, 2022 at 8:54 AM
    PasqueFlower
    PasqueFlower [OP] New Member
    2022 Tundra SR5 double cab 6.5ft bed, tow package, rear air suspension
    2022 TUNDRA SR5 with air springs option: Yes I have the capacities from the door jam. However, looking for a slide-in camper from Scout, model options 885-1130 lbs. dry. But the “manual for this vehicle”says max camper weight 825 lbs. Hmmm. Is this because of gross rear axle limitations?
  2. Aug 14, 2022 at 9:51 AM
    I’m not certain on this, but I would be willing to bet it’s due to bed strength. Slide in campers are rough on truck beds.
  3. Aug 14, 2022 at 9:49 PM
    PasqueFlower
    Another social media platform response to this said the manufacturers of other brands do this as well… lower cargo capacity for slide-in camper because they assume most will not follow the GVWR recommendations. So they build in 150 lbs per seatbelt as part of the camper restriction.
  4. Aug 14, 2022 at 10:42 PM
    mountaingroan
    mountaingroan New Member
    Frank
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    I wouldn't think twice, bag it, load it and go....
    Now a 2000# camper? Probably not.
    PasqueFlower[OP] likes this.
  5. Mar 19, 2023 at 7:31 PM
    Papa Smurf22
    Papa Smurf22 New Member
    Jimmy
    Lacey,wa
    2022 Blueprint limited tundra trd
    Black out emblems, dominator d6 boards, westcott leveling kit, 17” Moto Metal rims with 33x12.5 Irok Swampers
    So we bought a travel lite 850sbrx for my limited. Had torklift frame mount tie downs installed. We had no issue other then then space. So we are selling it and the tie downs to get a travel trailer
  6. Mar 19, 2023 at 7:48 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    That camper weighs 2,350 pounds dry if my research is right?
  7. Mar 19, 2023 at 7:51 PM
    Papa Smurf22
    Jimmy
    Lacey,wa
    Yep if I remember right. Added the 1000lb air bags to help with the squat. Forgot it was there most of the time
  8. Mar 20, 2023 at 6:25 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I had to look up your story. This guy did a lot of driving before it cracked. He needs a new frame..
    mayan and Elevatorguy like this.
  9. Mar 20, 2023 at 6:30 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    I bet that was fun!
  10. Mar 20, 2023 at 6:41 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    God damn definitely need a new frame lol
  11. Mar 20, 2023 at 6:45 AM
    This is an overused cliché. There's no way in hell you forgot 2350# of high center of gravity weight was in the bed of your truck. Or that you were riding on 1000# helper bags. It had to drive just a smidge different than an unloaded truck.
    Mattedfred likes this.
  12. Mar 20, 2023 at 7:19 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    mayan likes this.
