Have you ever watched Beavis and Butthead?
  1. Yes, and liked it
    24 vote(s)
    53.3%
  2. Yes and wasn't a fan
    9 vote(s)
    20.0%
  3. No but I'll give it a shot
    2 vote(s)
    4.4%
  4. No and probably never will
    6 vote(s)
    13.3%
  5. Yes and I have accepted Beavis Christ as my Lord and Savior
    4 vote(s)
    8.9%
  1. Mar 19, 2023 at 5:11 PM
    NWPirate
    Zach
    WA
    Thanks :fistbump:
  2. Mar 19, 2023 at 5:18 PM
    I have my Blackstone, but also use my grill some from time to time. Looking for a new scraper as ours got tossed around with wind and snow. There are many choices now. Any suggestions?
  3. Mar 19, 2023 at 5:23 PM
  4. Mar 19, 2023 at 5:28 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
  5. Mar 19, 2023 at 5:34 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Gloriosky Batman! I'm glad your friend is doing OK now.
  6. Mar 19, 2023 at 5:35 PM
    Blue Thunder
    Washington
    35 in the winter and 40 in the spring/ summer. Will bump the rears up to 45+ when I start towing
  7. Mar 19, 2023 at 5:37 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You still have to have the right tool or pay the dealer $35 every time you swap tires. Apparently the truck only stores one set of tires. But if you take those tires off for 6 months then put them back on, apparently it doesn't remember them. :facepalm:
  8. Mar 19, 2023 at 5:38 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Perhaps they lied but they told me they were literally a clone of the sensors that are on the truck so it didn't have to be reprogrammed as a new sensor because the truck still saw them as the original
  9. Mar 19, 2023 at 5:46 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Discount will also reprogram TPMS for free if you buy tires from them. I used to do it all the time even when I swapped my own winter tires back and forth. My current tires don't have any sensors in them so I have just had the light on for like 2 years now and I don't even notice anymore.
  10. Mar 19, 2023 at 5:56 PM
  11. Mar 19, 2023 at 6:24 PM
    NWPirate
    Zach
    WA
    I wonder if my Scangauge 3 can fix that.. :monocle:
  12. Mar 19, 2023 at 6:50 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
  13. Mar 19, 2023 at 6:57 PM
    NWPirate
    Zach
    WA
    My condolences. :hattip:
    Can you still get the brush though?
  14. Mar 19, 2023 at 7:00 PM
    Outbound
    Aaron
    Northern Alberta
  15. Mar 19, 2023 at 7:02 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    All the things we were told to be conspiracy theories are now coming true. :(
  16. Mar 19, 2023 at 7:18 PM
    Leo's first
    Groton ma
    I have a nice stainless wire brush that works well on my cheap grill
  17. Mar 19, 2023 at 8:12 PM
    18" TRD Off Road Wheels
    Spent a good chunk of time hosing off the road grime and thin mud slurry from my road, then did the top end touchless wash. So pretty in the sun.
  18. Mar 19, 2023 at 8:21 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Burnt Orange™ is truly a modern classic color.
  19. Mar 19, 2023 at 8:37 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  20. Mar 19, 2023 at 8:38 PM
    I'll take your compliment, underhanded though it was. :hattip:
  21. Mar 19, 2023 at 8:41 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :rolleyes:
    It really is a sharp color. But I will never not call it by the wrong name.
  22. Mar 19, 2023 at 9:30 PM
    Outbound
    Aaron
    Northern Alberta
    That could work, but welding brushes don't have the requisite weight for bludgeoning small mammals.
  23. Mar 19, 2023 at 10:22 PM
    RainMan_PNW
    Casey
    Clark County, WA
    If I mount it to the end of an axe handle maybe…
  24. Mar 19, 2023 at 11:28 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Fuuuk.... it definitely was not his time that day; great reason to celebrate!!!!
  25. Mar 20, 2023 at 5:25 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Y'all are probably aware, but there is a case or three every year where a wire gets ingested by someone. The last one I read was a kid. Some stories have the wire ruining someone's life. I know the few times it happens are statistically insignificant, but I just use a cheapo spatula for regular cleaning, and the foil-covered-grate method when I want to get it really clean.
  26. Mar 20, 2023 at 5:27 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Do you come with the brush?
  27. Mar 20, 2023 at 5:29 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I generally use something I won't use near food to bludgeon small animals.
  28. Mar 20, 2023 at 5:56 AM
    But small animals are food. :confused:
  29. Mar 20, 2023 at 8:17 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    They become food. But until they do, they're hairy, dirty and, eventually, bloody.
  30. Mar 20, 2023 at 8:17 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
