tundra transmission issue
Discussion in '1st Gen Tundras (2000-2006)' started by Alanprior52!, Mar 18, 2023.
  1. Mar 18, 2023 at 2:21 AM
    Alanprior52!
    Alanprior52! [OP] New Member
    Alan
    2001 tundra pickup
    transmission shifts and works fine, but can only start from stop if shifting into low and manually shifting up to higher gears. Then after a stop, will only start out again if shifting down back to low to start from stop.
    i would welcome any diagnosis.
    The transmission otherwise shifts normally at all speeds except wont start out from a stop without first shifting into low.
    when attempting to start out in drive it acts as it it is in N and does nothing!
  2. Mar 18, 2023 at 9:16 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I would try and post in the "1st Gen" section since it appears you have a 2001 tundra.
    You are currently in the 2nd gen section.
  3. Mar 19, 2023 at 2:20 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    What transmission is in this? It sounds like it has a mechanical governor and/or the tail shaft speed sensor is not working?
    It should have some codes stored for this type of failure. Have you hooked up to it to read them?
    Start there!
    JasonC. and Jeff_5_7 like this.
  4. Mar 19, 2023 at 2:57 PM
    @T-Rex266 can we get this moved into 1st gen territory
    BubbaW and T-Rex266 like this.
  5. Mar 19, 2023 at 4:17 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Whats the fluid look like? I'd lean to a burnt clutch pack if the fluid was recently changed. But maybe a stuck ball.
    If it was a solenoid, it would try to jump into 3rd when you put it in drive.
    any codes?
  6. Mar 19, 2023 at 4:37 PM
    Did you check the fluid level? Failure to automatically shift properly is a classic symptom of improper fluid level.
    I doubt that's what it is, but it's the first thing to check any time you're seeing trans probs: Is the fluid the right color? Is the fluid level proper?
    NickB_01TRD and Aerindel like this.
