Prewire fog lamps?
Discussion in 'New Member Introductions' started by MepTundra, Mar 6, 2023.
  1. Mar 6, 2023 at 5:22 PM
    MepTundra
    MepTundra [OP] New Member
    2021 White Tunra double cab
    Hello everyone. New to the forum and just bought a 2021 basic Tundra double cab. Looking forward to learning a lot about my truck.
    I have a question. The truck did not come with fog lights, but I believe it is prewired. There are connectors at each location where the lamps should be. There is no relay in the slot but it looks like there are contacts.
    Is there a plug and play kit or can I buy a few items to get it all connected without running wires.
    Thanks a lot!,
  2. Mar 6, 2023 at 5:27 PM
    MepTundra
    Adding to the question. Is there a connector in the dashboard that is just hanging there that can be connected to a switch? Thanks
  3. Mar 6, 2023 at 6:26 PM
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
    Fog light switch is built into the turn signal stalk. It would be easier installing aftermarket lights and wiring it.
  4. Mar 6, 2023 at 7:42 PM
    MepTundra
    Does that mean the turn signal stalk is also prewired?
  5. Mar 6, 2023 at 8:09 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! You might want to search the forums here. A few have replaced their stalk, which I believe is required to get the OEM functionality. Like @timdske said, it's likely a lot easier to go aftermarket and add a switch.
  6. Mar 17, 2023 at 5:19 PM
    MepTundra
    It looks pretty straight forward to replace the turn, light, fog light stalk. Do you have to reprogram the trucks computer to recognize the new fog lights and switch? Or is it pretty much plug and play?
  7. Mar 18, 2023 at 8:09 PM
    Welcome from NY.
