Soft top question
Discussion in '3rd Gen Tundras (2022+)' started by matth66, Mar 5, 2023.
  1. Mar 5, 2023 at 4:47 PM
    matth66
    matth66 [OP] New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    I currently have a Retrax pro xr. And wanted to use the t track to mount a soft topper. Anyone heard of anyone doing this
  2. Mar 18, 2023 at 7:57 AM
    Dsforever2
    Dsforever2 New Member
    2023 Tundra Limited
    I am considering the same idea of a soft topper with a Retrax pro xr. Are any soft topper compatible with the Retrax pro xr?
  3. Mar 18, 2023 at 8:24 AM
    alex17117
    alex17117 New Member
    Alex
    2024 limited, Lunar Rock
    Won’t work. The frame of the Softopper extends several inches into the inside of the bed which block the utility tracks
  4. Mar 18, 2023 at 8:53 AM
    matth66
    matt
    Nor cal
    Is that only when it’s folded down or when open?
  5. Mar 18, 2023 at 10:07 AM
    Dsforever2
    2023 Tundra Limited
    Thanks a bunch for the quick reply!
  6. Mar 18, 2023 at 10:55 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  7. May 30, 2023 at 5:22 PM
    matth66
    matt
    Nor cal
    Could you post some pics of the softopper that shows the rail you are referring too
