What size is the crank pulley bolt on the 4.7L?
Discussion in '1st Gen Tundras (2000-2006)' started by perpetualmotion, Mar 17, 2023.
  1. Mar 18, 2023 at 9:48 AM
    Casper421
    In the woods
    06 DC
    Well, is the new motor in yet?! What are you waiting for?!
  2. Mar 18, 2023 at 8:49 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Holy cow this thread is a crapshoot.
    The crank pulley bolt is M18x1.5.
  3. Mar 19, 2023 at 9:16 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    For a reference to anyone, this the same size and thread pitch of an O2 sensor on these trucks.
  4. Mar 20, 2023 at 6:38 AM
    There you go! Just use an old O2 sensor in there, torque it down, and you're good to go! :rofl:
  5. Jul 4, 2024 at 6:12 PM
    USERidiculousNAME
    USERidiculousNAME ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    Doesn't know the answer, yet processed to treat you like a child, for not figuring it out. Silly understood your situation, you wanted to go get tap. He said figure it out when you have the bolt. Actually his way is better, you don't want bolt showing up and it doesn't match your retapped bolt hole, meaning possible 3rd tap out if even possible
  6. Jul 4, 2024 at 6:38 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
