  1. Mar 17, 2023 at 5:04 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    Tractor pull? Trailer queen? Haulin Mass?
  2. Mar 17, 2023 at 7:27 PM
    S13ka24de
    S13ka24de New Member
    1" wheel spacer...lol
    GAknight, Tundra Dude 45, WVI and 7 others like this.
  3. Mar 18, 2023 at 2:41 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Make sure you retorque after 50miles.
    NewImprovedRon and HulkSmurf14 like this.
  4. Mar 18, 2023 at 5:07 AM
    coTony
    Tony
    Montrose, CO
    Got it put back together yesterday. I started on Thursday after work and got to the point where I was wrapping it up and still wanted to add the USB on my dash mount and replace the cigarette lighter in the rear with USB and constant on. Decided to wrap it up on Friday and it ended up being a Tundra day
    Before
    During
    After
  5. Mar 18, 2023 at 5:44 AM
    trevorklat
    trevorklat Don't Mess with Texas!
    The Lone Star State
    2018 Super White Platinum Tundra 4WD CM
    Linex bed liner, Retrax roll-top bedcover, Ranch Hand Summit brush guard, SDHC ABS sensor guards, Interior LEDs, Cargo lamp LEDs, Reverse Light LEDs, Rear TRD sway bar, Valhalla's Shield Cat plates, Husky floormats
    Preparing to haul next project home (John Deere 4300). First haul after having dealer flash computer to rid myself of the trailer brake controller disconnect error. Worked flawlessly!IMG_2845.jpg
  6. Mar 18, 2023 at 5:46 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Looks great. I'm a big fan of the OG Pro grill as well, especially with the OEM LED headlights. The long horizontal bar of the grill goes well with the LED horizontal DRL's.
    Nice Deere, love the Yanmar diesels in those. Does it run?
  7. Mar 18, 2023 at 7:03 AM
    BLUEEYEDBRUTE
    BLUEEYEDBRUTE New Member
    2015 Tundra Texas Edition SR5 Grey
    Exhaust, Lift, Rims and Tires
    Added some window tint and finally got the drip molding for the roof that was missing
  8. Mar 18, 2023 at 11:58 AM
    Kitt
    Kitt New Member
    2017 Tundra SR5 TRD 4x4
    Completely stock
    After much research, and much time on the forum, I've decided I don't really need a coilover lift. I would like to run 35's at the most, or some wide 33's at the least. I'll leave the serious off roading for my Polaris.
    I think 3" lift should suffice.
    Now the arduous task of deciding which manufacturer.
    Any input is welcomed.
    IsaiahCanada likes this.
  9. Mar 18, 2023 at 12:04 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    If your current shocks are still in decent shape, the Westcott kit is a good option. https://westcottdesigns.net/product/toyota-tundra-trd-off-road-preload-collar-lift-kit/
  10. Mar 18, 2023 at 12:10 PM
    Kitt
    Kitt New Member
    Completely stock
  11. Mar 18, 2023 at 12:14 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Correct, a lift alone won’t get you all the clearance. Removing the mudflaps and pushing the bumper plastics forward should get you close. Every truck is a little different on what all is required. It also depends on the actual tire and width you go with. 295/70R18 is around 34” and fills out the wheel wells nicely without needing as aggressive of clearancing.
    Pangaea, GarTX526, the red and 3 others like this.
  12. Mar 18, 2023 at 12:31 PM
    Kitt
    Kitt New Member
    Completely stock
    Nice to know, thanks again.
    I'm looking at Mickey Thompson Baja Legend MTZ in 33x12.50/R20. But I might upgrade the size to 295 if they'll work with that lift.
  13. Mar 18, 2023 at 2:05 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    If you already knew this then pls disregard. We have subforums for more robust discussions about specific subjects. Wheels & Tires, Suspension, Performance & Tuning...
    This is a sticky from Wheels and Tires. Sharing in hopes it helps. https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/
    Tripleconpanna and AggiePhil like this.
  14. Mar 18, 2023 at 2:12 PM
    Kitt
    Kitt New Member
    Completely stock
  15. Mar 18, 2023 at 2:19 PM
    S13ka24de
    Something stupid again just torch $700 down the drain and made a FlowBorlamaster less drone exhaust.
  16. Mar 18, 2023 at 2:32 PM
    SwitchThrottle
    Installed the Diode Dynamics 42 bar with Hotshot upgraded brackets. It's a snug fit, and you can't adjust the angle when it's in so I just leveled the bar with the bumper mounts and tightened it down. I'll sort the wiring later, but it works and hope its pointed in the right direction.
    GAknight, kbark, Ginsterkev and 8 others like this.
  17. Mar 18, 2023 at 3:12 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Looks so much better
  18. Mar 18, 2023 at 3:35 PM
    S13ka24de
    Does it block the air flow?
  19. Mar 18, 2023 at 3:57 PM
    lowball
    lowball New Member
    LB
    2018 Silver Tundra TRD Off Road
    Just got my onboard air compressor installed a few day ago + morrflate 4wheel hose kit!
  20. Mar 18, 2023 at 4:26 PM
    1UP
    1UP Truck Gang
    No apologies dude. Quite a few ppl don't realize these subforums exist. Just sharing the wealth of knowledge :thumbsup:
  21. Mar 18, 2023 at 6:04 PM
    SwitchThrottle
    It takes up the entire bumper opening, so it blocks that airflow, but I doubt it will cause much issue. The grill opening is so large I'm sure it more than makes up for it. I believe the cooler right behind that opening is the powersteering cooler.
    bulldog93 and Tripleconpanna like this.
  22. Mar 18, 2023 at 6:47 PM
    MickisDaddy
    MickisDaddy New Member
    2015 Toyota Tundra CrewMax
    None as of yet
    I finished installing running boards, took it through the car wash (you wouldn't know it to look at it), installed my floor mats, and added some bling. I just got mine a few weeks ago. Next is probably going to be a new head unit. I am looking at the Kenwood DMX7709S.
    truck_front.jpg truck_runningboards.jpg truck_fflormats.jpg truck_bfloormats.jpg truck_stickers.jpg
    GAknight, porkitt, cartage1 and 9 others like this.
  23. Mar 18, 2023 at 7:52 PM
    Bdebs
    Bdebs Don’t Threaten Me With A Good Time!
    2020 Limited Crewmax TRD Offroad
    TRD Rear sway bar, Bilstein 6112, Bakflip MX4 Tonneau Cover
    Installed the Falken wildpeak at3w 295/70/18 on stock trd off road 18 inch rims with bilstein 6112 on 1.9 setting. This truck looks Way better than it did with the stock 275/65/18 tires.
  24. Mar 18, 2023 at 8:27 PM
    LVM8
    LVM8 New Member
    NY
    2024 Tundra Limited 4X4 - TRD OF - MGM
    Got these installed today. 295/70/18 Wildpeaks
  25. Mar 18, 2023 at 8:34 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    “Mostly” mounted my new-to-me WKOR sliders.
    Still need to drill and bolt the underside, and need to modify my rear cat plate mounting brackets, but very happy.
    96E70138-DCE3-4E2B-B39A-1FF7A44FA355.jpg CA5C7BBF-7F70-451D-95FB-7814A3D7F337.jpg
  26. Mar 18, 2023 at 8:53 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Did you end up throwing some paint on them, or is that how they came out after you cleaned em up???
  27. Mar 18, 2023 at 9:17 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You just need to get rid of those white comic sans stickers at the back end of them :boink:
    Looks great though. Love my WKORs!
  28. Mar 18, 2023 at 9:20 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Just dusted them off with a dry rag.
    Yeah. I agree
    I think I’ve got some small TM still
  29. Mar 18, 2023 at 9:27 PM
    Tripleconpanna
    That's awesome... I glad you found a 'used' set in that kind of condition :thumbsup:; better than waiting for the build and really better when it's less $$
  30. Mar 18, 2023 at 9:42 PM
    trevorklat
    The Lone Star State
    Yes, it runs. but needs some TLC (tires, fluids, filters) and new plastic covers.
