What size is the crank pulley bolt on the 4.7L?
Discussion in '1st Gen Tundras (2000-2006)' started by perpetualmotion, Mar 17, 2023.
  1. Mar 17, 2023 at 8:36 PM
    perpetualmotion
    perpetualmotion [OP] New Member
    2000 shitbox
    As per usual, i had a whoopsies. Long story short, I need to know what size the crank pulley bolt is on the 4.7. Scoured the forums, scoured the net, bolt size and pitch Ive not found yet. Ordered a new one, just need to know for the purposes of running a tap .
    Edit : first gen (2000)
  2. Mar 17, 2023 at 8:37 PM
    Have you tried extraction yet?
  3. Mar 17, 2023 at 9:06 PM
    perpetualmotion
    2000 shitbox
    no extraction needed. I just need to know the size and thread pitch. bolt came out but the first two and 5th threads are damaged. Im betting on the last few with some loctite to hold.
    Edit: I would measure the bolt for pitch and diameter, but its more than mangled.
  4. Mar 17, 2023 at 9:11 PM
    Also look at getting a chase vs a tap.
    Mr Badwrench likes this.
  5. Mar 17, 2023 at 9:18 PM
    perpetualmotion
    2000 shitbox
    French, your comments aren't entirely useful.
  6. Mar 17, 2023 at 9:20 PM
  7. Mar 17, 2023 at 9:20 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Do you own a tap and die set with gauges? If not, just wait till you receive the bolt and head to the hardware store, they usually have gauges on the bolt isle. Good luck.
  8. Mar 17, 2023 at 9:28 PM
    perpetualmotion
    2000 shitbox
    Tilly, Im going to the wrecking yard tomorrow and will pull one, even though I ordered one. I just wanted to know because i highly doubt ill be able to find a metric tap of that size locally. Id rather go down to the wrecking yard and get a new motor than make the trip for a bolt and spend time waiting for a tap, i can swap a motor faster than I can wait.
  9. Mar 17, 2023 at 9:32 PM
    TILLY
    Massachusetts
    OK, whatever, we're just trying to help you out.
  10. Mar 17, 2023 at 9:43 PM
    perpetualmotion
    2000 shitbox
    i appreciate it
    TILLY likes this.
  11. Mar 17, 2023 at 10:13 PM
    Mr Badwrench
    Mr Badwrench New Member
    Glad you figured it out?
    :confused:
  12. Mar 17, 2023 at 10:26 PM
    perpetualmotion
    2000 shitbox
    The question still remains; whats the thread diameter and pitch? I don't intend to come off like a dick, however I thought that was a straight forward question , given the provided information. Which I feel hasn't been read by previous commenters. Im stoked on the input, its just not useful.
  13. Mar 17, 2023 at 10:46 PM
    TILLY
    Massachusetts
    We tried to lure you to common sense, but it seems you weren't capable of that.
  14. Mar 17, 2023 at 10:58 PM
    perpetualmotion
    2000 shitbox
    Tilly, I know how to identify diameter and thread pitch, the bolt is however mangled. It’s the main crank bolt.
    If you don’t have the answer to a question don’t answer , but don’t insult my intelligence based off your lack of reading comprehension.
  15. Mar 17, 2023 at 11:17 PM
    TILLY
    Massachusetts
    Your intelligence is already in question if you cant figure out if the bolt you already ordered is the correct one or not. Don't blame us for your stupidity.
  16. Mar 17, 2023 at 11:30 PM
    perpetualmotion
    2000 shitbox
    Ordering a bolt based off a part number is simple, yeah? Finding the actual thread pitch and diameter without one in hand,is apparently not. If you were able to understand what you're reading you’d know the bolt isn’t the subject in question.
    Again, I ask you; what is the thread pitch and diameter of the crankshaft pulley bolt on a first gen? (It’s Okay to say you don’t know, tilly. Or even better, tell me what it is and I’ll eat my hat)
  17. Mar 18, 2023 at 12:16 AM
    TILLY
    Massachusetts
    If you're too lazy to go to the hardware store for free like I recommended, get one of these, problem solved. :thumbsup:
    shifty` likes this.
  18. Mar 18, 2023 at 2:08 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  19. Mar 18, 2023 at 5:17 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Well, that didn't take long!
  20. Mar 18, 2023 at 5:30 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  21. Mar 18, 2023 at 6:26 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Think its the same as a 1uz?
  22. Mar 18, 2023 at 6:36 AM
    Probably not, and screw you for trying!!!
    oh, and not helpful!!
    don’t worry op, I took care of this one for ya. :thumbsup:
  23. Mar 18, 2023 at 6:41 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  24. Mar 18, 2023 at 7:19 AM
    shifty` Goons of Hazzard
    Entitlement much?
    Whew, glad I was sleeping when this one came up.
    Exactly. I'd expect this to be basic knowledge, and doesn't require first few threads to be OK.
  25. Mar 18, 2023 at 7:22 AM
    OP should be lucky he even got a response to such a specific question. I've been to other forums that are so dead you never hear back from anyone.
  26. Mar 18, 2023 at 7:27 AM
    TSsssssss
    FirstGenVol[QUOTED] and KNABORES like this.
  27. Mar 18, 2023 at 7:28 AM
    This isn’t how u make friends, OP
  28. Mar 18, 2023 at 7:34 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Sounds like he’s not here for friends, just someone that can google better than he can.
  29. Mar 18, 2023 at 8:53 AM
    NWPirate
    Zach
    WA
  30. Mar 18, 2023 at 9:03 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    My google-fu used to be so much better before greed ruined the search feature.
    but 13471c fits 1, 2, and 3 uz and the 2jz.
    https://youtu.be/8UFIYGkROII
    N84434, NWPirate and FrenchToasty like this.
