20 inch Light bars and light pods installed
Discussion in '3rd Gen Tundras (2022+)' started by buttersdad, Mar 15, 2023.
  1. Mar 15, 2023 at 8:25 PM
    buttersdad
    buttersdad [OP] New Member
    Anthony
    2023 tundra
    Finally got around to installing a few upgrades to my new 23 platinum. Been waiting to install the trd pro grill until I decided what light bars to install in the grill opening, and on the lower grill as well. I wanted to save some money and decided to try the lasfit 20 inch light bars. Was going to get the lasfit light pods as well but got an extremely good deal on some rigid pods I couldn't pass up. I went with the Wescottdesigns mounting bracket for the grill light bar and used some tacoma light bar mounts for the lower grill light bar. I had to chop and measure the tacoma brackets to fit but they worked out great with some self tapping screws directly to the crash bar. Got the oem looking buttons from caliraised as well as their dual light harnesses so both light bars and light pods are activated by a single buttons. These light bars throw some serious light, and the rigid dss pro pods are very bright as well for ditch lights. Overall they worked out exactly how I wanted and I saved about $900 over buying premium light bars. I'll update the post if I have any issues with the lasfits.
  2. Mar 15, 2023 at 8:38 PM
    GoFast157
    GoFast157 New Member
    Looks nice. I kinda dig the dark chrome now that there's less of it. Was going to color matching mine when I swap grills but now you have me second guessing that.
  3. Mar 15, 2023 at 8:43 PM
    buttersdad
    Anthony
    2023 tundra
    I wanted to color match the mustache as well, but it does give it a nice accent with the smoke chrome. I think the silver makes it look better than some of the other truck colors
    GoFast157 likes this.
  4. Mar 16, 2023 at 5:15 AM
    nodak67
    nodak67 New Member
    JR
    have to say the dark chrome looks better the darker the vehicle color :)
    but then again anything not chrome is better on any color
  5. Apr 25, 2023 at 1:36 PM
    Petey_Tundy
    Petey_Tundy New Member
    Peter
    2023 Tundra SR5 TRD Sport Premium
  6. Apr 25, 2023 at 2:07 PM
    007Tundra007
    007Tundra007 New Member
    2022 Tundra Limited
    Looks really good, clean install.
    Curious about the dark chrome grille surround? Vinyl?
  7. Apr 25, 2023 at 2:38 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    That's the Platinum grille...smoked chrome kinda look
  8. Apr 25, 2023 at 7:28 PM
    buttersdad
    Anthony
    2023 tundra
    Petey_Tundy[QUOTED] likes this.
  9. Jun 26, 2023 at 6:09 PM
    BP2190
    BP2190 New Member
    2023 TRD Sport Premium 4x4 Midnight Black
    I guess I'm having trouble seeing, did you have to cut your grill out? Also the mounts you linked, they look different than the ones you used? All the pics except the last one showed mounts that are flush with the crash bar, the last one shows them sticking out quite a bit. I'm looking for the ones that are close fitting ( don't want to trim or cut my bumper )
  10. Jun 26, 2023 at 7:45 PM
    buttersdad
    Anthony
    2023 tundra
    So no cutting of the grill is needed, it will fit with the grill as is. The different camera angles do make it look more flush one one pic and further out from the crash bar on the other. The mount I Linked will work perfect, you want the light bar sticking out from the crash bar and right behind the bumper mesh, I had to cut and drill the mounts to fit the bar perfectly, if you want a plug an play option get the westcott designs light bar mounting brackets, but those will run you $150. Otherwise $20 and a little cutting and drilling will get you the same result with the mounts I used
  11. Jun 26, 2023 at 8:11 PM
    BP2190
    BP2190 New Member
    Ok, awesome! I planned to do this somewhat budget. I will say it does look more flush. I do plan to drill into the crash bar, was hoping to not modify anything else, so im glad yo hear that I don't need too. Thank you very much for your quick response
  12. Jun 26, 2023 at 8:30 PM
    99ways2die
    99ways2die New Member
    NJ
    I see your @20, and raise you $10!
    LoL
    Pretty much the same result; I'm still amazed how some of these companies can charge ppl $100+ for these brackets with a straight look on their face.
    For "BP": i did cut the grate out in that opening as I didn't want/need that thin line of plastic obstructing the light output. Your call on this one; many ppl cut them out, some don't.
    My old thread is here, if anyone cares or wants additional info for reference/etc:
    https://www.tundras.com/threads/how-to-bumper-led-light-bar-installation-and-general-info.110234/
    Have fun.
  13. Feb 7, 2024 at 11:04 AM
    SgtSausage1978
    SgtSausage1978 New Member
    Utah
    2023 SR5 crew cab
    screw Baja Designs 1000$ for 1 light that’s insane to me..
    rough country has the bumper clear white light bar for 100$ with all the wiring and brackets ..might go with that on bumper ..
    I have the TRD TOYOTA heritage grill that says toyota on it on my 23 SR5 might be called a TRD PRO grill..
    for the 20” light bar behind the grill under where it says toyota i’m looking at either the OZ-USA, the LASFIT. or maybe even the rough country amber 20” dual row black series with amber DRL if it fits its 3” high ..i want amber and DRL ….
    should i have two switches for each light hmmmm ? will the amber overpower the white bumper light i think it’s 18000amber on the Rough country lumens to 8000 white .. i know it’s rough country they kind of get a bad wrap warranted or not but for the price they have great reviews on both those lights.
    my question is wescott designs wants 220$ for the mounting bracket for a grill light bar that’s pretty pricey..i know i can mount the bumper bar for 10$ as shown by others here but has anyone found a cheaper way to mount the grill bar???
    probably get a flush OEM looking switch for the left hand control panel ..wish they made a paddle switch for AUX that goes right in front of the shifter where the hazard light switch is..thanks
    update looks like that grill opening is only like 1 3/4” so that dual row probably won’t work ..RC makes a single row amber DRL bar that’s 1.6” tall might have to go with that
  14. Feb 7, 2024 at 1:57 PM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey @SgtSausage1978,
    Baja Designs has been an off-road lighting company for 32 years we have put countless hours into testing and working closely with our engineers to make our products as best as they can be. With a lifetime warranty and a 30-day money-back guarantee, we created a product line that will last. Our products are uService-able, making them completely customizable with a variety of lens options to suit your driving needs. We have lights from all price points. Depending on what you are looking for, if dependability and quality are what you are looking for then that is why we are here. Our lights come standard with :
    Baja Designs Aux Lights
    I would also recommend checking our Lighting Zones Explained which helps you find which zone would be ideal for your lighting application. Please feel free to let me know if you have any questions. I am Baja Designs Rep here on the forum, and I can help you out with anything you need.
    Best,
    Bill Sonevongxay | Forum Sales & Support 
    Email: Bill@bajadesigns.com Phone: (760) 560-2252
    JGlock30 and Reaper1911 like this.
  15. Feb 7, 2024 at 4:15 PM
    SgtSausage1978
    Utah
    2023 SR5 crew cab
    @Baja Designs
    no one is questioning the fact your lights are the best after all your tests and countless hours of results.. and you guys are great as a company and the customer service is fantastic..
    When the Red Bull Race Trophy Truck team comes to you with a blank check and says do it all as best as possible we all know who they’re calling …
    don’t get offended I’m simply stating that for most people 1000$ is too much money to spend on one 20” light i think even you can agree with that ..
    Here’s a suggestion, you take all that knowledge and come out with a model of light where you don’t use the best of the best components but it’s still Baja Designs worthy for 3-400$ …it won’t be BAJA RED BULL TROPHY TRUCK worthy, but still blows all these other lights out the water and you sit back and collect your millions from us average joes..i’ll take 10% for the suggestion ..
    stay frosty
  16. Feb 7, 2024 at 5:11 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    @Baja Designs
    It's a challenge to understand the value BD has engineered into their products over competitors. While BD provides detail technical descriptions of BD product and how great it is, how does a customer know the knock-offs do not have the same features?
    How about a video detailing, showing, how your product compares to a popular Amazon item, say, lasfit 22 in light bar? Show comparison such as beam patterns, current draw, thermal management with actual data? No one does this anymore. Well almost no one. Check out this video from banks. A direct comparison will go much further to justify the cost.
  17. Apr 22, 2024 at 5:49 AM
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    2022 Tundra SR5 , blueprint
    Tonneau cover
    There are plenty of knock off products out there for a fraction of the cost and they look and perform great.as said earlier, there is no need for me to spend this kind of money. There are many choices out there. The prices are outrageous.
    It’s their business to charge what they want. It’s our choice to get what we want for the price we are willing to spend.
  18. Jun 17, 2024 at 11:35 PM
    LunarRockAgave
    LunarRockAgave New Member
    LimitedCrewMaxLunarRock24
    I did this project last week, and just now uploaded some pictures. I didn't take off the entire front end, just the bottom pieces "Tundra" framed bottom, and the bottom black plastic shield. I would advise to do it properly take your time and just take the front end off. Taking the pieces below as I did and others had suggested doesn't seem like the best approach as you can tell you're taking things apart out of order. I did take my time and was very careful not to scratch my paint, and I walked away without any issues (aside from a partial broken clip). I used clip prying tool. Anyways here are some pictures of what I did and how I mounted (total cost of hardware to install $1.50. I didn't need to order any light bar brackets. I couldn't justify the cost of the brackets for what they were (this is my opinion and we all have one).
    Lasfit 22" Lightbar and the brackets it comes with are perfect to tighten at a perfect angle and mount behind the plastic grill. They mount and sit flush perfectly in a little insert/section of the plastic grill.
    I took advantage of the "Tundra" cover piece being off to put vinyl "Yellow" over the fog lights. If I need the diodes etc later, I'll add them, but for now worth the $9 investment in the yellow vinyl roll and the output in my "opinion" is good. Anyways purpose of this picture is I've outlined in "red" the nuts that are holding the light bar to the plastic grill.
    I used 3 nuts on each side (one to fasten the bolt to the bar and affix it to the bar), then the other 2 nuts to fasten and tighten to the plastic (the two nuts allowed me to adjust height as well). I was able to play with the angle to make sure I was comfortable to bring it as close as possible to the plastic but not let it rest on the plastic to avoid any heat issues and burning/melting should I use the lightbar for extended time.
    Finished product. I'm quite happy with the light output and the setup. Waiting for the Cali-Raised push button, but other than that, this took about 2hours to install (but I took my sweet time and did this over 3 days).
    Motorjock721 likes this.
  19. Jun 18, 2024 at 5:48 AM
    Bailey1794
    Bailey1794 New Member
    Houston
    2023 Smoked Mesquite Hybrid 1794 Tundra
    Diode Dynamics Ambassador & Talons Garage Affiliate (See Below for discounts) Use code Bailey for Diode Dynamic free shipping Current Build & Pics Instagram.com/Bailey1794 Discounts & Affiliate links below https://linktr.ee/bailey_1794?fbclid=PAZXh0bgNhZW0CMTEAAaYH-pwfNz76E_oAQekLat2ZdcSY0VrV7a8O3_UxaU15mlBifUGV3lGaU4s_aem_Aamyw5XakyTlp6h_WyGSA8wBSO-cFzK1Z0t3EQBBaXEgDCnQI49fSwGFqQNWOCNd5OxDNGhVrMYRcfs_DEuuCXSy
    Looks great. I'm assuming those power board lights are aftermarket or they came with the aftermarket steps?
  20. Jun 18, 2024 at 10:42 AM
    LunarRockAgave
    Thanks and yes, the lights on the steps are part of the after market steps (Rough Country Steps). PIA to have installed those, not because it was difficult, more so because of the tedious routing of multiple cables, but yes the LEDs are from the Rough Country Steps.
    WillTunBlack20 likes this.
  21. Jun 18, 2024 at 11:54 AM
    Bailey1794
    Houston
    Was the lighting attached to the factory RC wiring? I am wondering if i can add lights to the stock OEM power boards.
  22. Jun 18, 2024 at 11:59 AM
    jctmundra
    Northern VT
  23. Jun 18, 2024 at 12:03 PM
    Bailey1794
    Houston
    LunarRockAgave likes this.
  24. Jun 18, 2024 at 12:06 PM
    jctmundra
    Northern VT
    Wiring will be the same. I'd go with DD as the build quality is better, will be brigher and can purchase magnetic mounts.
  25. Jun 18, 2024 at 1:54 PM
    Bailey1794
    Houston
    Sorry i meant the DD bed lights they are wired into the bed somehow and does not require splicing i believe? Since they are essentially Rock lights i wonder if i can just order 2 sets and run one as the bed & another for running boards. Still waiting on their install guide so i can confirm if its possible.
