22 Tundra TRD Suspension Lift Kit
Discussion in 'Suspension' started by gr8fasushi, Sep 11, 2022.
  1. Mar 11, 2023 at 5:56 AM
    #601
    Silver23
    Silver23 New Member
    2023 Silver 1794 TRD
    I've seen a few youtube videos of in-depth installation (and kit contents). The new front axles are definitely longer. If memory serves me right, I'd say they were at least 2-4 inches longer.
  2. Mar 11, 2023 at 5:57 AM
    #602
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I think the picture is in this 22 page thread
  3. Mar 11, 2023 at 4:45 PM
    #603
    Seity
    Seity New Member
    Yea the indepth install video mentions the boot looks longer but the axles seem to be same length. Was hoping for a side by side.
  4. Mar 11, 2023 at 5:55 PM
    #604
    Taikowaza
    Taikowaza New Member
    This video provides some comparison.
    https://youtu.be/Pg_45Pz80KA
    Fast forward to 6:00 to see some examples
    _kmg_ and Yaboy like this.
  5. Mar 11, 2023 at 6:29 PM
    #605
    Seity
    Seity New Member
    Thank you, that is what i was looking for.
  6. Mar 11, 2023 at 10:19 PM
    #606
    enjoytheridedude
    enjoytheridedude New Member
    3rd Gen Tundra SR5 TRD off road
    37 inch Yokohama Geolandar Mud Tires 17 inch method racing 701 bead grip Southern Style Off Road Full Plate Bumper and Rock Sliders Total Chaos Front upper control arm and rear 5 link kit. Warn VXR10s winch Rigid industries 30 inch midnight edition E series pro spotlight pattern light bar We Boost OTR fleet Diode Dynamics ss3 pro SAE fog lights Lasfit auto lighting ditch lights Rough country lift for now Yet to be installed (dobinsons rear 2.5 inch lift springs ) Front and rear suspension lift Icon front sway bar drop brackets Adventure motors KC rear brake lines and rear sway bar drop bracket.
    I have the TRD Lift kit except I have King 2.5 adjustable coil-overs and rear dobinsons springs and rear total chaos link kit.
    I had to take off my front Total Chaos UCA because it was too short to use with the longer TRD lift kit axles.
    I’m here to see if you guys know if a Camburg UCA with heim joints may be compatible with this TRD kit?
    I noticed a significant loss of fluidity in the travel range with the switch from the total chaos UCA to the Roush TRD UCA…I even hear it sort of creaking and it bothers me. The ball joints on the high speed style kits are just so smooth.
    What are my options?
    I went with Toyota extended axles to correct my CV angles and give me reliability but the Roush UCA ball joints are killing me.
    I’ve called every company almost and none are willing to support the axle length of this TRD kit. Only the stock length and of course their own long travel kits which are coming out later this year.
    Beams37, YotaFJ, Yaboy and 1 other person like this.
  7. Mar 12, 2023 at 5:59 AM
    #607
    Taikowaza
    enjoytheridedude your build looks awesome. Re UCA, before I had my TRD kit installed I was considering a hybrid build with adventure motors combining the best parts of the TRD lift kit with a mix of other parts, I’m still hoping to make some of these changes to my current setup with them when I’m down there. I am very impressed with adventure motors.
    here’s what they had suggested, the UCA they had proposed were the Pro Comp Tubular Front Upper Control Arms. Perhaps this list can give you some ideas re: your UCA options. The exact part number wasn't listed on my quote, looking at the Procomp site here is what I found. https://www.procompusa.com/products/pro-comp-pro-series-front-upper-control-arms/
    Pro Series Front Upper Control Arms - 57023B
    Part #EXP57023B
    Primary Features
    • Direct Fit
    • 22-Current Toyota Tundra
    This is the parts list that adventure motors suggested for me, I still love this component list and want to make some of these additions.
    022 Tundra Combo Lift Kit - Fox / Dobinson IMS - Fox 2.0 Performance Front Coilovers
    - C59-559V Rear Coils
    - IMS59-60687 Rear Shocks
    - Pro Comp Tubular Front Upper Control Arms
    - Adventure Motors Rear Sway Bar Bracket
    - Adventure Motors Rear Stainless Steel Brake Lines - DBF212 - Front Duro Bump stops
    - PR59-1421 Dobinson Panhard Bar
    Note: - Fox 2.0 Performance Front Coilovers
    Toyota TRD Components - SEE SUB LIST - ESTIMATED PRICING ****
    STILL WAITING TO GET PRICE ON SOME COMPONENTS NOT
    AVAILABLE FOR INDIVIDUAL PURCHASE YET ****
    Knuckles:
    PT981-34310
    PT981-34320
    CV's:
    PT362-34310
    PT362-34320
    End links:
    PT983-34310
    PT983-34320
    PT983-34330
    Tie Rods:
    PT985-34330
    PT985-34320
    2X - PT595-34310
    PT595-34330
    PT595-34340
    Note: Knuckles:
    PT981-34310
    PT981-34320
    CV's:
    PT362-34310
    PT362-34320
    End links:
    PT983-34310
    PT983-34320
    PT983-34330
    Tie Rods:
    PT985-34330
    PT985-34320
    2X - PT595-34310
    PT595-34330
    PT595-34340
    enjoytheridedude likes this.
  8. Mar 12, 2023 at 9:52 AM
    #608
    enjoytheridedude
    Taikowaza,
    Thank you I really appreciate it! I had no idea the pro-comp UCA’s were long enough…I haven’t actually seen them put a set on the tundra with the TRD knuckles and cv axles get though..I’ll have to call them and confirm. I assumed that my Total Chaos upper control arm would work as well…and when I installed everything my camper was extremely negative so much so that I could barely drive the truck. I was driving on the inner sidewalls like I was “stanced” . The dealership ultimately had to install the TRD upper control arms.
    The TRD upper control arms are a full inch longer thanks standard and a full inch longer than all direct fit upper control arms…the reason the lower control arms are not changed is because the lower knuckle piece meets the lower control arm in the middle, it’s increased thickness is exactly one inch.
    Camburg and Mazulla off road and even icon make UCA’s that are camber and castor adjustable with heim joints but the heim joints cannot Ben adjusted a full inch without risk of breaking or coming apart due to too little overlap of threads.
    but hopefully someone decides to support this specific axle length, if not my options are either keep the TRD UCA, or get rid of the rest of the TRD kit and go to an entirety new aftermarket long travel setup.
    Taikowaza likes this.
  9. Mar 13, 2023 at 6:13 AM
    #609
    lsumatt1514
    lsumatt1514 New Member
    2020 Tundra Crewmax Platinum
    Good morning. Is there a running list anywhere on the forum of the dealers that have experience installing the TRD lift kit on the new Tundra? I don't want to be one of the local dealership's guinea pig on the install when I get ready to purchase. Thanks!
  10. Mar 13, 2023 at 6:52 AM
    #610
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Not sure but mine was done at Bill Kidd's in Timonium MD (north of Baltimore). Mine was the first one they did but I know the put the lift on new one to put on the lot.
  11. Mar 13, 2023 at 3:47 PM
    #611
    dfwtundraplat
    dfwtundraplat New Member
    How do you get the speedometer to be accurate when you out on 35’s
  12. Mar 13, 2023 at 7:17 PM
    #612
    t300
    t300 New Member
    Manitoba
    22tundra
    Thanks for the post. My interpretation is - if you are lifting the front of your truck by 2-3 inches then you should consider dropping (eg spacers) your swaybar to keep that interaction close to stock and result in improved ride vs not dropping the swaybar. Or did I completely mess that thought up in my head lol
    Taikowaza[QUOTED] likes this.
  13. Mar 13, 2023 at 7:18 PM
    #613
    t300
    t300 New Member
    Manitoba
    22tundra
    You don’t. I bought a $20 Amazon gps speedo that I put to left of my screen to remind me or someone else driving my truck of actual speed.
    ScootARoot likes this.
  14. Mar 13, 2023 at 7:37 PM
    #614
    Taikowaza
    @KroppDuster first brought this matter to my attention, posts in this forum 203, 205, and 208 (awesome information), “The only real issue in using the factory end links vs the included spacers is that it will limit your front articulation while off roading. It will prevent you from using your full amount of down travel in the front suspension” and @charlieyankee88 also had an excellent post on this topic. I learned the answer the hard way by keeping my stock sway bar spacers and end links:
    “1. Standard is not a skid plate drop. It is a sway bar relocation, so sway bar is outside of skid plate. This will not reduce articulation. It will give you max possible articulation while still maintaining sway bar. yes, only sway bar is outside skid.
    Additional benefit to this, for actual off roaders, is you can remove the sway bar easily and put it back on without removing skid. Ditching the sway bar will give you maximum articulation off road, but not recommended for on road driving.
    2. Not relocating sway bar will limit articulation.Not sure on how much. That would require comparing before and after with both configs. Not sure anyone has done that.”
    I have done this! And can compare before and after with both sway bar configs…I hereby attest that articulation is severely limited by not relocating sway bar using the kit’s spacers and end links, harsh as %*^% lol ;)
    Tundratic and charlieyankee88 like this.
  15. Mar 14, 2023 at 9:51 PM
    #615
    Frozen.Tundra
    Frozen.Tundra New Member
    2022 Army Green 1794 6.5 TRD
    Just got the Trd lift done, really think it came out with better proportions.
    35x12.5x20 ko2s , stock Trd rims and a very slight rub when fully locked.
    hefty price tag for the lift but it drives incredible, really feels stable and responsive on road.
  16. Mar 15, 2023 at 4:55 AM
    #616
    Silver23
    Silver23 New Member
    nice!! how long did it take for the install? My dealer is telling me Toyota says its a 14hr job and that is what I have to pay for. If it goes over, that's on them.
  17. Mar 15, 2023 at 6:48 AM
    #617
    cruiserhead
    cruiserhead New Member
    I was just quoted from one dealer $2350. They said takes 2 days. I don't know what that is in hours (16?). It seems the consensus so far has been around a 20 hour job, so 14 seems not bad.
  18. Mar 15, 2023 at 8:24 AM
    #618
    Frozen.Tundra
  19. Mar 15, 2023 at 9:24 AM
    #619
    Silver23
    Silver23 New Member
    My dealer had told me Toyota says it's a 14hr job (@ 105/hr), so I'm preparing myself to spend around $1470 for installation. I wonder if alignment is included or if that's an extra charge? My kit with shipping is $2652. Yeah, I can see myself having to order the bed step and one of those trailer hitch cargo carriers. I'm 5'5" and I don's see myself loading up a deer in the bed after the lift is installed!! LOL.
  20. Mar 15, 2023 at 9:28 AM
    #620
    nodak67
    nodak67 New Member
    JR
    trust me they will get every scape of blood out of that rock they can, nothing is included :)
  21. Mar 15, 2023 at 9:33 AM
    #621
    Silver23
    Silver23 New Member
    That's what I figured.
  22. Mar 15, 2023 at 9:47 AM
    #622
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    I'm 6'2", on my 22 I had the TRD lift put in and the side of the box was shoulder height. So about as tall as you are.
  23. Mar 15, 2023 at 3:39 PM
    #623
    TundraLtdCO
    TundraLtdCO New Member
    Daniel
    2022 Tundra Limited TRD
    Is anyone able to help me out??
    Do you think that I'll need to get this 2" spacer pack if I'm going with the LoadLifter 5000 airlift bags? I have the TRD lift on my 22' Limited Tundra. I almost wonder if it's overkill for the minimal lift in the back of the truck.
    Thoughts... and thank you!
    Air Lift 2" Universal Spacer for Air Spring Kits
    https://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=53749
    https://www.sdtrucksprings.com/inde...=59000&zenid=9abf6ccdb7298983e1b8175067c38462
  24. Mar 15, 2023 at 6:44 PM
    #624
    Silver23
    Silver23 New Member
    Don't know if I'm lucky or not but I ordered my TRD lift from sparksparts on Tuesday 14March and got an email today along with a text from FedEx stating it shipped with an arrival date of Friday 17March. Calling my dealer in the morning to schedule the install.
    Yaboy likes this.
  25. Mar 16, 2023 at 10:09 AM
    #625
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    That's good news you gotta take pics of before & afters...
  26. Mar 16, 2023 at 10:56 AM
    #626
    Silver23
    Silver23 New Member
    I certainly will. Spoke with the dealership this morning and they will let me know if they can take it next week (mainly depending if they have a vehicle for me to use). They just completed their first install and the manager said it took them two days. Glad mine isn't the guinea pig.
  27. Mar 17, 2023 at 11:36 AM
    #627
    YotaFJ
    YotaFJ New Member
    Marcelo
    Seattle
    2023 WCP Hybrid 1794 TRD
    Leitner Forged ACS Decked system TRD Skid Plate TRD Running Boards Tacotunes cat shield Chrome delete in process
    Well, I'm not having luck getting tires to fit on my truck. TRD lift at the dealership two weeks ago and the Method 705 18" +18 offset rubbed on the frame with 35x12.5 Toyo ATIIIs, so Discount ordered Falken AT3s in 285/75/18 and they also rub on the frame. I guess it's time to find a place to get it chopped. Just slightly frustrating given I've read that 35s fit with that wheel setup in addition to the slightly smaller 285/75/18s for other people on the forums and FB groups.
  28. Mar 17, 2023 at 11:39 AM
    #628
    sctomfar
    sctomfar Chasing 700RWHP
    Tom
    Bluffton, SC
    Supercharged Reg cab
    Harrop 2650 supercharger TRD suspension TRD intake Custom exhaust Dirtydeeds cross pipe Fully built bottom end motor Manly Rods Crowder Pistons ARB Stud Kit National Speed Tuned Redesigned fuel system XAT Fuel Rails Twin Demon Fuel Pumps 83cc Injectors Morimoto Headlights
    we have done 3 of them at the dealership i work at. they are great.
  29. Mar 17, 2023 at 11:51 AM
    #629
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Puzzling indeed
    Yaboy likes this.
  30. Mar 17, 2023 at 12:51 PM
    #630
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    How bad is the rubbing, show some pics of where it’s touching the frame
