2023 Tundra Damaged lower grill
Discussion in '3rd Gen Tundras (2022+)' started by Markysharky, Mar 14, 2023.
  1. Mar 14, 2023 at 7:58 AM
    Markysharky
    Markysharky [OP] New Member
    Hit a chicken and broke part of the lower grill. Can just that section be replaced and does anyone know the part number? Thanks.
  2. Mar 14, 2023 at 8:01 AM
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Light bar fits good there
  3. Mar 14, 2023 at 8:02 AM
    nodak67
    nodak67 New Member
    JR
    installed a light bar and be done with the replacement.
    light bar probably be cheaper than to replace just that part since you have to buy a whole grille?
    not sure, have to ask roman
    Eurodriver and Yaboy like this.
  4. Mar 14, 2023 at 8:38 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    I agree with others. Slap a light bar in there. It's easy, fixes your problem (you're already half way there with the cutting), and it adds functionality.
    If you don't want to go that route, then it looks like you're in for a bit of a project. That grill "lattice" work (I'll call it that) is actually part of the larger lower grill support structure. You'd be taking off most of the front clip to replace that.
    Markysharky[OP], Sean492 and Yaboy like this.
  5. Mar 14, 2023 at 10:21 AM
    Markysharky
    52117f is a general part number for the front bumper used for various Toyota models? Am I missing something?
  6. Mar 14, 2023 at 10:27 AM
    KroppDuster
    Bilstein 5100s
    You've got to navigate the parts.toyota.com system.
    I'll save you a little time though. Here's the direct link to the part # (521170C040): https://parts.toyota.com/p/Toyota_2...t-Rail-Front--Upper/105892805/521170C040.html
    Check out the sticky thread at the top of the forum by @shifty`: HOWTO: Use the Toyota Parts system to find & order parts. That will help for future parts queries.
  7. Mar 14, 2023 at 10:49 AM
    Markysharky
    I think the confusion was the image doesn’t show the grill cross hatch pattern on the diagram. Thanks for the help!
  8. Mar 14, 2023 at 10:57 AM
    KroppDuster
    Bilstein 5100s
    The parts diagrams aren't the highest res images, but it's there.
    I know because I've dismantled & reinstalled the grill twice as I've done some front upgrades. Pic of the backside of my grill when I had it off. The yellow part is the grill work that you've damaged (the chicken) and the red outline is the support structure.
  9. Mar 14, 2023 at 11:00 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    So, is the yellow lower grille part available separately or just come with that entire assembly? Just curious.
    Markysharky[OP] likes this.
  10. Mar 14, 2023 at 11:04 AM
    KroppDuster
    Bilstein 5100s
    Most other parts are available separately. However, that particular grill work is part of the mold of that entire support assembly:
  11. Mar 14, 2023 at 11:05 AM
    raylo
    Frederick, MD
    That's what I figured since there was no pop out for it. Who'd have thunk they'd make it like that? Oof.
  12. Mar 14, 2023 at 11:07 AM
    KroppDuster
    Bilstein 5100s
    I agree. That type of stuff should really be a sub section with separate fasteners for easy replacement. It's also quite pricy. Maybe $20 or $30 in raw plastic but the MSRP is well over $400. Though I'm sure you could find it cheaper on sale by cross shopping dealership.
    raylo[QUOTED] likes this.
  13. Mar 14, 2023 at 11:08 AM
    Markysharky
    Turned about to be one expensive suicidal bird.
    raylo and KroppDuster like this.
  14. Mar 14, 2023 at 11:09 AM
    raylo
    Frederick, MD
    But at least now we know why the chicken crossed the road... to break the OP's Tundra grille.
  15. Mar 14, 2023 at 11:10 AM
    Markysharky
    Looking at it the grille area appears to be snapped in from behind but not sold as a separate part number. Kroppduster you are the man!
  16. Mar 14, 2023 at 11:10 AM
    raylo
    Frederick, MD
    Yeah, like almost $200/lb.
    KroppDuster likes this.
  17. Mar 14, 2023 at 11:10 AM
    KroppDuster
    Bilstein 5100s
    If there is any silver lining, it's that replacing this is pretty easy. Tons of people have done grill swaps so there's a lot of documentation & many YT vids about dismantling the front. It's an easy job. Just time consuming. Give yourself a six pack and about an afternoon...you'll knock it out easily.
  18. Mar 14, 2023 at 11:13 AM
    Markysharky
    I’ve replaced body and interior panels before and torn dirt bikes down to the frame. Think I can handle those pesky bolts and plastic clips
    Eurodriver and KroppDuster like this.
  19. Mar 14, 2023 at 11:20 AM
    Markysharky
    My game with women is so bad the only thing I can hit on is a broiler chicken and I killed it, fml.
  20. Mar 14, 2023 at 11:29 AM
    raylo
    Frederick, MD
    Pro tip: when you hit on women, don't use the front of a Tundra. Be gentle!
  21. Mar 14, 2023 at 11:57 AM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    In the 90s some would put Home Depot chicken wire mesh in our Hondas.
    Yaboy likes this.
  22. Mar 14, 2023 at 12:19 PM
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    I remember that being a thing also. Weird times
  23. Mar 14, 2023 at 12:23 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Definitely dumb. Just wanted to keep the chicken theme alive here.
    raylo and Markysharky[OP] like this.
  24. Mar 15, 2023 at 6:47 AM
    Tom976
    Tom976 New Member
    Tom
    Call foul on that fowl. Looking at the damage I would have thought you hit a butterfly.
    raylo likes this.
  25. Mar 15, 2023 at 1:58 PM
    OnThaLake
    OnThaLake New Member
    Must have been a big chicken!
    raylo likes this.
  26. Mar 15, 2023 at 2:20 PM
    raylo
    Frederick, MD
    Or maybe this one". ;-)
    Siblue and OnThaLake[QUOTED] like this.
  27. Apr 10, 2023 at 1:11 PM
    Markysharky
    Finally swapped it out. About 25 screws and clips, it’s not hard but tedious. Took a good two hours and a few beers to swap it out. Would classify as a medium difficulty just cause of all the clips and stuff that could break during the process. Didn’t feel like putting a light bar and hacking up the bumper and wiring. Not sure how much longer I’ll own this truck.
    For a full size truck the bumper support is very thin plastic like a kids toy lol
    4genRunner, OnThaLake and raylo like this.
  28. Apr 10, 2023 at 8:18 PM
    Tom976
    Tom976 New Member
    Tom
    I'd say thats some thin plastic too .... how much are the replacements?
    Toyota should be ashamed of the strength of these grills. There's some expensive hardware in that nose that needs protection!
    Now if they make things thin and fragile, then produce those parts in large amounts (making it cheap)
    At least people wouldnt be that annoyed. Wonder what the aftermarket world is going to do.
  29. Apr 10, 2023 at 9:19 PM
    Markysharky
    With oversized shipping about $550.
  30. Apr 11, 2023 at 7:49 AM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    This 10lb piece of pavement got kicked up by a tractor trailer in front of me. Went right through the fog light in my 2014 Platinum Tundra. This was a $1500 repair caused by a few dollars of asphalt. :itllbuffout:
