General Turbocharger Thread (formerly "Turbo Charging A Tundra!")
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Mar 14, 2023 at 4:20 AM
    #421
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    It is boost activated and it is metered by the amount of boost. If you are not in boost then it is not running.
    some articles state it lowers temps by up to 50 plus degrees if I remember correctly
    nobodyintexas likes this.
  2. Mar 14, 2023 at 4:35 AM
    #422
    coTony
    Tony
    Montrose, CO
    So you said if some owners don’t want to take the jump… I am following closely and want more details on where to get it installed and price. Keep up the good work!
    MTRock, reywcms and TurboKits[QUOTED] like this.
  3. Mar 14, 2023 at 4:45 AM
    #423
    Black@Blue19
    Ken
    SE Texas
    To me it is way more less complicated than adding a super charger. Any good mechanic shop is able to do the work. It will come with instructions just like the supercharger. The spark plugs are the only thing to change on the engine on the Stage 1. The wiring of the water/meth system is the only other detailed addition, the rest is pretty much bolt on.
    The Stage 2 is when new injectors, and a new fuel pump would be added along with the intercooler.
    oops I probably should have let Jesse answer that. If I messed up anything he will fix it!:)
    TurboKits and coTony[QUOTED] like this.
  4. Mar 14, 2023 at 4:57 AM
    #424
    coTony
    Tony
    Montrose, CO
    So just about the same as a SC purchase and install. Looking at everything under the hood I would be in trouble fitting a Stage 2 kit
    reywcms and Black@Blue19[QUOTED] like this.
  5. Mar 14, 2023 at 5:51 AM
    #425
    Not sure how this is less complicated than the supercharger install. Not buying that.
  6. Mar 14, 2023 at 5:53 AM
    #426
    centex
    centex New Member
    The stage 1 probably is. Remove exhaust manifolds, install new manifolds and piping, connect to intake, install water meth. That's pretty simple. The stage 2 with the fuel system and intercooler is probably about the same.
    M3Tundra-JK likes this.
  7. Mar 14, 2023 at 6:07 AM
    #427
    TurboKits
    TurboKits New Member
    Stock headers remain in place... So you don't even have to remove those (on either stage of the kit) :)
  8. Mar 14, 2023 at 6:14 AM
    #428
    centex
    centex New Member
    Now that's interesting. That really simplifies things. I'm thinking a stage 1 with an intercooler would be the bees knees for most users.
    M3Tundra-JK, TurboKits and mZiggy like this.
  9. Mar 14, 2023 at 6:16 AM
    #429
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    I concur.
    TurboKits likes this.
  10. Mar 14, 2023 at 6:57 AM
    #430
    Kung
    KG, VA
    That's exactly what I'm looking at, depending on pricing. :)
  11. Mar 14, 2023 at 7:03 AM
    #431
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Is it up to the end user to acquire custom tuning for the turbo kit, or is there a base file utilizing tuning software such as HPtuners with credits and a flash tool provided in the kit to get it on the road like supercharger kits have?
    reywcms and Saltyhero13 like this.
  12. Mar 14, 2023 at 7:05 AM
    #432
    TurboKits
    We have a 2007-2021 base maps, you will need HPT or a local HPT tuner to flash and adjust the file to your exact truck set up, location, fuel, etc... But It won't be a from scratch scenario. The HPT & Credits will not be included in the kit, as we do not want to lock people into buying something they may have already or a friend or a local tuner that can do it...
  13. Mar 14, 2023 at 8:21 AM
    #433
    Silver17
    Eastern PA
    That’s cool. So buyers should count on spending around $600 if they’re going to buy the HP MPVI2 tool and credits to tune it themselves or have a remote tuner handle the tuning, and whatever the tuner charges ($500-800). Or alternatively just take it to a tuner and have it tuned but not have the ability to data log or make adjustments on their own.
  14. Mar 14, 2023 at 8:22 AM
    #434
    TurboKits
    Correct, many options ranging from DIY to set and forget!
    Saltyhero13 and Silver17[QUOTED] like this.
  15. Mar 14, 2023 at 8:23 AM
    #435
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    how do you initially drive it home from the install?
  16. Mar 14, 2023 at 8:24 AM
    #436
    mZiggy
    mZiggy Honey badger
    Marc
    Carefully ;)
    snivilous, Kung, Silver17 and 4 others like this.
  17. Mar 14, 2023 at 8:34 AM
    #437
    TurboKits
    One would assume if you are getting it professionally installed, that the base map loading and tuning would be part of the deal. HPT is a widely used and known platform, there should be a tuner on every corner really.
  18. Mar 14, 2023 at 8:47 AM
    #438
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I could not find any in a 1 hour radius of my location. I don’t live out in the sticks either.
    Saltyhero13 and Silver17 like this.
  19. Mar 14, 2023 at 8:52 AM
    #439
    Silver17
    Eastern PA
    Being in the same local area as you, I know what you really mean is there are tuners around….Whether or not they have any interest in tuning your tundra is another story.
    snivilous and Saltyhero13 like this.
  20. Mar 14, 2023 at 9:04 AM
    #440
    ZPhilip
    Philip
    West Chester, PA
    That’s what I meant. Nobody wanted to touch the Tundra tuning aspect. And my install shop doesn’t touch HP Tuners on anything.
    Saltyhero13 likes this.
  21. Mar 14, 2023 at 9:06 AM
    #441
    centex
    centex New Member
    Not many that actually do Tundra's. I have a hard time finding one that does HPT for my Durango. Majority are LS or Ford houses.
  22. Mar 14, 2023 at 9:11 AM
    #442
    nobodyintexas
    nobodyintexas What?
    South of Houston
    This.
    Luckily Houston has a couple of nice tuning houses. Pietz & Prospeed.
    I played hell trying to get a place to put in my gauges....much less a 3rd party turbo system.
  23. Mar 14, 2023 at 9:17 AM
    #443
    TurboKits
    You need to explain to them you are getting a base map that came from a fully tuned Tundra and all they need to do is load and adjust... They are probably thinking they have to build from scratch...
  24. Mar 14, 2023 at 9:18 AM
    #444
    Black@Blue19
    Ken
    SE Texas
    reywcms likes this.
  25. Mar 14, 2023 at 9:19 AM
    #445
    TurboKits
    We've done everything remote on My personal tundra and on Kens...
  26. Mar 14, 2023 at 9:24 AM
    #446
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    +1 for remote tuning. Literally doing that right now with OTT. It's not hard. Just follow the on screen prompts. Flashing the truck is basically the same as updating any computer component firmware.
    Black@Blue19 likes this.
  27. Mar 14, 2023 at 9:25 AM
    #447
    Silver17
    Eastern PA
    I inquired with OTT about simply scaling the MAF on my otherwise complete tune I’d been running for over a year and 7k miles when I switched to a larger intake. I thought it would be a cheap minor adjustment. They refused to modify another file and said they can’t verify that the tune they are modifying is safe so they wanted to charge me $750 to start from scratch. I guess it depends what level of liability the tuner you’re dealing with is willing to accept.
    It’s fine to start from scratch, I’d just be prepared for remote tuners to not want the base file and want to do it on their own. You can get it tuned one way or another, I’d just be prepared to pay full price for the tune is all.
    Saltyhero13 and M3Tundra-JK like this.
  28. Mar 14, 2023 at 9:25 AM
    #448
    Black@Blue19
    Ken
    SE Texas
    For the Houston crew keep this name if you want anything that involves speed or any work needed being done.
    Excessive,,, and they will be at the track Wednesday thru Sunday with their vehicles they have done,,,, including a friends Vette that is awesomely fast
  29. Mar 14, 2023 at 10:26 AM
    #449
    Saltyhero13
    Saltyhero13 Throbbing Member
    "Are you ready to play the "no boost" game? Click yes to begin and yes to begin"
    Silver17 likes this.
  30. Mar 14, 2023 at 10:36 AM
    #450
    TurboKits
    Ha Ha, it's really not hard to stay out of boost on a set up like this. We were doing a turbo project on a Hyundai Genesis V6, single turbo, similar configuration to the Tundra, albeit a smaller turbo for the smaller motor, but we had to wait almost 4 months for the tuner to fly out from Korea to tune it. At the time, the customer, whom was also a close friend of the companies. Daily drive the car 20+ miles to and from work. Of course this was the 3rd or 4th project we had done with him, he was in fact a tuner himself, so he understood in depth what was going on, but he managed 4 months / 4K miles without a tune...
    Saltyhero13[QUOTED] likes this.
