Turbo Charging A Tundra!
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Mar 10, 2023 at 6:32 AM
    #391
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  2. Mar 10, 2023 at 6:34 AM
    #392
    centex
    centex New Member
    Properly size they do a great job. Will be curious to see what they look like after some sustained runs and heat soak but I don't think they'll be that bad. Keep up the good work.
  3. Mar 10, 2023 at 6:48 AM
    #393
    TurboKits
    TurboKits New Member
    LOL or here! https://www.turbokits.com/aem-v3-water-methanol-injection-kit.html
    But in all seriousness, we love water meth, been running it on kits since 2005, back when we had to get the aquamist kits from the UK. Its cheap insurance and emulates running 100oct but with pump gas and only when in boost, plus the charge cooling. It's really is a no brainer on ANY FI motor. Especially the newer direct injection motors with carbon buildup, the water meth can help keep that down (if started from new or cleaned engine). Anyway, there are just a lot of benefits and we love it...
  4. Mar 10, 2023 at 7:11 AM
    #394
    M3Tundra-JK
    Scott
    2005 GX470
    Cool, I'd rather purchase from someone active on the forums! What's the difference between the two linked products? I can't see any from pics. Just that one says Tundra, and the other Honda. Guessing the wiring/mounting brackets?
  5. Mar 10, 2023 at 7:12 AM
    #395
    Saltyhero13
    Saltyhero13 Throbbing Member
  6. Mar 10, 2023 at 7:16 AM
    #396
    TurboKits
    Nothing that I can tell, their site is misleading a bit by saying it will fit the Tundra. It's universal, it would work on a lawn mower if you installed it properly, LOL. So keep that in mind, these are universal, so you have to mounts them, wire them, run the pump and lines, etc.
    M3Tundra-JK[QUOTED] and RobertD like this.
  7. Mar 10, 2023 at 7:29 AM
    #397
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    How would you implement it? Everyone always says the meth eats the coating on the SC rotors. You would have to inject it post rotors by drilling and tapping a fitting into each intake runner. Sounds pricey.
  8. Mar 10, 2023 at 7:37 AM
    #398
    M3Tundra-JK
    Scott
    2005 GX470
    Oh, no idea lol. It hasn't gotten past the, "Hey that looks cool I could probably use that" phase of thinking. That looks like a lot of work, probably won't happen
    mZiggy and Silver17[QUOTED] like this.
  9. Mar 10, 2023 at 7:43 AM
    #399
    Saltyhero13
    That's a nice kit. May be easier to design a riser with ports.
  10. Mar 10, 2023 at 7:58 AM
    #400
    centex
    centex New Member
    I've used the snow kits in the past but they are all fairly simple. The kit I used was boost referenced and progressive so as the boost started to rise, the system would inject more. Below a certain threshold it wouldn't spray. They are pretty universal and basic.
    Black@Blue19 and Saltyhero13 like this.
  11. Mar 12, 2023 at 7:05 PM
    #401
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Tuning this time seems to be moving right along, the hold up has been the snow storms. I imagine that if they could get some clear weather that lasts for a few days the tuning could be complete! Again, once the tuning is complete back to the Dyno for the final run:)
    omgboost, RobertD and TurboKits like this.
  12. Mar 13, 2023 at 6:08 AM
    #402
    TurboKits
    Got the go ahead from the tune to test higher boost, had to get prepared for an almost 2ft of snow, storm, coming in tonight through Wednesday, but was able to get the boost up to 5.5-6 PSI and get some logs to the tuner... Wanted to keep posting the IATs from the logs for everyone to see. It was 36* the ride in this AM, 41* IATs cruising, 46* at the top of a 6 PSI peak boosted run...
    Toyotoholic, mZiggy, reywcms and 5 others like this.
  13. Mar 13, 2023 at 7:17 AM
    #403
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    is it "normal" for a turbo engine to only add 10 degrees of IAT?
    or is this exceptional?
  14. Mar 13, 2023 at 7:26 AM
    #404
    TurboKits
    A properly sized intercooler will do wonders bringing the intake temps down as close to ambient as possible.
  15. Mar 13, 2023 at 9:54 AM
    #405
    Saltyhero13
    Meth works wonders too:
  16. Mar 13, 2023 at 10:00 AM
    #406
    TurboKits
    Yeah I didn't want to say that those are the IATs before Meth comes into play, since the meth nozzle is after the MAF and not part of the IAT readings, but yes, the meth is then taking this small differential and bringing it back down to ambient or even a few degrees lower! We are a big fan of Water Meth, I personally have it on both my personal turbo tundra and my sport car.
  17. Mar 13, 2023 at 10:06 AM
    #407
    Saltyhero13
    Good to know when we are looking at these logs. Thanks.
  18. Mar 13, 2023 at 10:09 AM
    #408
    TurboKits
    Vizsla and Saltyhero13[QUOTED] like this.
  19. Mar 13, 2023 at 10:23 AM
    #409
    Saltyhero13
  20. Mar 13, 2023 at 12:22 PM
    #410
    Silver17
    Eastern PA
    Don’t get me wrong, air to air intercoolers work great, but this data is a poor representation of the reality of the IATs. Cruising along on a 30 degree day when not making any boost like on this log, the cool ambient air pre-cools the whole mass of the intercooler to 30ish degrees. Then we are shown a 55% throttle pull at low boost for a very brief period from 45-72mph looking at this log. The minimal heat discharged over that brief low boost pull is not going to present a scenario that will ever heat up and saturate the intercooler (especially in it’s pre-cooled state), and show true IATs under a sustained boost scenario. The point is we aren’t concerned with IATs on a 30 degree day for a 5 second pull from 45-70mph. That’a not why there is interest in the IATs.
    I understand @TurboKits.com is showing us this just to show the IAT data he has available so far at the current tune limitations. He’s showing us what he has, but this little snippet of data doesn’t really tell us what we want to know. What we really want to see is the IATs on a 100 degree Texas day on a sustained boost pull from 0-100mph like on a 1/4 mile strip; or IATs pulling a 9,000lb travel trailer up a steep grade for 2+ miles.
    If you a want to know the real IATs of a given scenario then enter them into this calculator. Input temp will be underhood temp in this case. A Generous efficiency input for the turbo is 75%, and a generous efficiency input for an air to air intercooler is 70%. Plug some numbers in and you will see the reality of what to expect.
    http://stealth316.com/2-turbotemp.htm
  21. Mar 13, 2023 at 12:58 PM
    #411
    TurboKits
    Just trying to dump info as we have it... Thanks for your input. Working with TurboKits.com will not be for everyone and we understand that...
  22. Mar 13, 2023 at 5:20 PM
    #412
    Saltyhero13
    We'll I for one appreciate how you've graciously answered questions and shared information about the development of this kit. Clearly this isn't the first truck platform you've fabricated a turbo kit for as your personal and business reputation precedes you.
    As far as addressing skeptical forum questions, we mean well even if it is hard to sense tone and intent from some of our comments. Modifying trucks comes with trade offs; these questions are aimed at helping understand what those trade offs will be with a turbo kit.
    At this stage it will be difficult to know all the answers based on a one off prototype run, especially for a new platform. Some of these answers will only shake out as more owners adopt the kit and run their trucks through the gauntlet of "truck duty" activities.
  23. Mar 13, 2023 at 6:39 PM
    #413
    TurboKits
    That was what I was getting at as well, glad we are on the same page! We only have the info we have, the rest is speculation. If that means some owners don't want to take the jump until that info is out, great, we'll keep building and testing and posting our and customers feedback until we have all of the info possible out there for everyone. Thanks again!
    Toyotoholic, coTony, omgboost and 7 others like this.
  24. Mar 13, 2023 at 7:00 PM
    #414
    Silver17
    Eastern PA
    Don’t misunderstand my questions as anything but excited and curious to see the results of the kit and am happy to see more support for the platform. I think it looks like a nice kit! Just prodding for answers that I understand we don’t have yet, but are nonetheless important considerations for potential purchasers depending on how they use their truck. My intent is to make suggestions on providing some important info possible buyers may like to see and then when possible see it recorded and presented in a way that doesn’t leave anything to question.
    The IATs we have so far look great, I’m looking forward to seeing how it looks under sustained boost runs. If it’s within 50 degrees of ambient on a long pull in high heat at full boost (without the meth) I think that is a success.
  25. Mar 13, 2023 at 7:11 PM
    #415
    centex
    centex New Member
    The only question I have is regarding pricing. I’m gonna assume 8-10k uninstalled.
  26. Mar 13, 2023 at 7:13 PM
    #416
    TurboKits
    The IATs will always be "without meth" since our meth nozzle is after the IAT sensor, so even tho the meth is helping cool the intake charge and increasing the active octane rating of the fuel, it is not ever going to be part of the IAT readings in the HPT logs. That info would be purely what he turbo and intercooler can do.
  27. Mar 13, 2023 at 7:14 PM
    #417
    TurboKits
    Stage 2 less
    Stage 1 much less
    We'll release the #s once we have the stage 2 layout 100% and can get it all quoted from our mandrel bender, but our plan when we started was to give the same if not more power for less $$ than what is currently out there.
  28. Mar 13, 2023 at 7:50 PM
    #418
    centex
    centex New Member
    You had my interest but now you have my attention.
  29. Mar 14, 2023 at 2:41 AM
    #419
    Silver17
    Eastern PA
    Yup I understand that. The difference for me is I personally don’t want to depend on a meth system on my pickup truck so any benefits it may have wouldn’t be considered anyway in my case.
  30. Mar 14, 2023 at 4:02 AM
    #420
    nobodyintexas
    nobodyintexas What?
    South of Houston
    questions:
    at what temp does the meth activate?
    is it a single dose or is the amount metered to IAT or boost?
    How is the true meth-supplemented IAT known if the sensor is before the meth?
    I'm a simple supercharger caveman so speak as if I'm a toddler or a golden retriever.
    reywcms and Saltyhero13 like this.
