For those with Ditch Lights
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Mar 9, 2023.
  1. Mar 9, 2023 at 4:24 PM
    Buellride
    Buellride [OP] New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    Which manufacturers have the lowest profile brackets? I really don't want the ditch lights to protrude like awkward after market accessories. I saw on Westcott's site that they have lowest profile brackets...IDK. Turning to the experts on this forum....thanks in advance.
  2. Mar 9, 2023 at 5:18 PM
    bballjames
    bballjames New Member
    Inland PNW
    22 Tundra Platinum 4x4 Hybrid Crew Max 6.5ft bed
    I can't comment on the Westcott, but they look a lot lower profile than mine from DD. I have a few pictures on a different thread (ignore my sob story about my headlights...), but just looking at the Westcott site, I can tell theirs are a lot closer to the hood than mine. Those sure are a pretty penny though at $190...
    https://www.tundras.com/threads/be-careful-with-your-headlights.120738/
  3. Mar 9, 2023 at 5:20 PM
    Buellride
    Olympia
    THE BOULDER
    Damn I remember reading your story...that is really awful luck. On the Westcott brackets..I hear you but everything from them is pricey.
  4. Mar 9, 2023 at 5:22 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The brackets all seem to be about the same sort of profile height as there's only so much you can go towards the hood without the bolt that keeps your light pod attached hitting the hood. My recommendation is to look at the size of light you attach to it.
  5. Mar 9, 2023 at 5:45 PM
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
    V3N0M likes this.
  6. Mar 9, 2023 at 6:46 PM
    2020cement_tundra
    SC
    2020 tundra
  7. Mar 9, 2023 at 8:40 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Rago sit pretty close
    FrenchToasty and V3N0M like this.
  8. Mar 9, 2023 at 11:29 PM
    V3N0M
    V3N0M New Member
    Orange County, CA
    2020 Tundra SR5 Crewmax
    - Carven Type R Exhaust - TRD LED Headlights - (2) LED Ditch Lights Mounted on Hood - Cali Raised Ditch Light Brackets - (2) 42” LED Light Bars Behind Grill - Cali Raised Hidden Grille Mounting Brackets - AJT Interior Chrome Delete - AJT V3 Shift Knob - 8" ReadyLift w/ Bilstein 5100's (all around) - 18" Raceline 948B Split Wheels - Toyo Open Country MT 37 x 13.50 R18 - Amp Research Power Steps
    435F1FB3-647B-4BA1-8D74-A7038A9F13F8.jpg I have the Cali raised brackets as well, the profile is low. I definitely recommend them.
  9. Mar 10, 2023 at 8:59 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    I run DLs on my truck since it's pitch black out where I live out in the boonies.
    The biggest difference, to be honest, is not so much the hood bracket but your choice of light pod. If you want as "slim" of a look as possible, then go with a 2-light pod design instead of a 4-light pod. Higher quality lights will also have lower profile mounting brackets (the silver part in my pic below).
    I run Rigid lights for the most part, but I had these cheap Chinese light pods from Amazon sitting around. I'll use them until they fail. They're definitely a larger body profile & taller bracket than higher quality lights from places like Rigid & DD. Look at the pic at the bottom and you'll see how much closer the Rigid bracket sits to the pod housing than the cheap ones I have right now.
    NewImprovedRon likes this.
  10. Mar 10, 2023 at 10:50 AM
    STEPBRO
    STEPBRO New Member
    2022 SR5 TRD OR
    +1 for Rigid. Good middle ground brand for those not looking to spend a mortgage payment for LED lights.
  11. Mar 11, 2023 at 6:12 PM
    TrailKiller
    TrailKiller New Member
    CJ
    540 Virginia
    2023 TUNDRA SR5 BLUEPRINT 4x4 Factory Lift & Loaded
  12. Mar 12, 2023 at 5:39 AM
    wildmank99
    wildmank99 New Member
    Arizona
    22 Tundra Limited
  13. Mar 12, 2023 at 4:37 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here is what I've got.
  14. Mar 12, 2023 at 4:43 PM
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    RC lights and bracket. Lights are ok and do the job but going to change them out to Diode Dynamics. 6E5C37CF-D8B4-4C6D-8EC9-00F62524FFD8.jpg
    Buellride[OP] likes this.
  15. Dec 30, 2024 at 6:17 PM
    22TundraSr5
    22TundraSr5 New Member
    Heather
    2022 tundra SR5
    How did you get the plastic cowling back on after mounting the bracket? I tried and tried until I was ready to break something and finally said screw it and took everything off the truck because I could not for the life of me get that plastic cowling to seat back properly with the bracket that rough country supplies with those ditch lights.
  16. Dec 30, 2024 at 7:04 PM
    2020cement_tundra
    SC
    2020 tundra
    Shouldnt need to remove anything except for hood bolts, mine were Caliraised brand so maybe yours are different
  17. Dec 30, 2024 at 8:08 PM
    PhatRay
    PhatRay New Member
    Ray
    2024 Tundra Platinum
    N/A
  18. Dec 31, 2024 at 6:23 AM
    Hunter1699
    Hunter1699 New Member
    These are what I have and worked great and low profile.
    Spickett78 likes this.
  19. Jan 4, 2025 at 11:48 AM
    timc74
    timc74 New Member
    Them brackets are ok for small lights but I tried them with Baja Design XL80s and they shook real bad so I installed SDHQ pillar mounts. They might be ok with the smaller BD Squadrons
