Linex Ultra
Discussion in '2.5 Gen Builds (2014-2021)' started by mesquitemag24, Sep 9, 2022.
  1. Sep 9, 2022 at 3:40 AM
    mesquitemag24
    mesquitemag24 [OP] New Member
    J
    2021 Tundra Limited
    Wanted to get everyone's thoughts on this topic. You're either going to love it or hate it, but to each their own.
    This is my second Tundra, first one was a '15 with 300k before I traded in for a brand new '21 Limited in Mesquite Brown. I've had it for just under a year and use it for work, which is in a rural area with 90% gravel roads all day everyday. I took everyone's advice and decided to have it professionally wrapped for paint protection - the problem is, doing the amount and type of driving I do, it ate the 3M wrap up in a matter of months. Chips, scratches, everything even wore through the paint. Living in the Midwest, these are now prone to rust and further damage.
    I keep my trucks basically until they die, so resale is not my biggest concern.
    I didn't Line-X the truck because the general consensus was that people hated it, it wasn't functional, the entire thing. But now, I have an option to either try and patch a whole bunch of paint, get the paint Kevlar painted (very limited availability) or Line-X the whole thing in a color-matched Ultra coating for protection.
    Any insights from the group?
  2. Sep 9, 2022 at 6:36 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    my 2 cents. TLDR; I am on the fence about it due to the truck being so new but understanding your useage.
    I have seen quite a few FJ cruisers, 4 runners, and jeep wranglers with a linex type coating in Arizona for running in the dessert against the sharp foliage there. It looks good but I don't know how much those people really use their vehicles off road or if they do it just for a look.
    I have a friend that did his old farm truck and turned it into his daily driver after he was done with a DIY job. its been on there 5+ years and is holding up great on the parts he did with it. He isn't doing the kind of driving you are and he has rust issues on the underside of the truck but its an 04 ford and it was really beat up before he did it. The salted Midwest winters are pretty hard on things.
    I wouldn't hesitate on an older vehicle that has taken its depreciation hit. I would consider doing mine if I still have the truck in 10+ years and it is showing significant wear, as in i would probably be daily driving a different car and want to keep the truck for truck stuff. I'm not sure how I would feel about doing it to a 1 year old truck, even covered in scratches. I had the whole drivers side of my truck repainted due to some blemishes in the paint from the previous owner, looked like brake fluid dripped all over it. Was about 4k to have one side done.
    The paint on these trucks seems a lot thinner than the 2010 Tacoma I had.
    I really like the look of it, but as someone that used to work in detail I'm not sure how easy it would be to clean.
    Another consideration would be trying to match color and texture if you ever ended up needing to replace a panel or fix any damage.
  3. Sep 9, 2022 at 6:45 AM
    mesquitemag24
    J
    2021 Tundra Limited
    I'm honestly on the fence about it too. I was considering painting it but for an actual quality paint job I'm looking at close to 20k versus 8-10k for Linex ultra custom tint. I religiously Fluid Film all our trucks because of the winter and salt usage but my last Tacoma started rusting regardless unfortunately. I appreciate your input, I just don't want to keep throwing money for bandaids when I can take care of it all at once
  4. Sep 9, 2022 at 6:57 AM
    Beach Toy
    Beach Toy New Member
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    I ran into a paving contractor at the hardware store (yes, a legit, ol skool hardware store) a few years ago that had a Rhino'd Tacoma. He said it was a company truck before he drafted into his hunting rig. After that he saw the job and color, and how it held up, he Rhino'd all of his work trucks. Food for thought.
    TundraMidwesterner likes this.
  5. Sep 10, 2022 at 3:41 AM
    mesquitemag24
    J
    2021 Tundra Limited
    I've seen the ones done professionally and they look great
    I think people dislike the look of the ones that are done with spray cans or by people trying it out getting that dull chalky look
    Thanks for the insight!
  6. Sep 10, 2022 at 4:04 AM
    I wouldn’t line-X the truck myself, even my old 2000 model which is in need of a new finish. Resale on something covered in rough plastic instead of factory paint is crap. Are there specific areas that are getting chipped and scratched that could be coated with a thicker wrap? Why not treat the spots that are prone to rusting and wrap the whole thing? Are you self employed? A custom wrap might be a business expense that could be written off. A new paint job after 3 months seems ludicrous. Just gonna get messed up again.
  7. Sep 10, 2022 at 4:36 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    People keep mentioning resale but you already said that wasn't a concern. I've seen a handful of trucks that have been bedlined and when professionally done they don't look too bad. My personal opinion I think paint looks better but I totally understand the usefulness of bedliner and wouldn't hesitate to do it in a situation such as yours.
    FlyingWolfe likes this.
  8. Sep 10, 2022 at 5:31 AM
    mesquitemag24
    J
    2021 Tundra Limited
    That was the original plan if it was just the fenders and rocker panels getting eaten up, but theres chips and scratches on the pillars, around the handles and you can see small flecks of surface rust already starting. If it was just a pavement work truck I wouldn't consider it, but its just unmarked country gravel rock quarry roads with brush every which direction about 90% of the time.
  9. Sep 20, 2022 at 12:58 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Professionally done looks good.it is not as thick as the truck bed. I may do to get rid of pin strips in the future
  10. Sep 20, 2022 at 3:17 AM
    Adam New Member
    It is only going to get more chips in it the way you are using it. I would do it if I had the cash to throw at it. Professionally done ones look legit.
  11. Sep 20, 2022 at 3:41 AM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Bed mat would be more useful, spray in bedliner is rough on the knees.
  12. Sep 20, 2022 at 4:25 AM
    Tundra4x4Offroad
    Tundra4x4Offroad #somenewshitz
    Sam
    Los Angeles, CA
    08 Tundra SR5, 18 Tundra Platinum
    Too many mods to list right now for both Tundra
    Best investment I did for my overland rig is to bedline the entire truck. I had it done professionally and the easiest part after dirt play is spray it down with water and air dry. No chemical needed. Wont add more than 25lbs of extra weight and it looks very cool.DBF687FB-4309-4086-873C-C7CD07AC06C2.jpg
    Part_time and cran2 like this.
  13. Sep 20, 2022 at 6:00 AM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    Tundra4x4Offroad and Part_time like this.
  14. Sep 28, 2022 at 8:26 PM
    Part_time
    Oregon
    Did you go to a Lines retailer or just a paintb shop?
  15. Oct 15, 2022 at 9:48 PM
    Tundra4x4Offroad
    Sam
    Los Angeles, CA
    I had it painted at riverside, ca by someone who specialize in bedliner paint. Its raptor bedliner mix with the color pigment to get the blue.
  16. Mar 10, 2023 at 10:54 AM
    xuy
    xuy New Member
    2021 TRD PRO Super White
    Just dropped by local line-x shop. Mines 21 pro white. Here in Alberta, cities using crappy load of sand and salt on the road in winter which is disgusting. I spent last three years fixing plow trucks. Brand new plow truck I put together came back in a year, I couldn't even look at the bottom of it.
    Mine truck two years old, I already have severe rust came out from the bottom on the rocker. Line-x guy told me it's gonna turn a little yellowish after a while but the toughness will never fade away. At this point I don't care too much as long as there is no rust and this is only way to keep this truck as long as possible.
    So I'm gonna line-x all four wheel lips and rockers on both sides. That's 2000. Plus color match another 450. So total of 2500 CAD. And looking at an existing done product, it ll be like 2mm thick. It ll give enough protection.
    I don't have time to wash the truck every single day hope this will help.
    don3032 likes this.
