Installing Solid Offroad Motor Mounts — pics and tips
Discussion in 'Performance and Tuning' started by Terndrerrr, Nov 28, 2021.
  1. Nov 28, 2021 at 12:57 PM
    Terndrerrr
    Terndrerrr [OP] 923000 miles to go
    Music City
    6UR-FE
    I’ve had these mounts sitting in my garage for a while now. Yesterday, while getting a bunch of other things done on my truck, I popped off the splash shields inside my wheel wells to get a good look at the motor mounts. From what limited pics I’ve found on the two threads on this subject, it appears I have a lot less room to work with than some of y’all here.
    Got a couple questions after a cursory glance.
    1. Is it safe to support your 5.7 while swapping these in with a jack and block of wood under the oil pan?
    The included instructions do not offer any info on jack points. After getting under my ‘21 and removing the skid plates, it seems there is nowhere else I can get a jack under the engine block. Seems to me that this is NOT ok. But I did find a video of a 4Runner getting new motor mounts, and the mechanic supported the engine with a jack and block of wood under the oil pan. So…:notsure:
    2. How did you get your hands in there with a wrench? It appears I may need to buy more tools…I’m thinking a swivel joint adapter may be required to get a socket on some of the bolt heads. I can’t find a way to get at them from under the truck; there is too much stuff in the way. It looks like I’ll have to remove the wheels and splash shields and go through the wheel wells. Even then, it looks like there is less room to work with than some of the post-install pics I found on the forum.
    Any tips/experiences from those who have installed these—particularly as it relates to extra steps/hassles on a newer 2.5 gen truck—would be greatly appreciated!
    @Bonzen
    @TexasTundra27
    @Ckatz53
    @vq35721
    @papasmurf
    @KyleGreenFabrication
    @FitsofRage88
    PS: there are no vids of removing/replacing even the OEM mounts out there, either. I’ll add pics and tips to this thread when I get to it. :headbang:
    Bonzen likes this.
  2. Nov 28, 2021 at 5:13 PM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    I went the jack and wood route. Working one side at a time, the engine is technically supported by the other mount so the jack/wood was there to support the other half of the engine. It appears to be a tight fit, and it is, but tools will fit...just expect your hands to look like you were punching a wall by the end of it. 25k miles on my truck with them and just as happy as day 1.
  3. Nov 28, 2021 at 5:31 PM
    Terndrerrr
    Music City
    6UR-FE
    Awesome. Yeah, it seems like kind of a pain but will be helped by some swivel joint tools.
    I thought I’d go one side at a time as well. Where did you place your wood block and jack under the engine?
    Thanks! :cheers:
  4. Nov 28, 2021 at 6:55 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    I used a jack and a 2x4 to support the engine at the oil pan. Definitely get some swivels to use. I had so many extra pieces out when I did mine that it’s hard to say what else would need to come out to get the job done. I did have to install the driver side in 2 pieces due to lack of space, but that could be because of my long tubes.
  5. Nov 29, 2021 at 4:58 AM
    Ckatz53
    Ckatz53 Newish
    MD
    Oil pan with a 2x6. It'll be like playing tetris but it'll get there.
  6. Nov 29, 2021 at 7:16 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
  7. Nov 29, 2021 at 9:02 AM
    Bonzen
    Bonzen Solid Offroad motor & transmission mounts
    Lake Havasu City, AZ
    Been using the block of wood under the oil pan method since 2003 to do motor mount installs. Perfectly safe. Never had an issue of any damage occurring and have never had a customer tell me otherwise. Remember you are just supporting it a few inches higher than normal, not bouncing it up and down with force. The oil pan will not cave in or anything like that. Obviously an engine hoist is preferable and a vehicle lift is the best method. But for the garage DIYer, the floor jack method with wood block (or thick phone book) is fine.
    Most customers do one side at a time, that way the motor is still held on by one mount. others do both at once, its personal preference.
    As far as fitting your hands in there, the 5.7 2nd-2.5 gen is the easiest truck to do the installs on. The V6 trucks are tight (I know a girl who did her own install on her 3rd gen tacoma 4wd in her driveway at night) So its just a matter of having an assortment of gear wrenches, long box wrenches and socket extensions. The average time I have heard from people over the last few years is around 2.5 hours.
    I try to get on here as much as I can remember to log on, so happy to answer any questions or attempt to provide tips.
  8. Nov 30, 2021 at 9:44 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    For more space to get at the block and frame mount bolts, jack up your truck, put it on jack stands, and remove the wheels and wheel well mud guards...then you can jack up the engine using a block of wood to remove pressure off the mounts to make them easier to remove. Do one side at a time, obviously.
    Yodder J and Bonzen like this.
  9. Dec 6, 2021 at 10:07 AM
    Bonzen
    Great advice - taking the tires off allows you closer access to the inner fender area.
  10. Dec 6, 2021 at 11:06 AM
    Terndrerrr
    Music City
    6UR-FE
    That’s what I did. And I got stuck and had to admit defeat. I got all 6 bolts off but could not get the big 19mm nut that holds the factory mount together to budge. My hands were bleeding, and after 5 hours, even after shooting penetrating oil onto that nut and waiting, I had to put it back together and put my wheel back on because I ran out of daylight. Here are some pics. This wasn’t too bad:
    I had to come up from the bottom on a couple of them:
    I put all those bolts back in, thinking that maybe the big 19mm nut that holds the mount together should be the first thing I tackle. I just didn’t have any room to turn my wrench between the block and the UCA mount. I had like an inch. There was too much give in the mount to get it to break loose. Here’s a pic:
    I am going to buy some ratcheting socket wrenches that have a joint near the head. Maybe that will allow me to turn the wrench far enough to break that 19mm nut loose.
    I also just want to say, I can do my front brakes in an hour or less. This has been a massive pain in my ass. But I haven’t given up yet.
  11. Dec 6, 2021 at 1:35 PM
    Bonzen
    Your theory is probably correct, if there are no block or frame bolts to hold the mount tight, the mount will just twist due to the soft rubber flexing when you try to take the main 19mm nut off. I'm still surprised it gave you that much of a fit, penetrating oil usually works awesome.
    On the few installs I performed, I never separated the 2 halves due to what I thought was adequate room to pull the old mounts out. On the V6 trucks, I separated the mount halves on the driver side only (much tighter working spaces than the 5.7 engine bay)
  12. Dec 25, 2021 at 1:36 PM
    Punisher29073
    Punisher29073 New Member
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    What exactly do you fix by installing solid mounts?
  13. Mar 9, 2023 at 4:09 AM
    coTony
    Tony
    Montrose, CO
    Hopefully I will be going through this install some time soon before it gets too hot
    Bonzen likes this.
  14. Mar 10, 2023 at 10:47 AM
    Bonzen
    Pwong562 likes this.
  15. Mar 10, 2023 at 1:55 PM
    coTony
    Tony
    Montrose, CO
    Anything as far as a video for the install? Just trying to see what I am up against having 3.0’s and a secondary shock in the front
  16. Apr 27, 2023 at 8:49 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have had these for quite a while and hope to do them Saturday.
    Have mercy on my soul!
    Bonzen likes this.
  17. May 9, 2023 at 7:01 AM
    Bonzen
    The 5.7 kit is by far the easiest install. The V6 kits are really tight. But, I have known girls that have installed them alone:thumbsup:
    reywcms and e30cabrio like this.
  18. Sep 9, 2023 at 7:34 AM
    xiakes
    xiakes New Member
    Phoenix, AZ
    '16 black tundra sr5 crewmax
    how many band-aid do i need to prepare for this kind of work? planning to install mine today.
    Bonzen likes this.
  19. Sep 10, 2023 at 10:50 AM
    Bonzen
    The last female customer that installed these said she only needed 2, so theres your baseline to meet or exceed :D
  20. Sep 10, 2023 at 11:21 AM
    Terndrerrr
    Music City
    6UR-FE
    Wait, you’re telling me she didn’t tear up her most likely far smaller arms and hands? :D
  21. Sep 10, 2023 at 5:18 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Like beers, I recommend a 30-pack.
