2022 Tundra Bed Noise (Solved)
Discussion in '3rd Gen Tundras (2022+)' started by bsulli91, Mar 1, 2023.
  1. Mar 1, 2023 at 1:19 PM
    bsulli91
    bsulli91 [OP] New Member
    Hello Fellow Tundra Owners,
    Like many others, while enjoying the rear window down on my new Tundra, I was experiencing a noise coming from the bed when going over small bumps. This was a combination of creaking and knocking sounds. After some trial and error, I sorted out what the culprits were for me, and thought I would share.
    The first thing I noticed was the plastic bed rail caps would make a rattle noise if I just tapped on them gently with my hand so I added a thin gasket between the plastic cap and the Bed rail to eliminate that movement.
    The second thing I addressed was the tailgate support cables knocking around. Turns out a 1/2" ID o-ring did the trick to deaden the quick disconnect movement noise.
    Lastley, I narrowed down the creaking noise (which almost sounded like a pop or knock sometimes) to the passenger side front bed bolt area. There is a piece of what looks like a very thin anti-friction pad between the Bed and Frame. I loosened each bolt on the bed and lifted it enough to put a plastic shim cut from a large zip tie in between the bed and the frame and re-tightened the bolts.
    Now I only hear lovely exhaust and turbo noises.
    Below are some pictures for reference:
    UPDATE #1
  2. Mar 1, 2023 at 3:31 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    You sir are a gentleman and a scholar. I most definitely will do this. It drives me crazy when I roll down the rear window hearing those noises. Excellent job and write up !
  3. Mar 1, 2023 at 4:30 PM
    Jasco1
    Jasco1 New Member
    23 SR5 Crewmax TRD OR Lunar Rock
    Nice work! I'll add this to the list.
    bsulli91[OP] likes this.
  4. Mar 1, 2023 at 4:36 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    3 posts and you deserve to be sticky’d
    Nice work
    biebs96 and bsulli91[OP] like this.
  5. Mar 1, 2023 at 5:12 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    I may be doing this too. That is good. Good stuff doesn't travel as fast. You messed up when you put (solved) on there.
    22whatwedo and bsulli91[OP] like this.
  6. Mar 2, 2023 at 3:00 PM
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    Very nice!
  7. Mar 2, 2023 at 7:45 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Toyota should be taking notes.
    woods likes this.
  8. Mar 2, 2023 at 9:29 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Great info! Thanks for sharing!
  9. Mar 3, 2023 at 5:41 PM
    Aces and 8s
    Aces and 8s I Turn Wrenches
    2023 Tundra CM Ltd
    Adding to this, the bed cleets are a source of noise too. Anytime the tailgate or a door is closed they rattle and make a springy noise. They're chintzy and easily removed. My 2011 tacoma had them and they made noise too.
  10. Mar 8, 2023 at 7:04 AM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    Great post
  11. Mar 8, 2023 at 7:10 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    I never had the bed rattle but if I push on it from the side towards the bulkhead it creaks and pops. I don’t know if it’s the sheet metal panel doing it or where it attaches underneath but if I don’t touch it doesn’t exist so I have to resist
  12. Mar 8, 2023 at 8:00 AM
    STEPBRO
    STEPBRO New Member
    2022 SR5 TRD OR
    Thank you.
  13. Mar 8, 2023 at 8:23 AM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Have also noticed the chain that hangs down from the spare tire mount can rattle. Zip tie it so it can't move around
    Soupbean77, cfus89 and SC4333 like this.
  14. Mar 8, 2023 at 8:54 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Great rundown
  15. Mar 9, 2023 at 7:33 PM
    4wd TRD PRO
    4wd TRD PRO New Member
    My bed was making a creaking noise too. Multiple places. I re-torqued the bed bold and nothing, took the bolts out and lifted the bed us a little and put some grease between the bed mounts and the frame. Took 10min. That worked! If it happens again down the road I will use some thin sheet delrin cut to fit in place on the grease.
    cfus89 likes this.
  16. Mar 9, 2023 at 8:33 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Going to try these suggestions. When I roll down the rear window, the bed squeaks too much.
    AstroTRD likes this.
  17. Mar 11, 2023 at 5:49 AM
    Bassman#1
    Bassman#1 New Member
    Excellent information. I am heading into the shop now to try these tricks. I am going to try the grease first before I do the shim technique for the bed. What is the torque specs on the bed bolts? Is 36 ft lbs correct that I saw posted on another site?
  18. Mar 11, 2023 at 7:41 AM
    Bassman#1
    Wow what difference. So nice and quiet. Until now the only thing I didn't like about the truck was the composite bed. Now I LOVE it. Thanks for the info and if you have the proper torque specs please send them.
  19. Mar 11, 2023 at 8:34 AM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Did you grease, or shim, or both?
  20. Mar 11, 2023 at 10:18 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    How about the rear window?
    If I lower my rear widow some, it's making crazy rattling noises over bumps!
    Dealership says it's normal and they all do it.
    Anyone has issues with the back window rattling?
    AstroTRD and arrampico like this.
  21. Mar 11, 2023 at 10:43 AM
    Breathing Borla
    AZ
    It’s normal because they all do it, lol
    gotta love that stupid logic
    AstroTRD and 4genRunner like this.
  22. Mar 11, 2023 at 11:41 AM
    4genRunner
    Southwestern MO
    Resident TIS ninja @ryanwgregg can probably answer this.
  23. Mar 11, 2023 at 1:09 PM
    Bassman#1
    I only greased it. I used Evinrude triple guard grease. Stuff doesn't attack rubber or plastic, hell it stays on a prop at 70 plus mph so I figure it won't wash away. I only took it for a quick spin and walked around in the bed. It's quit has a mouse so I am pretty sure it's fixed. The noise Kap1 is talking is having I bet is the bed knock. Mine was horrible when I towed. The frame flexes more when towing so it was real load. Thanks bsulli91.
    Kap1 and graf_von_tundra like this.
  24. Mar 11, 2023 at 4:55 PM
    lesh234
    lesh234 New Member
    Thanks
  25. Mar 12, 2023 at 9:23 AM
    Tundrafarm
    Tundrafarm New Member
    22 hybrid limited 4x4
    Hope this helps?
    AstroTRD, mayan, iiawah808 and 3 others like this.
  26. Mar 12, 2023 at 10:33 AM
    4genRunner
    Southwestern MO
    Hope all is well.
  27. Mar 12, 2023 at 10:59 AM
    bsulli91
    Glad so many folks are finding this useful!
    I couldn’t find the torque specs, so when I loosened the bolts, I marked the head and turned it off a 1/4 then tightened back to the same spot with my torque wrench and it seemed to be around 30flbs so I went with 35 for good measure assuming there was some settling. Looks like 36flbs is the winner per Tundrafarms last post.
    Ultimately, I have decided I would get 6 lubricant filled nylon washers from mcmastercarr.com for a more permanent fix. I like the grease idea too so figured I would combine best of both worlds. I will let everybody know the results once I get them in and run for a few days.
    T-MAC and graf_von_tundra like this.
  28. Mar 12, 2023 at 11:19 AM
    DrZoidberg
    Dave
    Tesla MYP
    If I push in the circled area it makes a popping noise. Either the bracket is loose or the body sheet metal is warped or something.
    I’d spend more time to look and remove the wheel liner but 90% sure tundra will be gone in 2 weeks.
    woods and graf_von_tundra like this.
  29. Mar 12, 2023 at 7:30 PM
    graf_von_tundra
    graf_von_tundra Not so new
    Central Texas
    2023 Tundra 1794 4x4 Black
    I’ve noticed the same on the passenger side, FWIW.
  30. Mar 12, 2023 at 7:41 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Can you post the part numbers or link?
