Driver Side Locking Mechanism
Discussion in '1st Gen Tundras (2000-2006)' started by Nico.G, Feb 17, 2021.
  1. Feb 17, 2021 at 2:42 AM
    Nico.G
    Nico.G [OP] New Member
    Nico
    2004 Toyota Tundra SR5 4.7L
    Hi,
    I’ve recently bought an 04 tundra with some issues, but overall a pretty solid truck at this point. There is however some quality of life fixes I’m still looking to do. I recently replaced the driver side door jam, open close button after noticing the interior lights weren’t going on when the door was opened, this fixed the problem. More annoyingly when I go to unlock the driver side door with the key it only opens that door not all 4 doors like the passenger side door does. Also once the driver side door is opened the unlock button only works when I turn the truck on however the lock button always works, any ideas? Thanks in advance.
    -Nico
  2. Feb 17, 2021 at 3:05 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I want to say to unlock all the doors from the drivers door you have to turn the key twice.
    GavinG83, tvpierce and Tundra2 like this.
  3. Feb 17, 2021 at 3:18 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Its this way on my '02, and our '08 sequoia
    Nico.G[OP] likes this.
  4. Feb 17, 2021 at 3:19 AM
    Nico.G
    Nico
    Ok I’ll try that and let you know, but why wouldn’t it unlock with the button on the door without the truck being on seems strange.
  5. Feb 17, 2021 at 3:43 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Might have a bad ground.
  6. Feb 17, 2021 at 4:02 PM
    Nico.G
    Nico
    The second turn to the right didn’t work. I have a new door actuator coming soon someone suggested that it was only $20 so when I removed the door panel I’ll check the ground.
  7. Mar 9, 2023 at 10:13 AM
  8. Mar 9, 2023 at 11:49 AM
    It's possible. Usually if I need to break up old grease, I'll use PB Blaster. It does a great job of dissolving crusty, hard grease, but it has a powerful smell, so it's not like you want to go nuts with it. It's also a metal preservative.
    That said, WD40 is less smelly and will free up gummed up mechanisms. I used to use it for shifters on bikes a lot. Once dried out, I'd follow-up with SuperLube or similar, something not prone to caking, although in a door like, white lithium may work better.
    LCP likes this.
