Fox Question
Discussion in 'Suspension' started by Chasntuna, Mar 7, 2023.
  1. Mar 7, 2023 at 6:06 PM
    Chasntuna
    Chasntuna [OP] New Member
    2015 DC TRD 2WD
    First official post here, I did the usual search and couldn't find what I'm looking for. Question is, Fox 2.0s claim the lift is 2 inch in the front max. BDS sells a kit that claims 3" but comes with their UCAs and assuming the same 2.0 CO. How does a UCA help lift an inch; assuming the UCA allows more travel and the CO can be adjusted for more lift? Is the UCA the differentiator?
    Bottom line, I'm torn between the Fox setup and Toytec for my budget to fit 35s. Feel free to opine.
  2. Mar 8, 2023 at 7:03 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Fox has a few options when it comes to front coilovers, it would be best to compare part numbers to be certain. Fox 2.0 IFP says 0-2", but likely 1.5" or so of lift would be our recommended max height for those shocks. Fox and Toytec are very different IMO. Are you wanting a shock that can be serviceable/tunable?
  3. Mar 8, 2023 at 7:22 AM
    Chasntuna
    2015 DC TRD 2WD
    Not necessarily.
