Can someone explain the term “g out”?
Discussion in 'Suspension' started by Marvthehamster, Mar 5, 2023.
  1. Mar 5, 2023 at 5:45 AM
    Marvthehamster
    Marvthehamster [OP] New Member
    Tom
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI Armor, OTT Tune
    What does this mean?
    What are examples of g out conditions for a mid travel tundra?
  2. Mar 5, 2023 at 5:49 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    G-out is usually used to refer to the abrupt transition from a steep decent to a flat or inclined surface. If you rode down the inside of a "V", the g-out would be what you'd feel ad the bottom of the "V".
  3. Mar 5, 2023 at 4:26 PM
    Marvthehamster
    Tom
    CO
    2018 CM
    Excellent. Thank you.
