CB Coilover shim issue
Discussion in 'Suspension' started by Tundra694, Mar 3, 2023.
  1. Mar 3, 2023 at 1:52 PM
    Tundra694
    Tundra694 [OP] New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    CB shim doesn’t fit over the center of the tapered top hat of my fresh 6112s. Dremel out the center or try another brand ?
    edit: 1/4” round over bit solved it.
  2. Mar 3, 2023 at 1:56 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I think the shim was designed around the TRD PRO shocks only (07-21?)
  3. Mar 3, 2023 at 2:00 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    Did you put it on right? Not trying to be an ass. I have them and the little cut out has to be in a certain spot for it to fit. So that means try flipping it over and spinning it. It will drop in when you have it rotated right.
    Tundra694[OP] likes this.
  4. Mar 3, 2023 at 2:02 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  5. Mar 3, 2023 at 2:04 PM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
  6. Mar 3, 2023 at 2:07 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  7. Mar 3, 2023 at 2:19 PM
    Tundra694
    AJ
    Yea it only went on one way. Tried all 4 positions to be sure.
