  1. Mar 3, 2023 at 12:22 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    That caster split can be improved by the looks of it. That split will likely pull
  2. Mar 3, 2023 at 12:25 PM
    I don't know enough about alignment systems to know if this is the case or not, but the GUI shows your tire is a 265/70r16. Is it possible that's skewing the output?
  3. Mar 3, 2023 at 12:28 PM
    Diff gonna get did. Had to hit the dealership for full syn oil change on the 2020 Highlander, picked up crush washers, grabbed my 80w90 on the way home.
    txagg, w666, NUDRAT[OP] and 2 others like this.
  4. Mar 3, 2023 at 12:46 PM
    Casper421
    In the woods
    06 DC
    Did they not test drive it after the first attempt and just call it good?!
    RUSTYNUTS and FrenchToasty like this.
  5. Mar 3, 2023 at 12:48 PM
    Casper421
    In the woods
    06 DC
    The stock wheel size is used to get the factory numbers.
    FirstGenVol and shifty`[QUOTED] like this.
  6. Mar 3, 2023 at 1:16 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I don’t know of any alignment shops around that drive it afterwards around here.
  7. Mar 3, 2023 at 1:21 PM
    He actually told me "it drives nice". Not sure if he just didn't notice the pull or what. It's not horrible but it's enough to notice.
    CodyP[QUOTED] likes this.
  8. Mar 3, 2023 at 1:21 PM
    Didn't you spend a fortune on Mobile 1? It just didn't work? I guess I missed the full story.
  9. Mar 3, 2023 at 1:26 PM
    Casper421
    In the woods
    06 DC
    That's just straight up lazy!
    RUSTYNUTS, assassin10000 and shifty` like this.
  10. Mar 3, 2023 at 1:26 PM
    Sunnier
    Sunny
    San Diego, CA
    Hulk is experiencing day 2 of major preventative surgery: timing belt and water pump. Also swapping the serpentine belt and they'll do an oil change so I don't have to go back for a while. F'ing fortune. I shoulda bought the parts myself. It'll make me feel less anxious though, knowing a date/mileage changed as a certainty, not the approximation I've been running on.
  11. Mar 3, 2023 at 1:29 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    “Toe and Go”…. @Darkness, may he RIP !
    txagg, RUSTYNUTS and FrenchToasty like this.
  12. Mar 3, 2023 at 1:58 PM
    tl;dr version -
    For front/rear diff and tc I'm out ~$165 in fluids and additives. I'm expecting ~$70 reimbursement from Mobil1. So $95 to refresh both diffs and tc, I guess?​
    novella version -
    Spent ~$110 on 75w140 & 75w90 of the Mobil1 LS for the rear/front diffs and tc. All OK except in rear, got chatter. Complained to Mobil1, they say they'll fully reimburse me (4qts for rear) and recommended trying additive to avoid a full cut-bait on newly installed fluid.
    Spent ~$12 on 7oz bottle CRC Trans-X additive. ~5oz got me to minimal chatter, but any chatter is pissing me off when I had virtually zero prior and it's pissing me off I'm adding additive to fluid that's already got LSD additives. So, w/SpeedPerks discount + 15% RetailMeNot coupon (code: rmn15) @ Advance Auto I'm out $39 more on Lucas 80w90.
    Since I'm keeping the full syn in the front diff and tc, I'm technically only out of pocket, what, $20, maybe $30 on this, total what I would've been, plus my time? Small price to pay to learn a lesson I should've avoided by heeding warnings here & elsewhere. When I saw a couple folks saying, "Worked fine for me, no chatter!" I assumed I may get lucky sticking with my preferred brand.
    I'm pretty stubborn about my fluids. Valvoline for grease and trans fluid. Mobil1 for crankcase and gear oil. Permatex for assembly lube and anti-seize. Superlube for plastic gears, poly bushings and similar rubbers. I think Royal Purple is overpriced silliness, though I used to use it often for GenIII SBC swaps. I like Lucas/Amsoil, but the others I just mentioned are my go-to.
    Lesson learned: Only use dino oil in 1st Gen Tundra/Sequoia if it has LSD.
    (Assuming 80w90 Lucas kills my chatter)
    PS/EDIT: East Coast Gear was right. I should've listened, but I'm a stubborn MF.
  13. Mar 3, 2023 at 2:08 PM
    Sounds like nobody adjusts for road crown like the do here. That and making sure their crappy alignment doesn’t pull too bad.
  14. Mar 3, 2023 at 2:13 PM
    Man, this shit is just painful no matter where I cart it up or which tires. Does Method Racing strictly enforce all vendors selling at their desired MSRP or something?
    I can't recall the last time I spent more than $2000 on wheels and tires.
  15. Mar 3, 2023 at 2:54 PM
    Casper421
    In the woods
    06 DC
  16. Mar 3, 2023 at 3:00 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i threw a fit about $176 tires. Glad my tundra is 16's. And i hate discounts website now. Even if i shop by size they wanna know what its for, and xe's came with 17"steelies, and they know it.
  17. Mar 3, 2023 at 4:36 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    tirerack.com...must be "fair trade pricing" (a.k.a. price fixing)
  18. Mar 3, 2023 at 6:17 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    NUDRAT[OP] and Jack McCarthy like this.
  19. Mar 3, 2023 at 6:26 PM
    Everyone has that specific color and size at $418. Which is why I'm suspecting Method Racing forces vendors to charge their desired MSRP. Other companies do the same and will penalize you if they find you doing otherwise, even going so far as ensuring you're not able to sell their product if caught selling below their MSRP.
    EDIT: Confirmed, Method Racing has a MAP (minimum advertised price) policy in place. Guess I'm hunting for another vendor/wheel. Lame!
    I may poke around at 16s and see if things are better. Ideally I'd prefer to be at $275/ea or lower per wheel. Shit part is I can't even find anyone that sells these who has a viable coupon that could at least get me closer to my target. 4WP included.
    We had it here too. For us, I'm pretty sure it's because we're on a frontal border. Usually when warm and cold fronts collide, the area around collision is high wind/rain.
    Jack McCarthy and FrenchToasty like this.
  20. Mar 3, 2023 at 7:49 PM
    Might be better to have a tent with with roll up sides to create a canopy along with a ridge vent to help prevent the roof from blowing apart. You’d also need to secure the frame more permanently though or weigh it down somehow if it’s not secure enough. I’m not sure if I’ve ever seen anything like that sold though. Hmmn.
  21. Mar 3, 2023 at 8:04 PM
    Now I’m thinking hydrophobic acoustic mesh might be an idea for a tent. Allows air to pass through it but blocks water and moisture. I wonder if anyone has done it or something similar?
    Mr.bee likes this.
  22. Mar 3, 2023 at 8:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Gubment project. Shenanigans ensue.
  23. Mar 3, 2023 at 8:58 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    It was real bad here too. Trees down everywhere power out for about 6 or so hours. Had to help move a tree off our street so I could get to work tonight. Got to cycle 4low though so not too bad. Been meaning to do that for a while. Went right in.
  24. Mar 3, 2023 at 11:13 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    An alignment tech? Didn't notice the pull during the test drive? You realize how silly that sounds I hope. He either didn't drive it or didn't like your donuts.Yeah, and so much for that theory of donuts being assurance of a job well done, eh?
    Wishing Hulk a full and speedy recovery:thumbsup:
    tensioners also?
    Sunnier[QUOTED] and FrenchToasty like this.
  25. Mar 4, 2023 at 4:22 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    donuts have always worked. I'd blame the tech before i'd blame the donuts. I mean as long as they werent krispy kreme.
    txagg likes this.
  26. Mar 4, 2023 at 5:31 AM
    Worse. It was the owner that did the alignment and test drive. Maybe he's diabetic and was pissed I brought donuts. :notsure:
    Sunnier likes this.
  27. Mar 4, 2023 at 5:48 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I dont drink monsters, but i thought the monster was a good idea, pretty much everyone my age is addicted to those things.
    we did a 'good' job on bmf's truck because we were well lubricated.
    txagg and FrenchToasty like this.
  28. Mar 4, 2023 at 8:03 AM
    Sunnier
    Sunny
    San Diego, CA
    Thank you!
    Hmmn, I'd better check. Not having done it myself (skeeered), I didn't ask. But I will, now you've mentioned it.
    RUSTYNUTS[QUOTED] likes this.
  29. Mar 4, 2023 at 8:15 AM
    Trying to think of a good reason not to throw these away. Can't imagine a scenario where I would put them back on or rebuild them. The bushings are expensive.
    Recycle them?
  30. Mar 4, 2023 at 8:17 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I listed my old ones on here and after a few months I got $50 from somebody that wanted to rebuild them. YMMV
