Gps not connecting
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tw1nsdad, Mar 1, 2023.
  1. Mar 1, 2023 at 1:48 PM
    Tw1nsdad
    Tw1nsdad [OP] New Member
    William
    White tundra k2
    Just bought a 2016 tundra I was cleaning battery cables left disconnected over an hour and when I hooked them bac up went to set the clock and it says acquiring time from gps but never does and won’t let you set it manually also the distance to empty is not calculating correctly but I know that may have to go through another fill up any suggestions
  2. Mar 1, 2023 at 1:55 PM
    AZBoatHauler
    So.Arizona
    How long since you reconnected? Is it in a garage?
