Broken Wheel Hun
Discussion in '1st Gen Tundras (2000-2006)' started by Ghocutt, Mar 1, 2023.
  1. Mar 1, 2023 at 9:50 AM
    Ghocutt
    Ghocutt [OP] New Member
    Graham
    2003 Tundra 2 wheel drive access cab
    Hello everyone I need some help. My 2003 tundras rear hub studs have all snapped off. I was wondering since it is a drum break how I could go about fixing this?
  2. Mar 1, 2023 at 9:59 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  3. Mar 1, 2023 at 10:54 AM
    This is what happens when someone over-torques the studs, and can result in a rollover or major collision. Sometimes shear like this can be caused if you don't torque the lug nuts down enough - when they loosen, the stud shears off.
    I went through similar with my rear wheel recentlyl, but they sheared when I tried to remove the wheel after a major flat tire event - whoever had this tire off last over-torqued the studs, which stretched the threads. You'll usually know you're there if the lugnut breaks loose, then either (A) gets tight again after a couple turns or (B) spins in place but won't come off. (A) is always a better situation than (B).
    Studs snapping off like this is a common problem anyone who lets torque monkeys at shops using under-regulated impact hammers put their lug nuts on. I've replaced several in my lifetime. Here was my removal/install of new studs.
    WARNING: You need to understand, your wheel studs are different lengths for front wheels vs. rear wheels. Not everyone at the auto parts store knows this and may give you the wrong length stud. Ask them to verify it's for <front/rear, whichever this is dealing with>. EDIT: See Dorman's part numbers in my follow-up reply below
    And, seriously, just go out and buy a stud setter if you've never done this before, the local auto parts store will have one. Google for "Wheel stud installer", the one Lisle makes is something everyone has in their toolbox for days like this.
    PS: If you don't have a feel for how many ugga-duggas you need to use when installing wheels, invest in a torque wrench, and watch a video on how to use it, and more importantly, how to STORE it when you're done using it. I don't recommend using handheld devices to install lug nuts, air, electric or otherwise!
    Mr.bee, Sunnier, FirstGenVol and 2 others like this.
  4. Mar 2, 2023 at 4:59 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I, for one always like a good Drum Break...:rimshot:
    been waiting a long time to use that one!
    bmf4069, Mr.bee, Sunnier and 3 others like this.
  5. Mar 2, 2023 at 5:17 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Throw your impact away if you did that. Definitely don’t drive that!
    Mr.bee likes this.
  6. Mar 2, 2023 at 10:16 AM
    I didn't know this. What is the reason they are different lengths?
  7. Mar 2, 2023 at 10:18 AM
    I presume it's because rear is drum and front is not. IIRC the difference is like 10-20mm or something.
  8. Mar 2, 2023 at 10:25 AM
    Sunnier
    Sunny
    San Diego, CA
    Good luck with your broken wheel Hun
  9. Mar 2, 2023 at 10:28 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I was wondering if OP was from Balmer, or perhaps the Dena
    Sunnier[QUOTED] likes this.
  10. Mar 2, 2023 at 11:29 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I ordered a new lug nut and wheel stud for my 06 RWD last week using my local Toyota dealer website using my Vin #. The stud is part #9094202052 - the website said for Left, Right Front and Rear axles. Did I get the wrong part to replace the stud on my rear axle?
    Wheel Lug Stud (Left, Right, Front, Rear)
    Part Number: 9094202052
    Supersession(s): 90942-02052; 9094202034
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    HUB (FOR FRONT AXLE LEFT); HUB (FOR FRONT AXLE RIGHT); HUB (FOR FRONT AXLE); HUB (FOR REAR AXLE LEFT); HUB (FOR REAR AXLE RIGHT); HUB (FOR REAR AXLE).
  11. Mar 2, 2023 at 12:10 PM
    I dunno. I went with Dorman on the studs. Dorman is who a lot of OEMs use to manufacture parts like this.
    Here are the Dorman part nums:
    bmf4069 likes this.
  12. Mar 2, 2023 at 12:26 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Wheelhun comments are the best.
    a friend of mine in highscool gave me top dollar for my '88 jeep comanche my grandpa had given me. I had fixed it up, and kept it mostly stock, but when he bought it he had pepboys racing seat and 6 pt harness & steeringwheel, and the discount tire AR steelies and big tires, and a different stereo setup (mine was 120v home stereo stuff on an inverter), but he got t-boned after a week after the new wheels (that discount installed) and when he got hit it shattered all 20 studs (probably not hub centric wheels) and discount had to pay him almost double what he paid, for injury. I've only taken loose wheels ever since. Half because i dont trust their torque sticks, and half because i dont want em to scuff my wheels.
    Sunnier likes this.
  13. Mar 2, 2023 at 12:36 PM
    Did the OP spell hub incorrectly or was the title changed to match @Sunnier ’s comment? :monocle:
    I’m too late to the party as usual.
    Sunnier likes this.
  14. Mar 2, 2023 at 12:50 PM
    Sunnier
    Sunny
    San Diego, CA
    Typo in the thread title. We're just playin'.
    N84434, FirstGenVol and Jack McCarthy like this.
  15. Mar 2, 2023 at 12:55 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    gen alpha wont get that joke.
  16. Mar 2, 2023 at 1:36 PM
    Sunnier
    Sunny
    San Diego, CA
    That's alright. We please ourselves.
    Imagine if this were Friday.... :cool:
    Jack McCarthy and Mr.bee[QUOTED] like this.
  17. Mar 2, 2023 at 1:36 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Thursday is auditions.
    Sunnier likes this.
  18. Mar 2, 2023 at 1:57 PM
    Wait…There’s a new one now?
    Damn. Well good luck, OP.
  19. Mar 2, 2023 at 9:18 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I wonder if Attila put that wheel on. Or maybe he tried to take it off.
    N84434, bmf4069 and Sunnier[QUOTED] like this.
