2014 SR5 Budget Upgrades?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rocko9999, Mar 1, 2023.
  1. Mar 1, 2023 at 9:02 AM
    Rocko9999
    Rocko9999 [OP] New Member
    Looking for budget, best bang for your buck upgrades for my 14' SR5 4.6 2WD truck-160K miles. Truck was a work horse before I got it-construction foremans- and the only thing I have done, other than clean the living heck out of it is to replace all the seat covers with a new OEM set I got a steal on-$80. It's got some dents, dings, etc. that I am fine with as I don't want to make it a show truck. Any ideas would be appreciated.
    D4x4TRD and QuicksandPNW like this.
  2. Mar 1, 2023 at 9:08 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Best bang for buck with 160k on it would be a complete run-through with all maintenance inspected and done on it.
    Best "upgrade" IMO at that mileage is
    New suspension (shocks) and ball joints.
    Best budget (under 200) upgrade is Husky floor mats.
    Best ~500 upgrade would be a rear trd swaybar.
    Lastly, Best "safety" upgrade would be new LED headlights. I see your in the desert. Makes a big difference in night driving.
  3. Mar 1, 2023 at 9:18 AM
    Rocko9999
    Thank you. I am sure it's in need of shocks as it was probably overloaded most of it's life-although it seems to ride decent. Does the swaybar make the ride any stiffer?
  4. Mar 1, 2023 at 9:20 AM
    1UP
    1UP Truck Gang
    Your truck wont "roll" as much. Makes cornering much better.
  5. Mar 1, 2023 at 9:20 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    chrome delete & black out the wheels..
    V3N0M and Rocko9999[OP] like this.
  6. Mar 1, 2023 at 9:23 AM
    1UP
    1UP Truck Gang
    If you were close I'd give you my ~10k mile used trd sport shocks I have sitting on my garage floor.
    Keep you eye on this sites marketplace. Occasionally someone is getting rid of an oem low mileage set up because they lifted their truck.
    V3N0M and Rocko9999[QUOTED][OP] like this.
  7. Mar 1, 2023 at 9:26 AM
    Rocko9999
    Will do. Thanks. I am in Socal.
    V3N0M likes this.
  8. Mar 1, 2023 at 9:28 AM
    1UP
    1UP Truck Gang
    I figured based on your pic. I'm east coast. But lots of socal folks in here. I'm sure you'll run across a good deal on suspension whenever you look to swap.
    https://www.tundras.com/forums/marketplace.81/
  9. Mar 1, 2023 at 12:53 PM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    I just bought a 14’ SR5(5.7) in December, have been modding it ever since lol I removed all chrome badges from the truck, polished headlights and clear ppf’d, sunstrip tint across top of windshield, I have 18” steel wheels like yours that I had powder coated satin black. Found a sweet private sale for some KO2’s. Swapped out the SR5 grill for the TRD pro heritage grill. Roof wrapped satin black, running boards installed. Found a vinyl tonneau cover for $250 luckily. I bought a scamazon led kit for interior and exterior lights. Makes a huuuge difference. As mentioned by someone above, I plan on upgrading to the LED headlamps within the next few months as well to update the truck completely. Getting the vehicle up to date on fluid changes and maintenance is always worthwhile as well.
    V3N0M, Rocko9999[OP] and 1UP like this.
  10. Mar 1, 2023 at 12:59 PM
    SPOirish28
    Ontario, Canada
    2014 SSM SR5 DC
  11. Mar 1, 2023 at 12:59 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Husky Mats
    Wheels/Tires
    TRD Sway Bars
    RCI Sliders
    RCI Skid Plates, under protection
    Shocks
    Debadge
    Blackout Bumper Caps/Grille
    Stubby Antenna
    TRD LED Headlights
    Actually, these are just all the things on my list that I've done or am continuing to work on!
    Rocko9999[OP] likes this.
  12. Mar 1, 2023 at 1:00 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    swap in factory LED headlights
    of you tow or mostly a road driver- TRD rear sway
    desert does it seat jacker, at least for the driver
    all offer a big improvement for the $, but do any needed maintenance items first of course
  13. Mar 7, 2023 at 7:16 PM
    V3N0M
    V3N0M New Member
    Orange County, CA
    2020 Tundra SR5 Crewmax
    - Carven Type R Exhaust - TRD LED Headlights - (2) LED Ditch Lights Mounted on Hood - Cali Raised Ditch Light Brackets - (2) 42” LED Light Bars Behind Grill - Cali Raised Hidden Grille Mounting Brackets - AJT Interior Chrome Delete - AJT V3 Shift Knob - 8" ReadyLift w/ Bilstein 5100's (all around) - 18" Raceline 948B Split Wheels - Toyo Open Country MT 37 x 13.50 R18 - Amp Research Power Steps
    Where in SoCal are you?
    I’m lifting my tundra this week and will have all 4 stock shocks from my SR5, truck has 15,028 miles. I’m in Orange County
  14. Mar 8, 2023 at 8:17 AM
    Rocko9999
    Oceanside.
    V3N0M[QUOTED] likes this.
  15. Mar 8, 2023 at 8:22 AM
    Rocko9999
    Were those stock wheels(not the black) in the first picture?
  16. Mar 8, 2023 at 8:23 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Best bang for buck I think would:
    1. LED OEM TRD Pro headlights and fog lights
    2. FRAC setup
    3. Sway Bar upgrades, both would be ideal imo but rear for sure.
    4. Auto tailgate lock
    5. Bed cover and/or bed liner.
    6. Ceramic window tint
    7. Catalytic Converter plates
    TundraTex, Trentimus and chingyeunglo like this.
  17. Mar 8, 2023 at 8:27 AM
    V3N0M
    V3N0M New Member
    Orange County, CA
    Not too far at all,
    I'm by Brea, CA
    Rocko9999[QUOTED][OP] likes this.
  18. Mar 8, 2023 at 9:38 AM
    SPOirish28
    Ontario, Canada
    2014 SSM SR5 DC
    Yes those are the stock limited 20” wheels
  19. Mar 8, 2023 at 9:57 AM
    Rocko9999
    I do like those.
  20. Mar 8, 2023 at 4:12 PM
    SPOirish28
    Ontario, Canada
    2014 SSM SR5 DC
    Yeah they’re not bad at all. I thought about powder coating them black at one point but I’d rather get some 35 offset wheels instead of the stock 60.. but new rims won’t be this year so I’ll be putting the stock 20’s back on this spring.
  21. Mar 8, 2023 at 5:10 PM
    Trentimus
    Trentimus New Member
    Trent
    2019 Tundra Off Road
    Nfab bars, undercover armor cover, hottails
    Yes it does, but we’ll worth it
