How to install train horns through OEM horn? Help?!?!
Discussion in 'General Tundra Discussion' started by lafivsev, Feb 28, 2023.
  1. Feb 28, 2023 at 5:48 AM
    lafivsev
    lafivsev [OP] Building The Dream Truck!
    Emilio
    2008 Toyota Tundra Limited Crewmax TRD-Off Road
    Hello all! I'm trying to install my train horns so that I can use them through my steering wheel inside the cab like a regular horn using the steering wheel horn. However I'm having problems doing that, I don't know where to connect the wires so that is possible. Does anybody with any info? Please Help! thanks! This is on my 2008 Toyota Tundra!
  2. Feb 28, 2023 at 6:05 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Don’t be that guy, please. Horns should get other drivers’ attention, not spike their adrenaline because you scared the shit out of them.
  3. Feb 28, 2023 at 6:20 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    If you are gonna be that guy, do a relay and pull trigger power from your stock horns.
    Device is train horn positive, trigger source is stock horn.
    texasrho83 and 2mchfun like this.
  4. Feb 28, 2023 at 6:55 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    easiest way is for you to get your truck running down a road, away from others, around 70-75mph. find a tree, bollard, column, or drunk driver.... and hit the item of your choice head on at speed mentioned. this will deploy the air bag within the steering wheel. once opened and accessed, you may be able to see all the wires behind the horn's button.
    below the steering wheel around the footwell is a very small and dim light. this is your "bright idea" light. it IS dim, but hopefully you'll be able to see it by then.
  5. Feb 28, 2023 at 7:15 AM
    Spend some time driving in FL and you will think differently about train horns. You just have to use them responsibly.
    Gravy likes this.
  6. Feb 28, 2023 at 7:18 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    if you swap out a factory horn for train horns, that eliminates the possibility of using them responsibly.
  7. Feb 28, 2023 at 7:32 AM
    2mchfun
    Most important thing is don't forget to get a decent life insurance policy.
  8. Feb 28, 2023 at 8:57 AM
    SwitchThrottle
  9. Feb 28, 2023 at 9:07 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I think it's a bad idea to engage your Hornblasters through the steering wheel especially if you're in an inspection state. Run a separate bump switch for the blasters.
  10. Feb 28, 2023 at 9:59 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    I’m so confused by this. If someone hits train horns at me I’m throwing roofing nails out the window.
  11. Feb 28, 2023 at 10:00 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    thats cuz you're from FL
  12. Feb 28, 2023 at 10:02 AM
    ToyoMafia
    Magic carpet.
    100%.
  13. Feb 28, 2023 at 10:04 AM
    Lol. There is a difference between responsible use and being a tyrant with them. They are not illegal other than decibels, but they can be used in emergency situations.
  14. Feb 28, 2023 at 10:05 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    that makes them illegal....the decibels:confused:
  15. Feb 28, 2023 at 10:06 AM
    HB has a wiring diagram that ties a separate toggle switch to turn them off using the OEM horn button.
  16. Feb 28, 2023 at 10:07 AM
    Outbound
    Aaron
    Northern Alberta
    I'm Canuckistani, and I'd chuck roofing nails too...
  17. Feb 28, 2023 at 10:08 AM
    Well the noise output exceeds limits, but the horns themselves are not illegal.
  18. Feb 28, 2023 at 10:10 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    right.
    kinda like me packin heat. it's not illegal to own, until i flash it in to the ladies in public
  19. Feb 28, 2023 at 10:11 AM
  20. Feb 28, 2023 at 10:34 AM
    ToyoMafia
    Magic carpet.
    I’ll take my $500 fine for littering
  21. Feb 28, 2023 at 12:06 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Or the guys :boink:
  22. Feb 28, 2023 at 12:06 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    $500 + roofing nail cost
  23. Feb 28, 2023 at 12:46 PM
    Outbound
    Aaron
    Northern Alberta
    $503 in Freedom Bucks. A cool half million in Canuckistani Pesos with today's exchange rate.
  24. Feb 28, 2023 at 12:52 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Train horns are for teenage douche bags. It's always a truck, wanna be cool, put them on a Geo metro.
  25. Feb 28, 2023 at 12:53 PM
    Outbound
    Aaron
    Northern Alberta
    Real men use ship's foghorns
  26. Feb 28, 2023 at 12:54 PM
    ToyoMafia
    Magic carpet.
    For real. Almost posted the same comment but Tracker instead. lol
  27. Feb 28, 2023 at 12:55 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  28. Feb 28, 2023 at 1:01 PM
    Outbound
    Aaron
    Northern Alberta
    People who put train horns on trucks are the same people who put spinners and a Carolina Squat on 20 year old Chevy pickups.
    camron1039, Gravy, 1lowlife and 7 others like this.
  29. Feb 28, 2023 at 1:09 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I like to think train horn aficionados ain't as bad as these guys:
  30. Feb 28, 2023 at 1:15 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    truck nutz, deep dish wheels, and flipped up tow mirrors. the trifecta.
