Oil analysis report 1000 miles
Discussion in '3rd Gen Tundras (2022+)' started by TundraWorkHorse, Feb 27, 2023.
  1. Feb 27, 2023 at 6:57 PM
    TundraWorkHorse
    TundraWorkHorse [OP] New Member
    2023 Toyota Tundra Platinum
    Here are the results . Ill call them tomorrow to discuss the results.
    I just called them to discuss the report . The lab technician failed to take into account that it was a brand new vehicle with only 1000 miles .
    Silicone high level - Normal for new engine assembly due to sealants used . This should drop significantly by the 2nd and 3rd oil change.
    Fuel dilution not uncommon and typical for combustion engines
    Viscosity is slightly high for the type of oil ( max should be 7 , I am at 6.5 ).
    Thoughts and opinions welcome . I will do another check at 5000 miles .
    Note - love the truck
  2. Feb 27, 2023 at 6:58 PM
    TundraWorkHorse
  3. Feb 27, 2023 at 7:03 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    woah
    Wallygator and Eurodriver like this.
  4. Feb 27, 2023 at 7:16 PM
    SupraDrew
    SupraDrew New Member
    Andrew
    2023 Tundra Platinum 4x4 LB
    I just changed my oil at 1500 miles, i was surprised how dirty it looked with such low miles. I am a every 5k oil change person anyway.
    Very interesting results, especially all the fuel in the oil.
    Thanks for posting results.
    Kap1 likes this.
  5. Feb 28, 2023 at 12:43 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Which company is this?
    Usually I only see Blackstone lab tests. What made you decide to go with this different company?
    FirstGenVol likes this.
  6. Feb 28, 2023 at 1:14 AM
    roaming-art
    roaming-art New Member
    What does something like this cost? Very interesting results, wonder where the fuel is coming from.
  7. Feb 28, 2023 at 2:08 AM
    Leaking injectors, long idle times, or rings not properly seated.
    Personally, I have always drained the oils within the first 1500 miles and it's never been a bad choice for this guy.
  8. Feb 28, 2023 at 2:20 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Just like a human, slowly calcifying all its veins... what the test results don't show btw...
    ryanwgregg likes this.
  9. Feb 28, 2023 at 2:22 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Interesting results, thank you for posting ! I wouldn’t be overly concerned, possibly do another sample at 2nd or 3rd oil change. A brand new engine will typically have lubes and micro debris present. Along with fuel blow by at the rings until properly seated. After 5000 miles foreign substances should decrease substantially after proper break in. I’ll be doing my first oil change between 1000 and 2000 mi. and expect to see minor metallic particles and discoloration at first change.
  10. Feb 28, 2023 at 3:42 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    I didn't send mine off to Blackstone but this makes me glad I did an early change at 1139 miles. Maybe I'll do a Blackstone next time.
  11. Feb 28, 2023 at 3:46 AM
    TundraWorkHorse
    Im not concerned since its the first oil change. Contaminants from a new engine assembled could be the issue but now I have a base line to view.
    Our business is in the US but I'm based in Canada and we used a local company for $25 .
    Soupbean77, Mattedfred, Kap1 and 3 others like this.
  12. Feb 28, 2023 at 3:54 AM
    blanchard7684
    blanchard7684 New Member
    these oil condition reports are nice, but to get to "how dirty" the oil is ISO 4406 particle counting is needed.
  13. Feb 28, 2023 at 4:33 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    If that oil is already shot at 1,000 miles, I pity the fool who runs their new truck to the first 10k service on the factory oil.
    Eagleye, FirstGenVol, STEPBRO and 8 others like this.
  14. Feb 28, 2023 at 8:12 AM
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    Always changed oil first 500 miles. Have seen too many oil analysis like this to risk an engine failure.
    Adding Additional Comments
    Changed Oil at 500 miles. Am changing again at 3000 Miles in next two weeks. Will be submitting Blackstone analysis from this change
  15. Feb 28, 2023 at 8:23 AM
    Pandarturo
    Pandarturo New Member
    Can’t wait to hear what the analysis company says!
  16. Feb 28, 2023 at 9:27 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    I'm not entirely dismissing the results, BUT I would be more concerned if these results were from the 2nd or 3rd oil change. There's always a far amount of containments from assembly lubes in a brand new engine. That's why there is a break-in period. Doing an analysis during the break-in period seems a bit of a waste to me, but I'm old school.
    This isn't focused at the OP, but more of a statement about the direction the comments on these types of threads tend to go:
    I know a lot of people are looking for a smoking gun with the 3rd Gen and constantly trying to find fault with it. I own a 2022. I've got 21k miles on it. I like it. In fact, I enjoy the hell out of it. Check out my build thread if you want proof of the investment I've made into my truck. I'm 100% biased. If something happens to my truck like what happened to @HBV2017 or @northerntundra1...then sure, I'll be pissed and will probably change my tune. Maybe it'll even force me to give Ram a try (never owned one) because I've had bad experiences with every other truck maker too (Ford & GM/Chevy). But, until something happens to truck, I'm not going to spend my days looking for faults and over analyzing things.
    I'm going to drive & enjoy my truck until the day I either 1) I run it into the ground (like I did with my 2nd Gen Taco) or 2) decide to upgrade (like I did with my 4R). Hopefully, that won't be for another 10+ years, but you never know. I could get t-boned tomorrow and total my truck. The RMS in my truck might have a defect in it and develop a leak tomorrow. I might spin a bearing next week because of a bad casting or defective seal. That's why I bought an extended warranty. :notsure:
    I'm not telling people to put their heads in the sand, but I am running out of stamina for the people who jump on the "sky's falling" bandwagon on the slightest whim.
    I'll standby for the hate rain, assuming it's coming. :crapstorm:
  17. Feb 28, 2023 at 9:37 AM
    xc_tc
    xc_tc New Member
    Lots of cold starts vs total travel distance too
    raylo and ryanwgregg like this.
  18. Feb 28, 2023 at 9:51 AM
    raylo
    Frederick, MD
    Post it back to this thread so we don't miss it.
  19. Feb 28, 2023 at 9:57 AM
    Silver17
    Eastern PA
    No one has said anything of the sort. I think most people aren’t shocked that the oil on a brand new engine is going to have some break in contaminants. This just comes off as being overly sensitive to others criticisms of a truck you didn’t design or build, frankly.
  20. Feb 28, 2023 at 10:32 AM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    100% with you. I've got 15k miles on my truck and it's fantastic! If something happens that changes my mind I'll happily share it here. I'm hopeful/doubtful that, that will happen.
  21. Feb 28, 2023 at 11:00 AM
    KroppDuster
    Bilstein 5100s
    Not really, but ok. My post was more about comment trends in general. You're focusing it specifically to this thread, but I understand that perspective. I'm totally open to criticism of the 3rd Gen Tundra, but again...my patience if thin for people who provide criticism only for criticism's sake. I.E. To sensationalize stuff.
    You interpret my post how you want. I see lately whenever you venture into the 3rd Gen forum, it's to participate in negative threads. So your interpretation of my post isn't all that surprising.
    Also, based on your own post, you seemed surprised by the oil results. :hattip:
  22. Feb 28, 2023 at 11:29 AM
    Silver17
    Eastern PA
    Yes oil results were a tad surprising given it was just 1,000 miles sure, but nowhere did I allude to it being a red flag in regards to whether one should purchase a 3rd gen as you seem to be suggesting. I’m sorry you have noticed my presence on this forum open for public comment, and are offended by my frequenting of some 3rd gen threads that are related to problems they may have. Those threads get hopping and keep jumping to the top of the list, so I tend to check them out. Damn me sometimes I even comment.
    Perhaps those threads are just plentiful, and I must have wrongfully thought I was allowed to engage in tundra related discussion on a tundra forum in regards to a vehicle that could be a prospective purchase. If you like I’ll just avert my eyes from the 3rd gen problem threads and purchase one in blissful ignorance in a few years.
  23. Feb 28, 2023 at 11:33 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Wow
    All this from an oil analysis report…. Need some Midols up in here….
  24. Feb 28, 2023 at 11:48 AM
    DaveE
    DaveE New Member
    2023 Platinum Hybrid, Magnetic Gray
    Changed my oil at 625mi over the weekend and it was dark, but this is coming from a severe used truck…short trips, lots of startups, etc. Replaced with Amsoil signature series and oem filter until dealer service at 5k mi.
    ryanwgregg and Terndrerrr like this.
  25. Feb 28, 2023 at 12:24 PM
    fastarget
    fastarget New Member
    2023 Max Platinum
    Does Toyota use a break-in oil per say, or are they filling them up with synthetic at time of production?
  26. Feb 28, 2023 at 1:00 PM
    TundraWorkHorse
    Update
  27. Feb 28, 2023 at 1:11 PM
    Black widow TRD
    Manuel
  28. Feb 28, 2023 at 1:27 PM
    TundraWorkHorse
  29. Feb 28, 2023 at 1:38 PM
    I would keep it up. Early drain and fill is money well spent. Turbocharged motors require a little earlier oil changes anyway. Do mine at 5000 miles. My onboard diagnostics says I can go to 7500+ miles but never do.
  30. Feb 28, 2023 at 1:41 PM
    TSB#T-TT-MID01-22
    ryanwgregg, hagrid, Kung and 2 others like this.
