2002 4.7 knock sound. Video with sound
Discussion in '1st Gen Tundras (2000-2006)' started by appa11y, Sep 21, 2019.
  1. Sep 21, 2019 at 9:07 PM
    appa11y
    appa11y [OP] New Member
    2002 Sequoia
    So I have a sequoia with 210k miles. Runs like a champ, but has had the infamous 'cold start' knock for as long as I can remember.
    I have tried pretty much everything listed in these forums for the past 2 years. I am finally attaching a video with the sound so maybe someone can recognize it and give some ideas on how to resolve.
    so far I have tried:
    - replaced fuel injector pressure regulator.
    - sea foam full treatment
    - heavier viscosity oil (10-40)
    - only using toyota filters
    - lucas oil treatment
    - spark plug replacement
    The video switches from being in gear to out of gear. While in gear you can distinctly hear the knock. When out of gear, the sound goes away.
    any ideas or thoughts are appreciated!
  2. Sep 21, 2019 at 9:45 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    It says that the video is private.
  3. Sep 21, 2019 at 10:10 PM
    appa11y
    2002 Sequoia
    crap. thanks. I'll fix it.
  4. Sep 22, 2019 at 6:31 AM
    @Darkness could this be related to what we were just discussing with valve adjustment?
    Paging @empty_lord too.
  5. Sep 22, 2019 at 6:36 AM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Check your transmission bolts and cross member make sure none are loose first?
    Check transmission oil when was the filter changed last?.
    Sounds like a bolt on the torque converter in that area has backed off somewhere?
    TX-TRD1stGEN likes this.
  6. Sep 22, 2019 at 6:39 AM
    Transmission might make sense too. I just asssumed the knock was going away because the truck runs at a different RPM when in gear vs neutral.
  7. Sep 22, 2019 at 6:59 AM
    appa11y
    2002 Sequoia
    Interesting. I will check the transmission issues listed above. It never crossed my mind. I will report back. Thank you!
  8. Sep 22, 2019 at 7:56 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I don't think its valves. That's an odd one, I'm thinking the same as Mike that it's related to the torque converter or trans.
  9. Sep 22, 2019 at 8:09 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    thats one of those noises where you need a stethoscope really. In some rare cases ive seen flex plates crack and make a knock like noise
  10. Sep 22, 2019 at 8:36 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Had the transmission ever been worked on?
  11. Sep 22, 2019 at 1:33 PM
    appa11y
    2002 Sequoia
    Not that I know of. I got it used. I have a stack of documents with it's service history, and there is no tranny work in the stack.
  12. Nov 19, 2022 at 6:50 AM
    Mr Badwrench
    Mr Badwrench New Member
    Did anyone ever figure this out?
  13. Nov 24, 2022 at 2:29 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Buddies extremely well maintained original owner 22RE at 450k broke a Piston Ring, sounded the same.
    Curious if this was trans related.
    Why are the pics side ways? o_O
    Mr Badwrench likes this.
  14. Feb 27, 2023 at 9:12 AM
    appa11y
    2002 Sequoia
    Nope. Still making the noise. Runs like a champ. Not sure what else to check...
    MS22 and Mr Badwrench[QUOTED] like this.
  15. Feb 27, 2023 at 9:50 AM
  16. Feb 27, 2023 at 9:51 AM
  17. Feb 27, 2023 at 12:28 PM
    Mr Badwrench
    Same here. Noise persists but it runs great. I've just been ignoring it.
  18. Feb 27, 2023 at 1:21 PM
    Did you check your flex plate? :rofl:
    Mr Badwrench[QUOTED] likes this.
  19. Feb 27, 2023 at 5:10 PM
    Mr Badwrench
    I think mine is coming from the valves themselves. It sounds like it is right on top of the engine. It sounds like it is running too lean, but I don't think that's what's going on. Its worth poking my head underneath by the bell housing though, the sound might be transmitting.
    shifty`[QUOTED] likes this.
  20. Feb 27, 2023 at 5:15 PM
    Is it more of a ticking or knocking?
    My truck and a bunch of the other guys' trucks on here tick like crazy. Sounds to me like typical lifter rattle in older SBCs. I was told it's supposedly the injectors, but I'm not interested enough to unplug my injectors one by one to test that theory.
  21. Feb 27, 2023 at 5:31 PM
    Mr Badwrench
    It's clatter or a light knock is how I would describe it, and only during cold starts for probably less than 15 seconds. I've been told it is piston slap due to wear and tear and high mileage. I might believe that, the oil was not changed on time (6000-7500) miles between oil changes on dino oil pretty consistently for its 200,000 mile life.
  22. Feb 27, 2023 at 5:51 PM
    Last time I heard a sound like that it was my 81 Buick Regal with a spun rod bearing from running my engine with little to no oil for 2 months. Needed a whole lower block replacement.
    Obviously not the same as it would be much louder by now and noticeable by anyone walking or driving by.
