  1. Feb 25, 2023 at 7:42 PM
    Yeah RV plumbing is very fragile. They use a flexible PVC type of line called PEC. Lowes carries it. You can install shutoff valves in any supply line. The one that I used is a Sharkbite type of connection. I put one in the toilet supply line.
    https://www.lowes.com/pd/SharkBite-...connect-Push-to-connect-Ball-Valve/1000510587
  2. Feb 25, 2023 at 8:01 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Thanks for the heads up as I just purchased a travel trailer.
    MGMTundra18 likes this.
  3. Feb 25, 2023 at 9:06 PM
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    That would be good in my book!
    I think I’m a solid 12.9 on the dashometer. Need to hand calc to see actuals.
    ATV25 likes this.
  4. Feb 26, 2023 at 8:03 AM
    justcuz
    justcuz 2.5 Gen Member
    Looked all the snow that fell on it overnight. FB8BD130-FE85-4330-88F8-63EF53DB5E3D.jpg
  5. Feb 26, 2023 at 11:16 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
  6. Feb 26, 2023 at 2:06 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Received new OEM rotors from Sparks Parts in 3 days. The ship30 code still gets you 30% off shipping. One of the rotors has some light oxidation on it but I test sanded a section and it comes off easily enough.
  7. Feb 26, 2023 at 3:42 PM
    EigenGuy
    EigenGuy New Member
    Northern California
    2020 Tundra TRD Pro
    New to me 2020 TRD Pro with 26,000.
    Thanks to the Tundras community for all the info. Figured I'd share some of my mods and findings so far:
    BFG KO2s in 275/70R18
    Rigid SR 930314 30" Light Bar & Bumper Mount
    Caliraised Toyota Short Style Switch
    ***I wired the lightbar to come on with the high beams. The switch "arms" the lightbar on and off.
    VLEDS Interior Light Kit (5500K)
    ***The interior lights make the truck feel a lot newer, but 5500K is honestly a little rough on the eyes in the morning. I would recommend 5000K or less.
    JL Audio StealthBox
    AudioControl LC-1.800 Amplifier
    ***I chose this amp because I could use the existing JBL subwoofer speaker wires as inputs and the two 10TW3s are rated for 400W each. It also has AccuBass so in theory a LC2i Pro line output converter or DSP isn't needed. Lastly, it's pretty small which means it could be mounted on the back wall and not interfere with the seat or the sliding rear window (I used rivet nuts adn yes that's a cutting board). There is barely enough room though and you have to locate the amp strategically to miss the seat structure. The sound is honestly a little underwhelming for the price, so in hindsight I would have done a ********* sub box and a larger amplifier. It's great for normal sound, but not much for showing off.
    Links:
    Tires - https://www.tirerack.com/tires/tire...d White Letter&partnum=77R8KO2RWLV2&tab=Sizes
    Light Bar - https://www.walmart.com/ip/Rigid-In...XFvie8ZlW6m8oFKL904NAgytqtB6oUxQaAuRVEALw_wcB
    Light Bar Mount - https://www.4wheelparts.com/p/rigid-industries-bumper-mount-kit-46512/_/R-FLWB-46512
    Switch - https://caliraisedled.com/products/small-toyota-oem-style-light-bar-switch
    Interior Lights - https://www.vleds.com/14-21-toyota-tundra-led-interior-kit.html
    Stealthbox - https://www.crutchfield.com/p_13694616/JL-Audio-Stealthbox.html
    Amp - https://www.crutchfield.com/p_161LC1800/AudioControl-LC-1-800.html
  8. Feb 26, 2023 at 4:01 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Went out and played the in snow. Everyone else in the group got stuck so I had to yank them out lol. Didn’t even air down the Mickey T’s. They’ve not let me down yet.
  9. Feb 26, 2023 at 4:10 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Showoff :D
  10. Feb 26, 2023 at 6:17 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
  11. Feb 26, 2023 at 6:21 PM
    Welcome from NY.
    EigenGuy[QUOTED] likes this.
  12. Feb 26, 2023 at 7:24 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Just got stuck in my fucking driveway with this slush/snow mix that just packs into grease.
    I’ll deal with it in the morning/daylight. I don’t feel like messing with it tonight.
  13. Feb 26, 2023 at 7:24 PM
    be_unscared
    be_unscared Not a truck doctor
    Brendan
    Central Cal
    21 Army Green w/skewp 4x4
    4x4?!
  14. Feb 26, 2023 at 7:30 PM
    v137a
    v137a New Member
    2018 Red CrewMax
    Finally put on that Amp bed step I bought last summer and put a hose clamp on my tailgate hinge.
    bulldog93 likes this.
  15. Feb 26, 2023 at 7:34 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What’s the hose clamp for?
  16. Feb 26, 2023 at 7:38 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  17. Feb 26, 2023 at 7:41 PM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    Forgot to post this from Thursday.
  18. Feb 26, 2023 at 8:28 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I’ll come rescue you if needed lol
  19. Feb 26, 2023 at 8:44 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  20. Feb 26, 2023 at 9:06 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yes
    I don’t feel like digging out my traction boards or chains in the dark while it’s snowing.
    You’d wouldn’t make it past my wife’s car 3/4 way up the driveway.
    I’ll get out there in the morning and get everything moved around. I’ve been in and out a half dozen times yesterday, but tonight this shit just turned to greasy ice.
  21. Feb 27, 2023 at 5:25 AM
    Mountaineer
    Mountaineer New Member
    TN
    2019 MGM Platinum
    Did some interior chrome and silver deletion over the past couple weeks thanks to MESO Customs and AJT Design. The MESO blackout kit included vent rings, shifter/cupholder trim, and door handle covers. Replaced the silver steering wheel trim with AJT. Looks way better! I think I can live with the silver door trim but not sure what I'm going to do with the dash. Really don't want to take it all apart again and I'm a little leery about the stick-on covers. Also hit the shiny plastic on the shifter display with a couple coats of matte clear coat.20230226_110206.jpg 20230226_110212.jpg 20230226_110158.jpg
  22. Feb 27, 2023 at 5:28 AM
    Odin43
    Odin43 YNWA
    Rich
    NJ
    2021 MGM Platinum, 2015 Lexus LX 570
    Thanks for making these videos. :thumbsup:
  23. Feb 27, 2023 at 5:34 AM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    enfotainment center pillars from Amazon
    mgm16trdpro likes this.
  24. Feb 27, 2023 at 6:26 AM
    The stick on overlays leave gaps. I used SEM Trim coating on mine.
  25. Feb 27, 2023 at 6:27 AM
    CaptRussia253
    Ruslan
    Mud terrains are the new snow tires haha.
    reywcms[QUOTED] likes this.
  26. Feb 27, 2023 at 7:23 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I just replaced my radio surround with the oem black trim
  27. Feb 27, 2023 at 7:46 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Yes but if you look the overlay is on the silver radio itself
  28. Feb 27, 2023 at 7:50 AM
    ICS has a microphone mount that you can use on the Rago. That cord would drive me nuts lol.
    bulldog93 and reywcms[QUOTED] like this.
  29. Feb 27, 2023 at 7:51 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I don’t even notice it lol
  30. Feb 27, 2023 at 7:53 AM
    Lol. Nothing on my Rago yet but 2 ball mounts. My camera monitor for the travel trailer will go on it when we tow it. No idea what else yet.
