brake pads and disks
Discussion in '2nd Gen Tundras (2007-2013)' started by 08-ltd-trd-blk, Nov 29, 2022.
  1. Nov 29, 2022 at 7:17 AM
    08-ltd-trd-blk
    08-ltd-trd-blk [OP] New Member
    Hey Tundras,
    i've got to do brakes on my 08. front and rear.
    they pulsate up front which drives me nuts.
    which ones have you guys had the best results with?
    there's all kinds of kits out there on Amazon and parts stores.
    i'm willing to pay more for the good stuff, but don't wanna pay double.
  2. Nov 29, 2022 at 9:07 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Factory stuff is good. Id skip the local auto parts stuff. Cryo treated rotors are always good on a Tundra. EBC, stoptech and Akebono are popular for good reasons.
    Lots written on brakes here, search in upper right and you will find plenty of threads with details, reviews, etc.
    AZBoatHauler likes this.
  3. Nov 29, 2022 at 9:11 AM
    AZBoatHauler
    So.Arizona
    Toyota OEM will be the best bang for your buck IMO.
  4. Nov 29, 2022 at 9:39 AM
    TheBeast
    TheBeast The Beach
    here is what I have been running for the past 4 years: no issues to report.
    StopTech slotted sport rotors (F and R)
    Posi Quiet ceramic brake pads (F and R)
    my oem rotors lasted 40K ish before being warped.
  5. Nov 29, 2022 at 10:19 AM
    2mchfun
    I'm pleased with the stoptech cryo treated slotted rotors and yellow stuff EBC pads. Think it all cost me around seven or eight Benjamins though. Some say the dust is bad from the yellow stuff, I generally don't stop much though. Instead I lag behind a bit at red lights, traffic jams, etc. However, when I need to stop quick, it will shut down.
  6. Nov 29, 2022 at 11:16 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Check out the BrakeMotive store on eBay i have used them for several years without issues
  7. Nov 29, 2022 at 11:44 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I tried some Hawk LTS pads for a while, and went back to OEM pads in under 10K miles. Unless you're very abusive of the stock brakes, I'm a fan of OEM pads. Been doing OEM rotors too for a while as I haven't found anything that appear to be that much better. I have heard good things about these guys and will likely try them next time. https://www.remmenbrakes.com/
  8. Nov 29, 2022 at 12:30 PM
    Dr_Al
    Dr_Al New Member
    Al
    Make sure it's the front rotors. I've known plenty of people who spent a lot of money on their front pads and rotors only to find out it was the rear. If the pads are worn out it doesn't matter but if there's plenty of pad life left you could be spending money for nothing. With drum brakes it's easy as you could just slowly push the parking brake until it starts to grab and see if it's smooth but with rear discs you can do that.
  9. Nov 29, 2022 at 3:55 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I use OEM. Just did front rotors and front/rear pads. If you do decide to do OEM some Toyota Dealers are doing free shipping over $75 currently. I have been using Serra in Decatur lately. Sparks Toyota is also popular but their free shipping ended on the 28th.
  10. Nov 29, 2022 at 4:59 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    I also just did OEM. Not much more expensive than buying aftermarket brands on Rockauto. A no brainer for me.
    Don’t forget to order new shims and a fitting kit. It’s cheap…and if the pads on your truck are aftermarket the shims on there might not match the OEM Pads.
    baraynavab and CMikeB like this.
  11. Nov 30, 2022 at 3:12 AM
    CMikeB
    CMikeB New Member
    Mechanic tells me I'll probably get another 20k miles from my OEM brakes. I have 88,000 on them now...yep, OEM will be just fine.:D
    AZBoatHauler and Rph74[QUOTED] like this.
  12. Nov 30, 2022 at 11:54 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    Nice! For years I’ve avoided OEM parts like the plague, mostly because I’m cheap, and because my local dealerships in my small city overcharge. Now, with some dealerships selling online at a discounted price, the price is now so close to aftermarket that it doesn’t make sense to me to not buy OEM. Especially in the case of Toyota, where I have confidence that OEM parts are of high quality.
  13. Nov 30, 2022 at 12:17 PM
    CMikeB
    CMikeB New Member
    Next question will be how much have Toyota's beancounters messed with the quality of OEM parts? Especially for my 2010.
  14. Nov 30, 2022 at 12:41 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    One thing I like about OEM Toyota parts are they’re either made in the USA or Japan. Other than oil filters. Toyota hasn’t disappointed me yet with their stuff.
    CMikeB[QUOTED] likes this.
  15. Dec 1, 2022 at 7:42 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    The brakes you install should be dictated by how you mostly use your truck. I installed the Powerstop Z36 kit (front and rear) because I mostly use my truck to tow my RV. I am very satisfied with the performance, whether I am towing or not.
  16. Dec 1, 2022 at 8:35 AM
    CMikeB
    CMikeB New Member
    That certainly makes sense. I tow a 3500-4000 lb load every year for a couple thousand miles. What I don't do, is jump on the brakes every time I need to slow down a few miles per hour or descend a grade. Toyota included their Sequential Shifter for that.:thumbsup:
    CTB Mike[QUOTED] likes this.
  17. Dec 1, 2022 at 10:34 AM
    08-ltd-trd-blk
    my dealer helped me out a little on the parts, still dropped 425 on OEM Parts.
    better than the 575 they initially quoted me....but a good bit more than the aftermarket kits.
    grave likes this.
  18. Dec 5, 2022 at 8:18 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    centric premium rotors are great. OEM pads for sure
  19. Dec 6, 2022 at 7:09 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    How much did the OEM front Pads and Rotors run? and do they OEM stuff make brake noise before they are about to go?
  20. Dec 6, 2022 at 7:38 PM
    texmln
    texmln New Member
    I second the Centric on rotors and their PosiQuiet pads. I always have a good experience with them and they come at a decent price.
    thearborbarber and baraynavab like this.
  21. Dec 7, 2022 at 5:01 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    For front brake pads, rotors, shim kit, fitting kit/anti rattle clip set-$332 including shipping
    For rear pads., rotors, shim kit, anti rattle clip set, 4 new brake pad pins-$344 including shipping.
    baraynavab[QUOTED] likes this.
  22. Dec 7, 2022 at 6:05 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    ^^^I forgot to mention, I bought my parts online from Toyota Parts of Olathe,KS. My local dealership charges much higher prices, so I don’t even bother checking with them anymore.
    CMikeB likes this.
  23. Jan 2, 2023 at 9:02 AM
    Chadwicktr
    Chadwicktr ‘08 DC X-SP 5.7
    Raleigh
    Thanks for sharing. Their prices seem super cheap.
  24. Jan 3, 2023 at 4:31 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    Glad that helped. Yeah, their prices are great, still cheaper even with shipping costs. Hard to beat the convenience.
  25. Jan 22, 2023 at 9:33 AM
    Bgkahuna11325
    Bgkahuna11325 New Member
    Gene
    2011 Toyota Tundra SR5 Crewmax
    I have found, that after replacing rotors and brakes, it is important that when you re-install the tires/wheels. you torque them to specs. (Steel wheels are around 150 and alloy wheels are around 100 foot pounds) DO NOT depend on the dealer, tire shop, etc to do it. It needs to be done correctly and the only way to ensure that is by doing it yourself. I had a tire shop "say' they torqued the lugs. but what I found was that they used a gun to put the lugs on (later found to be about 210 foot pounds), then use the torque wrench at 150 foot pounds. Anyone see an issue with this???? When you get home, remove the lugs, and redo them correctly with a torque wrench. Since then, I have not had a rotor warp and no shimmy in the braking.
  26. Jan 22, 2023 at 9:57 AM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    I used Advics on rockauto, they seemed identical to the factory stuff I took off. I kept the OE shims because they seemed better than the stuff that came with the Advics pad set. Rotors were identical, pads just had different shim kits.
    WILLINH likes this.
  27. Jan 22, 2023 at 9:59 AM
    2mchfun
    I suppose there could be some science behind that. The rotor is being compressed between the hub and the wheel. With temperature changes when operating the pressures exerted on the system components would vary depending on the torque. The lug bolts themselves, the hub, and the wheel would also expand at a higher temperature as well. So, all in all it becomes a bit complex, especially when you factor in airflow at different speeds, friction, water puddle splashes, etc. Personally, I never had a problem with the German torque spec of gudentight on every vehicle I have ever owned. I think most brake problems are caused from poor driving not lug nut torque. Just my opinion.
  28. Feb 26, 2023 at 1:05 PM
    homeyclaus
    homeyclaus New Member
    2013 Spruce Mica CM TRD
    Leer 100XL cap, Icon front susp and rear shocks, OME springs, WKOR sliders, RCI skids, Exp1 bumper
    Uneven lug nut torque is definitely a variable on many vehicles. Also, the washer on the Toyota truck lug nuts lend themselves to overtightening if the right kind of grit gets between the washer and the nut, and this will cause stretching or snapping of the stud. Does torque matter on a Tundra? I don't know for sure, but I torque everything because it's an easy variable to control.
    As far as brake components go, if you get a deal on OEM, go for it. I am partial to Wagner OE-X pads on my truck, they do very well towing our trailer and don't head fade as badly as some of the others I have tried. Next brake job a set of Centric premium coated rotors will go on front and rear, although I have had great luck with the OE rotors, I still have factory rotors on there after 122k miles.
