EEF Qi Charger v2 Release and Dual Charger Sneak Peek…
Discussion in '3rd Gen Tundras (2022+)' started by Front_Range_Pro, Oct 28, 2022.
  1. Feb 23, 2023 at 8:04 PM
    #331
    lammarwell
    lammarwell New Member
    Scott
    2023 Black Tundra TRD Pro
    Full Expel PPF in satin black, Halo Ceramic, tinted windows including windshield,JB4 tuner, Bonoss 1 1/4' wheel spacers, Bakflip MX4 cover, lift assist air bags, Wescott 3/1 lift and 37/12.5/18 Nitto Ridge Grapplers on the way.
    Interested as well...can you throw me on the waiting list please?
  2. Feb 23, 2023 at 8:18 PM
    #332
    Front_Range_Pro
    Front_Range_Pro [OP] EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    ryanwgregg likes this.
  3. Feb 24, 2023 at 6:44 AM
    #333
    colekbod
    colekbod New Member
    2023 SR5 Sport Lunar Rock
    Installed mine yesterday. It looks great and charges surprisingly fast. I do plan to eventually hard wire a USB port under the dash and connect it to that to free up the center console port.
    Great product so far. I'm sure you will sell a ton of these.
  4. Feb 24, 2023 at 8:27 AM
    #334
    Front_Range_Pro
    Vail, Colorado
    That’s great!
    Both of you were original waitlist members. Thanks for your guys’ support and patience. I pass along all your guys’ comments and input on the EEF honcho and I think I can speak for him in that he is equally as stoked you guys are happy with the chargers.
    Jonathan
  5. Feb 24, 2023 at 8:48 AM
    #335
    Jasco1
    Jasco1 New Member
    23 SR5 Crewmax TRD OR Lunar Rock
    Is there an on/off button? My wife’s Camry has the wireless charging pad and you can turn it off. I don’t want my phone charging nonstop when driving.
  6. Feb 24, 2023 at 8:50 AM
    #336
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Usb port is dead when the truck shuts off
    Jasco1[QUOTED] likes this.
  7. Feb 24, 2023 at 8:53 AM
    #337
    Breathing Borla
    AZ
    so take it off the charging pad man, lol.
  8. Feb 24, 2023 at 8:54 AM
    #338
    Breathing Borla
    AZ
    all I need is my tundra now, lol. Im going to keep running this in the garage just plugged into my power strip. so far it has nice charging power for wireless and its not finicky on location , does not get anything more than Luke warm when on there for a few hours
  9. Feb 24, 2023 at 12:05 PM
    #339
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    @Front_Range_Pro I have some questions, I assume that the charging icon on the 14" display works? I haven't been able to get the OEM charge pad to work at all with my Pixel 7 Pro (phone is very picky for wireless charging) and I'm now really considering this now!
    And, do you ship to Canada? Sorry, didn't do the check-out on your website!
  10. Feb 24, 2023 at 4:26 PM
    #340
    Front_Range_Pro
    Vail, Colorado
    Great questions!
    The icon in Apple CarPlay run through the iPhone itself. It’s a mirroring software so if the phone is indicating it’s charging, that will reflect in the screen.
    The issues you are having with the OEM charging unit is pretty much standard and was the the reason for our charger development.
    As for shipping, the answer is most definitely YES! However please keep in mind that there may be extra costs associated with shipping and customs.
    Jonathan
    jproy12[QUOTED] likes this.
  11. Feb 24, 2023 at 5:51 PM
    #341
    Breathing Borla
    AZ
    Isn’t the light color backwards?
    red light is on when nothing is on it and green light comes in when you add something to charge
    Most things are green meaning ready to charge and red meaning charging
    not a huge deal but curious
  12. Feb 25, 2023 at 10:13 AM
    #342
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    Installed mine today and wired the power to the fuse block under the glove box. Works fantastic, thanks for the hard work. Looks OEM, install was easy with the video, shift knob was the hardest part, phone camera trick worked well.
    Beams37 likes this.
  13. Feb 25, 2023 at 12:22 PM
    #343
    myerswoodshop
    myerswoodshop New Member
    2022 Toyota Tundra Platinum
    Can you show how you wired it like this?
    Breathing Borla likes this.
  14. Feb 25, 2023 at 7:36 PM
    #344
    KClav
    KClav MGM Limited
    I installed it per the instructions on the EEF YouTube link except for plugging the USB into the console. Instead, I ran the USB to the passenger side floor board area. It’s evident when you’re installing it. Just route the USB right and down. It pops out by the passenger floor board. I removed the panel below the glove box and that gives access to the fuse block under the right side of the glove box. I removed the 10A spare fuse noted on the fuse box cover and installed a fuse tap. Wired the positive of the fuse tap to the positive of the 12V USB. I wired the negative of the 12V USB outlet to a bare screw to the lower right of the glove box. I had to take the lower right kick panel off. I then plugged the EEF USB cable into the 12V USB outlet and it worked perfectly. I zip tied the wires to some existing wires in the same area.
    I basically got the idea from the post below that shows the Fuse Tap product and the 12V USB outlet. I used the exact same ones.
    https://www.tundras.com/posts/2880348
    40man and Henry1jg like this.
  15. Feb 26, 2023 at 8:29 AM
    #345
    murtro
    murtro Life is unpredictable. Eat dessert first!
    Alberta
    Thanks for posting this - the result would be as close to OEM with everything out of the way = Nice! Does it provide the same amount of power as the console USB port? Also, how do you connect the fuse tap hot to the 12V USB - strip the wires (sorry for the newb questions)??
  16. Feb 26, 2023 at 9:00 AM
    #346
    KClav
    KClav MGM Limited
    This provides the same power as the USB console port.
    I cut the blue crimp connector from the fuse tap and I cut the wire from the USB port before the in-line fuse (got rid of inline fuse and attached connector). I then stripped about a 1/2" from the end of each wire and connected them with a heat shrink solder connector that I had from a previous project. It is basically something like the green connector out of the pack in the link below:
    https://www.amazon.com/Connectors-C...&qid=1677430693&s=merchant-items&sr=1-13&th=1
    murtro likes this.
  17. Feb 26, 2023 at 4:43 PM
    #347
    Dugnor
    Dugnor New Member
    2022 Tundra 1794 WCP
    Maybe switching the red and green wires on the LED would flip the colors?
  18. Feb 26, 2023 at 5:15 PM
    #348
    Breathing Borla
    AZ
    doenst bother me enough to rewire what they did, just throwing that out there for the consideration of the next batch
    it’s kinda universal that green means ready red means charging, this is backwards
    Dugnor[QUOTED] likes this.
  19. Feb 27, 2023 at 7:25 AM
    #349
    BillorJackorPeteorDennis
    BillorJackorPeteorDennis New Member
    Washington, DC
    ‘25 TRD Pro - Mudbath
    I can see it both ways (the LED colors).
    Red means OFF - doing nothing but powered and ready
    Green means ON - unit is doing something
    Many of my pilot lit appliances and electronics are the same way so I didn't lose any sleep over this issue. But yes, my phone equipment is opposite.
    Perfect world:
    Blue or Amber = powered and ready to work
    Red = working
    Green = connected to phone but phone fully charged.
    FYI -- installed Saturday. Took a bit longer than expected, but I did tap in to the fuse block under the glove box, and I agree that the shifter was the most annoying step.
    I will say that after two days of driving around with this new charger, there's a night and day difference. My phone battery charge percentage is ACTUALLY higher at my destination; with the OEM charger I would be lucky just to be at the same charge level as when I started.
    Bravo guys! Thanks for the time and effort.
    Krusher22plat likes this.
  20. Feb 27, 2023 at 7:52 AM
    #350
    Dugnor
    Dugnor New Member
    Curiosity got the best of me last night, so while I'm waiting for my fuse tap to do my install I switch the red and green wires on the LED. It gave me the OEM charger colors of light green not charging dark green charging.
  21. Feb 28, 2023 at 1:01 PM
    #351
    Front_Range_Pro
    Vail, Colorado
    I see this seems to be a common suggestion amongst some. I’m talking to the product development guy. We are looking into switching the LEDs or finding a factory color option.
  22. Feb 28, 2023 at 2:05 PM
    #352
    eddiefromcali
    Eddie
    100% Stock
    I'd just keep it consistent with whatever the oem charger displayed. No need to change it to anything else.
  23. Mar 5, 2023 at 2:18 PM
    #353
    Dugnor
    Dugnor New Member
    Got my charger installed today, works great. This is what it should have been from the factory!
    One tip that may be helpful, when removing the shifter knob, pull the boot down, on the front (meaning the part facing you) driver side of the knob you can feel part of the clip sticking out. Push that towards the driver door while pulling up. Easy peasy.
  24. Mar 5, 2023 at 7:08 PM
    #354
    Front_Range_Pro
    Vail, Colorado
    EEF still developing cool charging solutions.
    Dual Charger solution is finally taking shape in prototype form.
    Also still trying to figure out a solution for direct plug-in. There are multiple factors affecting the viability of the OEM plug option. I know many people prefer this method. But it is still on the radar. “
  25. Mar 9, 2023 at 8:21 PM
    #355
    Front_Range_Pro
    Vail, Colorado
    OEM-style dual charging action…
    iPhones 14 Pro Max and 12 Pro Max
    (Prototype testing)
  26. Mar 10, 2023 at 8:08 PM
    #356
    HeavyB
    HeavyB New Member
    Joe
    any updates? Are you using stock wiring or plugging it into the usb port?
  27. Mar 15, 2023 at 9:52 AM
    #357
    Derff
    Derff New Member
    Fred
    Southern California
    2022 Tundra
    Westcott lift, wheels, and Tires
    Thanks Front_Range_Pro! I just ordered my QI charger. :spending:
    Front_Range_Pro[OP] likes this.
  28. Mar 15, 2023 at 10:50 AM
    #358
    manapiko
    manapiko New Member
    Patrick
    Soon to own 2023 TRD Pro
    I for sure will buy a dual charger that plugs into the existing plugs. And understand that drives up costs, but definitely worth it.
    Edit: I'd prepay too, if that helps dev/prod costs
    SecrITSociety likes this.
  29. Mar 15, 2023 at 1:47 PM
    #359
    Front_Range_Pro
    Vail, Colorado
    It is important to note that while we are still trying to devise a solution for this, it is still in the R&D phase with heavy emphasis on “research” aspect. Finding/creating the correct plug connector is actually the easiest part of it. EEF loves the challenges of developing solutions but won’t sacrifice quality or safety for an extra USB port.
    Speaking personally, for a truck that costs $55k-$75k+, I would want quality products in it and on it. But I just want quality stuff in all my vehicles anyway no matter if it’s my Tundra or my girlfriend’s RAV4 :thumbsup:
    Ideally, we want to make a plug and play dongle that will allow current Qi-Charger customers to upgrade their current cords to a plug as well as offer it for future customers.
    Thanks for everyone’s patience on this.
    Jonathan
  30. Mar 18, 2023 at 8:08 PM
    #360
    majking68
    majking68 Going "Green"
    Tony
    Kansas City, Missouri
    2022 Limited
    Lifted
    Put me on your list for a OEM-style dual charger finished product. (22 Limited)
