Bilstein level lift nose high - Now what?
Discussion in 'Suspension' started by Rockwell, Feb 26, 2023.
  1. Feb 26, 2023 at 7:20 AM
    Rockwell
    Rockwell [OP] New Member
    New Jersey
    2021 Tundra Crew Max SR5
    Hello all,
    I need your advice...
    Am new to the forum. I'm also new to Toyota and Tundra. One month ago I purchased a 2021 Tundra CrewMax SR5 and immediately began to make it mine. I have blacked out the windows, done a few interior mods, have a new set of SRS Ray10s waiting to be put on as well as 275/70/R18s
    I had a well known 4X4 shop install Bilstein 5100s to level the truck out. Thanks to the knowledge on this forum I asked them to set to middle setting, but they insisted that highest setting was needed to achieve level. I went with it.
    Now Im nose high by about .50 - .75 inch. At first I tried to accept it, but I just don't like it. I want a slight rake, nose down. Picture below.
    Now what? Do I go back to the shop and pay to have the 5100s taken out, reset, and realignment? Or do I simply add 1 inch blocks to the rear?
    This truck has full warranty until it reaches 130K miles (currently has 34K). I'm trying to not go overboard with suspension mods and void the warranty. As it stands now, all Ive done is change my shocks. I'm afraid adding a block will give Toyota reason to void warranty. Am I overthinking?
    I do very little off-road, I'm 99.3% highway.
    All I wanted was level, I never intended to modify the rear height, although I do like the height of the front end. Then there's so many posts about block failures, but maybe 1 inch isnt a concern?
    What would you do???
    Thanks for the help!
    mattyd170 likes this.
  2. Feb 26, 2023 at 7:32 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    If I were you, I'd go back to the shop and show them that it's nose high and have them put it to the middle setting like you wanted in the first place. That's their fault 100%. You shouldn't have to pay again. And welcome to the forum!!
  3. Feb 26, 2023 at 8:05 AM
    Kbo
    Kbo New Member
    British Columbia
    2019 Double cab
    A bit of a lift, compressor, bags
    Looking back there’s always 20/20 vision. Middle setting is nice and there’s less angulation on the CVs. You could try getting them back to what you originally wanted but you ultimately allowed them to make the change. Hopefully they’d help you out.
    Anyhow, a 1” shackle lift on the rear works great. I have a picture of mine with the middle setting and a 1” shackle lift and it’s perfect for me.
    As far as warranty, I don’t know. I’d bet that if there was a driveline issue nor suspension issue they could connect it back to the mods, creating a headache. I did mine under warranty, too, but my tolerance might be higher than yours.
  4. Feb 26, 2023 at 8:07 AM
    Kbo
    Kbo New Member
    British Columbia
    2019 Double cab
  5. Feb 26, 2023 at 8:40 AM
    MULLI63
    MULLI63 New Member
    Southern California
    2015 Tundra Platinum, SnugTop Shell, Gray
    Bilstein 5100 all four corners - front at top setting Ready Lift 1” rear block 295/70R18 Falken Wildpeak Method Roost R18 Under Seat Storage Boxes - Rear Seats - see post LED Interior Lights LED Mirror, Back-Up and License Plate Lights Added Auxiliary Fuse Box and Battery Switch Plasti-Dip Chrome Mirror Covers and All Badges to Black WeatherTech Bed/Tailgate Liner Replaced tailgate strut Working On Modifications: Add Oh Sh!t Handle To Driver Side A Pillar LED Head and Fog Lights
    I lifted my 2015 with 5100s on high setting and 1” block in the rear. Has a slight rake, but will be towing in the future. Looks mostly level.
    If you go with blocks, 275/70 may be a bit small. I went with 295/70 Falken Wild Peaks.
    I’ll upload picture in a bit.
    MedCityMoto and Rockwell[OP] like this.
  6. Feb 26, 2023 at 8:46 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Post a pic of the lower perches on the shocks. It’s somewhat common for shops (or DIYers) to put the perches on upside down and give way too much lift.
  7. Feb 26, 2023 at 8:53 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  8. Feb 26, 2023 at 9:38 AM
    Rockwell
    New Jersey
    Here's a shot of lower perch, I don't think it was a bad install, just a bad choice of setting.
    landphil and TRDFerguson[QUOTED] like this.
  9. Feb 26, 2023 at 9:40 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Ok those look correct. I’d say make them drop it to the mid setting like you wanted then. Or get shackles for the rear like @saybng mentioned. You don’t have any shims or spacers on the top right?
    Rockwell[QUOTED][OP] likes this.
  10. Feb 26, 2023 at 9:42 AM
    Rockwell
    New Jersey
    Yes, this is exactly the stance I'm looking for, and you are on middle setting.
    I agree, it would be nice if they would offer to help me out, but i highly doubt it. I agreed with them and OK`d it. I hate to have to, but I don't even mind spending the money to correct it, I just want to go about it the best way, which is why I'm torn between a Redo, Block, or even shackle.
  11. Feb 26, 2023 at 9:43 AM
    Rockwell
    New Jersey
    I would like to see that pic, thank you.
  12. Feb 26, 2023 at 9:45 AM
    Rockwell
    New Jersey
    Correct, no shims, no spacers. Bone stock except for 5100s
    I just dont know what route to take! Analysis Paralysis!
  13. Feb 26, 2023 at 9:47 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    This, X infinity. And beyond.
  14. Feb 26, 2023 at 9:48 AM
    Rockwell
    New Jersey
    What size shackles would I add? +1?
    Im going to try and measure the exact difference today when I get to good level ground.
  15. Feb 26, 2023 at 9:49 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Next question, did the shop do an alignment? That can also make a big difference in final stance.
  16. Feb 26, 2023 at 9:49 AM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Might try Icon 1.5 add-a-leaf lift springs in the back. It works pretty good for me.
  17. Feb 26, 2023 at 9:50 AM
    Rockwell
    New Jersey
    They did, and even provided me with a print out of all the alignment specs.
  18. Feb 26, 2023 at 10:25 AM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Redo. Lifting it more does nothing good for you on the street, and isn't even optimal in most offroad situations.
    I'd try to get them to at least give you a discount, since they certainly have some negligence there in advising the top setting. What did they charge for the install?
    Also, if you haven't driven it much... wait until you've got a few miles hitting bumps. They do tend to settle a little.
  19. Feb 26, 2023 at 11:07 AM
    Rockwell
    New Jersey
    I am leaning that way, Redo. I just had this done Yesterday. I have only driven about 100 miles so far. I don't think they will settle, the springs are original and I would imagine fully settled by nowI. The shock itself I don't believe holds any weight.
    I'm going to call them and see what they say. I paid $930 for shocks and install. Yes, very expensive, but I knew that going in. They are a widely known shop, I wanted it done right, (haha), and I wanted to trust the workmanship, which I still do.
    WFD473 and rruff[QUOTED] like this.
  20. Feb 26, 2023 at 11:08 AM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    Ultimately, you might have to pay to get it right. But I would have them fix it and put the 5100s in the middle. It is unfortunate but not negligent on anyone's part. Just fix it, pay for the mistake, and be happy. You will be chasing all sorts of magic dragons now with adding to the rear to correct and/or fix the look you are looking for. Middle will ride great, give you a look you want and allow you to do bigger tires later if you want—my 2 cents.
    When I did my 2012, I did the middle setting and then added the coachbuilder shims, 2 on the left, 1 on the right, because much easier to add or subtract those then pull coil, unspring it, move and then reinstall that coil.
    On my 2020, I added the TRD pro front shocks with 1 shim on the driver's side. Now I need to get it aligned too.
    Rockwell[OP], bflooks and rruff like this.
  21. Feb 26, 2023 at 12:07 PM
    Mstaz
    Mstaz New Member
    Good comments above. With middle setting, you should be level. I have the 5100s up front on the highest setting and have toytec shackles in the back for +1. This results in a bit of rake, and level when I’m towing my utility trailer or have a dirt bike and gear in the bed.
    Rockwell[OP] likes this.
  22. Feb 26, 2023 at 12:11 PM
    rruff
    rruff New Member
    I dunno. I think since he went in asking for middle and they talked him into top, they have liability. Absolutely.
    "Front 5100 Series height adjustable front shocks provide 0.87, 1.57 or 2.28 inches of lift." Just based on Bilstein's spec you wouldn't pick the top unless you wanted to risk being nose high. 2.28" is at the extreme high end of normal rake for a stock truck. I think ~2.1" is typical.
    OP, if you haven't yet, park on some good level pavement and measure all of them, and see what you get.
    Rockwell[OP], WFD473 and mattyd170 like this.
  23. Feb 26, 2023 at 12:21 PM
    Kbo
    Kbo New Member
    British Columbia
    2019 Double cab
    I bought BDS 1” shackles. Nobody had the toytec shackles it seems and coach builder seemed expensive. I would not purchase the 1.5” - too tall - especially if you are wanting it to sit more level at the mid setting for the front.
  24. Feb 26, 2023 at 1:48 PM
    Rockwell
    New Jersey
    "You will be chasing all sorts of magic dragons now with adding to the rear to correct and/or fix the look you are looking for"
    Very well stated and precisely why I'm reluctant to block or otherwise raise the rear to chase the front end.
    THANK YOU ALL for the GREAT feedback... huge help to me!
    bflooks likes this.
  25. Feb 26, 2023 at 1:50 PM
    Rockwell
    New Jersey
    I'm going to get precise measurements tomorrow. I'll keep you posted. Thank you
  26. Feb 26, 2023 at 1:55 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  27. Feb 26, 2023 at 2:07 PM
    Rockwell
    New Jersey
    Thanks! I will absolutely do that. I'm getting measurements tomorrow. At most I'm thinking it's 0.50 higher than rear, and maybe even less. It's funny sometimes I think it's nose high, then other times it looks about dead level.
    If I go the shackle route, I'll definitely take em of your hands.
    TRDFerguson[QUOTED] likes this.
  28. Feb 26, 2023 at 2:18 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Take it back, get it to the middle. Truly
    Don't go shackles unless you want the softer ride, and even then, it's a different discussion, as poly bushings with factory shackles addresses this.
    The roof line on this truck doesn't help matters. 100% level will leave it looking nose high. Measure, and subtract 1/2 for front setting if you want it to "look" right. Otherwise, I bet they are within 1/4", which is nothing over 19'
    Rockwell[QUOTED][OP] and WFD473 like this.
  29. Feb 26, 2023 at 2:26 PM
    biebs96
    PA
    I agree, take it back. You told the shop you wanted middle setting, they swayed you to go top setting.
    Not sure about cost, but I’d be surprised if they do it all over again for free. Maybe negotiate for half of the cost, since it’s not what you asked for originally.
    Good luck.
    Rockwell[OP], bflooks and WFD473 like this.
  30. Feb 26, 2023 at 5:39 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I’d push pretty hard for a free redo.
    Yes, you agreed to their recommendation, but they are a very reputable shop and their expertise led you to believe that they knew their business.
    Honest mistake on their end, and a good shop would see it as just that. They told you it would be level, and it apparently is not. Give them the opportunity to correct it and make you a customer again when you need more stuff. A couple hours of labor to correct this will not sink them!
    WFD473, Rockwell[OP] and rruff like this.
