Shifter Knob
Discussion in '2.5 Gen Tundras (2014-2021)' started by JWWard03, Feb 25, 2023.
  1. Feb 25, 2023 at 9:12 AM
    JWWard03
    JWWard03 [OP] New Member
    James
    2021 Tundra SR5 CrewMax 4x4
    Are there any options to replace the shifter knob? See a bunch of stuff on Amazon but they all look like they’d be too tall. The shaft is way too long to make sense for an automatic with no button. Just want something more low profile.
  2. Feb 25, 2023 at 9:22 AM
    awq735
    awq735 New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    I have the silver TRD shift knob. It came on my truck from the dealership. I think it looks much better than the factory shift knob.
    IsaiahCanada, 1lowlife and Taco-Spike like this.
  3. Feb 25, 2023 at 9:25 AM
    Taco-Spike
    Two Trucks
  4. Feb 25, 2023 at 9:26 AM
    Labrayota
    Labrayota New Member
    Central Illinois
    2017 Crewmax TRD Off Road MGM
  5. Feb 25, 2023 at 9:26 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    They also offer a totally black option.
  6. Feb 25, 2023 at 11:33 AM
    Bergy24
    Bergy24 New Member
    Teton for the win.
    V3N0M, Rockwell, Kitt and 1 other person like this.
  7. Feb 25, 2023 at 11:38 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
  8. Feb 25, 2023 at 11:52 AM
    awq735
    awq735 New Member
    Anthony
    Ohio
    I wish I had the black one, but I still like mine over stock!
  9. Feb 25, 2023 at 12:01 PM
    JWWard03
    James
    Is it possible to remove/replace/modify the shifter pole itself?
  10. Feb 25, 2023 at 12:56 PM
    bulldog93
    Jeff
    Buy the black one and sell the silver one. That's what I did.
  11. Feb 25, 2023 at 7:27 PM
    GravityGear
    Aurora, CO
    I have not found a way to do that. You'd have to remove the assembly, take it apart, remove the shaft, cut it, machine it down, then re-thread it. You'd need a lathe.
    bulldog93 likes this.
  12. Feb 25, 2023 at 7:43 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Back when I had my candy, I just used a hack saw to cut the threads down to shorten it and threaded a Lexus is250 knob on it.
    May be an option to cut it down (but I guess that would only shorten it slightly) if you don’t like the look of the shift knob options that fit
  13. Feb 25, 2023 at 7:55 PM
    CTundraForMe
    CTundraForMe New Member
    I have the TRD one - it came with my TRD Pro - and it's a bit loose, for lack of a better word. That is, it can be lifted off the rod a good 2 inches, and can spin around. Haven't found a way to tighten it up, if it can be tightened up.
    But it looks good.
  14. Feb 25, 2023 at 8:37 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I am really happy with the black TRD knob. This is simply what should have come on these trucks. 7EF385CA-675F-45A0-9E00-0F70B3DC00E0.jpg
    TRD ROB, 1lowlife and bulldog93 like this.
  15. Feb 25, 2023 at 10:49 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Do you want it black?
    Just put some shrink wrap on the shaft and take some heat to it.
    dh6nc8v6_zpseu3zve2d_13475190514dd9bca1fbf4204eecebffa8ee1137.jpg corwv1ob_zpsdajt4wcz_c6107058a1e9c0aa49225244e0662712a7543728.jpg
    ^This.
    There is a #2 Phillips head screw in the top of the shaft hole.
    Try pulling the knob, taking a long shaft #2 Phillips screwdriver, sticking it in the knob, and tightening that screw.
    I've had to do that on both my TRD shift knobs.
    76BBB533-6F30-45AA-94FE-F8AF0B78454E_zps_bd68934c10271efa153e61d607bcfb483a5dd6cb.jpg unljd5ry_zpsku1saqh4_d408750cb20a709f8e7895789069ddf165d2d197.jpg
    bulldog93[QUOTED] likes this.
  16. Feb 26, 2023 at 12:10 AM
    be_unscared
    be_unscared Not a truck doctor
    Brendan
    Central Cal
    21 Army Green w/skewp 4x4
  17. Feb 26, 2023 at 6:51 AM
    Foxtrot704
    Foxtrot704 New Member
    Daniel
    2020 Silver Metallic Tundra SR5
    FOX 2.0 leveling coilovers and rear shocks, ARB twin compressor, Victory 4x4 roof rack and rock sliders
  18. Feb 26, 2023 at 2:29 PM
    eagleguy
    eagleguy New Member
    If you take the OEM handle and tweak it a little to the right (1-2 o'clock) it will feel totally different.
  19. Mar 6, 2023 at 2:25 PM
    JWWard03
    James
    Fixed it. I usually do this to all my manual trucks, but it works here too. It's a lower profile too when in gear and that's what I was looking for. Thanks everyone for the input.
  20. Mar 6, 2023 at 2:38 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    You can always mod the stock knob. As for shortening the handle, it won't require a lathe, just a hacksaw, a good sharp die, and a little patience.
  21. Mar 6, 2023 at 2:39 PM
    eagleguy
    eagleguy New Member
    Anything out there with an Eagle stick on or whole handle?
  22. Mar 6, 2023 at 7:23 PM
    S13ka24de
    S13ka24de New Member
    I kinda grow into getting used to it....i can rest my hand on it. Its level with the arm rest
  23. Mar 7, 2023 at 4:25 AM
    Kitt
    Kitt New Member
    2017 Tundra SR5 TRD 4x4
    Completely stock
    Hey, are those control knobs custom? I have a 2017 and my knobs look different.
  24. Mar 7, 2023 at 6:53 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    RobertD, Kitt[QUOTED] and bulldog93 like this.
  25. Mar 7, 2023 at 1:24 PM
    Kitt
    Kitt New Member
    Completely stock
    Awesome stuff brother. Thanks for the info. I might steal your setup
    1lowlife likes this.
  26. Mar 7, 2023 at 1:28 PM
    Kitt
    Kitt New Member
    Completely stock
    How did you get the Teton on a Tundra?
  27. Mar 7, 2023 at 3:19 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    I cut the shaft about an inch and got the same shifter knob my wife's Highlander has,
    Unique??
  28. Mar 7, 2023 at 3:26 PM
    RobertD
    Robert
    DFW, Texas
  29. Mar 7, 2023 at 5:18 PM
    Bergy24
    Bergy24 New Member
    Teton sells them for the Tundra. Mine is design 2, and design 3 is out now. Simple removal and install and in my opinion, the best looking knob available.
  30. Mar 7, 2023 at 7:01 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    Tinkerer Design
    Ranger Patch knob
    ToyotaHeritage and Kitt like this.
