Winch setup/kill switch
Discussion in 'Recovery & Gear' started by TexMedic, Feb 24, 2023.
  1. Feb 24, 2023 at 5:51 PM
    TexMedic
    TexMedic [OP] I ask a lot of questions…
    2017 Dark Gray DC Tundra 4x4
    Do I need a winch kill switch? I’m looking into the Badlands Apex 12000lb (synthetic line) winch, and so I’d most likely just use the one that’s included in the kit. I’ve read across multiple forums that the winch will always be drawing power (especially if it’s wireless- like the Apex), but at the same time some people say that’s a bunch of crap. Another point is in case something shorts out and/or the winch won’t stop. I won’t be using this thing that often, but I just wanna do it right.
    Any input would be appreciated.
  2. Mar 15, 2023 at 7:59 AM
    4x4WarriorOfRocks
    4x4WarriorOfRocks New Member
    2010 Tundra 4x4 Rock Warrior
    I have a ComeUp, and the manual says the winch will shut itself off, whether using wireless or wired control, after 5 minutes of not being used. So I would say just try and find the manual of the winch you want, or call them to find out for sure.
    NewImprovedRon likes this.
  3. Mar 15, 2023 at 8:43 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I use this in between the battery and the winch so that my winch never has a live wire until it is needed. If the winch's solenoid gets stuck closed or if you get in an accident and that fat ass cable somehow makes contact with the frame you'll have to disconnect it from the battery side.
  4. Mar 15, 2023 at 9:00 AM
    I run a breaker for some of the same reasons @Cruzer mentioned 30026124-FE43-4BF2-ADBB-20C58594446B.jpg
    Mater and Cruzer like this.
  5. Apr 6, 2023 at 2:56 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    does that replace the whole winch control box or do you use it like a regular on/off solenoid on the power wire from the battery?
  6. Apr 6, 2023 at 2:58 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Regular on/off. I use it for the winch and the inverter actually.
  7. Apr 6, 2023 at 4:27 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Just get one of these and put it between your battery and control box if want cheap insurance. Those solenoids (especially if they’re not genuine albrights) can get stuck. Keep it out of the elements and you should be fine though
    NewImprovedRon and FrenchToasty like this.
  8. Apr 6, 2023 at 6:33 PM
    helidave
    flagstaff
    2015 DC 4x4
    That's what I was going to do, but it would be nice to be able to turn the winch on/off without popping the hood.
    Mater likes this.
  9. Jun 2, 2023 at 7:34 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I didn't install one but I have a breaker switch on my accessory tray next to the Auxbeam
    The Black Mamba likes this.
  10. Jun 2, 2023 at 7:52 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I see that this is a few months old. Did you resolve the issue and install a switch?
    I have always only had Warn winches. Currently I don’t have an isolation switch for the one on my tundra.
    Yep, that’s correct information about the wireless controller being a phantom drain. The wireless part is always on, waiting for a signal from the controller. There’s a small weather tight switch on the side of the winch controller but if you switch it off you have to switch it on again if you need to use the winch. I just keep my truck hooked up to a battery maintainer. Sometimes it’s sitting for months.
    Mater likes this.
  11. Jun 6, 2023 at 5:37 AM
    TexMedic
    I did. I ended up using the kill switch that was included with the winch. It’s simple, sturdy, and easy to use. Sure it takes a second to open the hood to switch it on, but there aren’t really any other drawbacks. Cheap insurance too.
  12. Jun 6, 2023 at 6:06 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I use this switch.
    gosolo[QUOTED] likes this.
  13. Jun 6, 2023 at 8:48 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    FUNTECK 2-Position Single Battery Disconnect Switch for Car Camper RV and Marine Boat, 12-60V DC, 275 Amps Continuous, Comes with 2 Copper Terminals https://a.co/d/9rkLkXT
    I’m ganna try this one.
  14. Jun 6, 2023 at 9:00 AM
    I have a power disconnect inside the cab of my crawler by the ignition switch. That way when I roll over I can shut off all voltage to the vehicle to decrease the chance of fires.
    Cruzer and Y0TA PR0 like this.
  15. Jun 7, 2023 at 3:22 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    On my tundra, because of the hidden winch mount and some of the other accommodations, it is extremely hard to access, requiring laying on my back, crawling partially under the truck and squeezing my hand into a small space down next to the fog light. I regret getting the hidden winch set up and the remote winch
  16. Jun 7, 2023 at 3:26 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ahh I see why you'd skip the hassle then. I suppose the hidden winch is a compromise in that regard
    Mater and gosolo[QUOTED] like this.
  17. Jun 7, 2023 at 5:57 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I prefer the look but it’s difficult to cleanly respool. I like being able to handle all aspects of a winch situation solo and fast so I really was attracted to the wireless remote. However, dependence on the technology and maintaining a charge in the controller suck.
  18. Jun 7, 2023 at 6:27 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I’ve got a Warn with a wireless remote. Hate it. I can’t free spool cuz something’s not working properly on the remote. Costs a shit ton of money to send it out to get fixed. No way in hell am I going take that fucker out.
  19. Jun 7, 2023 at 6:28 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've wondered quite a while on how the remote stays charged? Is it the phantom power draw?
  20. Jun 7, 2023 at 6:42 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    That’s correct. I just keep my truck always on a battery maintainer
  21. Jun 7, 2023 at 7:05 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You'd think they'd state a warning in the manual but nope.
  22. Oct 28, 2023 at 9:47 AM
    Fieldnstreamer
    Fieldnstreamer Cold Researcher
    Sam
    East Tn
    2006 DC Limited 4x4 Phantom Gray Pearl, 2000 AC Limited 4x4 (R.I.P.)
    Brute force bumpers/sliders, OME 3" lift, SCS ray 10 wheels, ARB onboard air compressor, GX460 big brake upgrade, JBA UCA's, siberian Bushings, RCV high clearance axles, 333 Billet steering rack clamp, TMR customs 10" front limit straps, 1" diff drop, agility customs dual battery setup/battery isolater with heavy duty wiring/ grounding cable upgrade, F-er battery tray, HFW spindle gussets, remote oil catch can,
    Probably a good idea unless you have a dual battery setup with an idolator like I do.
  23. Oct 28, 2023 at 10:23 AM
    AZBoatHauler
    So.Arizona
    I haven’t had any issues - SuperWinch with wireless remote has been on 6 months - no kill yet.
    :crapstorm:
    snivilous and Black Wolf like this.
  24. Oct 28, 2023 at 12:57 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I left my truck parked for a week and it was deader than a doorknob. I had to do a deep cycle charge before it would start.
    Mater likes this.
  25. Oct 28, 2023 at 2:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Mater likes this.
  26. Oct 28, 2023 at 4:37 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Those 8mA tho :boink:
    AZBoatHauler likes this.
  27. Oct 28, 2023 at 4:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Those 8mA are only to keep the switch closed (i.e. hot). So when it's OFF it's dead cold.
  28. Oct 28, 2023 at 5:22 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    My only hope is that when I do finally grow up, I’ll be smart like you.
    This, just being good looking, hasn’t really paid off…
    texasrho83 and AZBoatHauler like this.
  29. Jun 12, 2024 at 12:57 PM
    pg_osborne89
    pg_osborne89 New Member
    I’m going to use the supplied battery switch. Whenever I use the winch I’ll most likely be popping my hood to flip the clutch on the winch anyway, so why not.
  30. Jun 12, 2024 at 2:32 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I have had a winch installed for several years without a kill switch and it has never drained my battery. I rarely drive my 4runner nowadays, and it's not uncommon for it to sit in the garage for 30 days between starts. No problems.
    I have a voltage monitor and have not noticed more than very minimal voltage drop after long periods. I do have a SINGLE type 34 Odyssey battery. Dual batteries is overkill if you're not sitting out in the desert for days on end.. We even did a lot of that and never had an issue.
