2013 tundra glove box light
Discussion in '2nd Gen Tundras (2007-2013)' started by Elfries81, Feb 21, 2023.
  1. Feb 21, 2023 at 9:56 AM
    Elfries81
    Elfries81 [OP] New Member
    Ernesto
    2013 4.6l tundra double cab
    Not much besides new headlights
    I recently replaced my tundra glove box light put the new bulb in, and it did not fix the problem. Found the interior fuse box check the fuses cannot find a fuse, burned out that was supposed to have the seat heaters which the glove box is on allegedly in that truck. Is there a relay or something that would power of the seat heaters in the main fuse box or is there something else I’m missing
  2. Feb 21, 2023 at 10:11 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Do you have to have your lights on for the glove box light to work? My 2015 didn't come with a glove box light but I thought I read that somewhere. Then again, it could just be my age...
    Found this post with a similar issue: post #17
    Glove Box Light | Toyota Tundra Forum (tundras.com)
    PhotoNerd likes this.
  3. Feb 24, 2023 at 12:28 PM
    Elfries81
    Ernesto
    I found the issue. Loose pin on the plug to light. I heard it snap into place and it works now. And yes the light only works when head lights are on its always on
